Our fax machine will only fax 20 pages from memory is there a way to clear the memory? We fax about 60 pages every night so this has become a big issue.
    President:
  • 1,082 Answers
You include no details about your fax machine.
However, Are your faxes from paper copies only? Do you have to print them out to fax them.?
IF SO.. then you should use a PC fax card, to fax directly from a PC. If you have hard copy only, then the addition of a scanner, with a document feeder to speed things up, will enable you to do same thing. Should be able to que up all the faxes and walk away.
Posted on Nov 10, 2010
How do you clear the fax memory on a OCE FX3000? Says memory is full. Not connected to a pc just use machine for copies and fax
Check your owners manual. your machine may be out of memory. To free up extra memory, you can turn off
fax storage (see Turning off Remote Fax Options on page 64), print fax messages
in memory (see Printing a fax from the memory on page 46) or cancel a delayed
fax or polling job (see Checking and canceling waiting jobs on page 38)
Sep 14, 2016 | Office Equipment & Supplies
How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
Jan 18, 2014 | Office Equipment & Supplies
I HAVE A SHARP UX-A450 FAX MACHINE AND WANT TO EMPTY THE FAX MEMORY.
MEMORY IS FULL / SEE MANUAL (alternating messages)
The memory is full. You may have too many messages recorded in the answering machine. To erase messages, see below. This may occur during fax reception if too much data is received before the pages can be printed out. If faxes have been received to memory because printing is not possible (an additional message will indicate the problem), resolve the problem so that printing can continue (see Substitute Reception to Memory on page 66). If you are attempting to transmit from memory, see If the memory becomes full on page 57. If you are copying, see If MEMORY IS FULL appears on page 67.
Erasing received messages:
It is important to erase received messages after you listen to them to ensure
that the memory does not become full.
? Erasing all messages: To erase all messages, press FUNCTION, DELETE, and then START/MEMORY.
? Erasing a single message: To erase a single message, press DELETE while the message is being played.
If the memory becomes full while the document is being scanned, MEMORY
IS FULL and SEE MANUAL will alternately appear in the display.
? Press START / MEMORY if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder. After transmission, the memory will be cleared and you can transmit the remaining pages. You will also need to transmit the page which was being scanned when the memory filled up.
? Press STOP if you want to cancel the entire transmission.
Nov 25, 2010 | Sharp Office Equipment & Supplies
Sharp fax machine UX30 memory is full. How to empty fully?
If the memory becomes full while the document is being scanned, MEMORY IS FULL will appear in the display. This may occur during fax reception if too much data is received before the pages can be printed out.
  1. Press these keys: (function) 6 # #
  2. The display will show: RECEPTION RATIO
  3. Press 1 to turn automatic reduction on.
  4. Select the reception ratio to be used in the event that the memory becomes full (automatic reduction is not possible when the memory is full). Press 1 for 93% or 2 for 100%.
  5. Press the STOP key.
If you are attempting to transmit from memory:
  1. Press the START/MEMORY key if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder.
  2. After transmission, the memory will be cleared and you can transmit the remaining pages.
  3. You will also need to transmit the page which was being scanned when the memory filled up.
  4. Press the STOP key if you want to cancel the entire transmission.
Here is a copy of the User Manual for the Sharp UX30:
http://www.docshare.com/doc/227849/Sharp-UX30-User-Manual
Jun 30, 2010 | Computers & Internet
How to clear fax memory on Magic 2
how to delete faxes from memory from a philips magic 2 fax machine
Feb 19, 2010 | Philips Magic5 Voice DECT Duo - Fax /...
Saying Memory Full - How do I clear the memory?
If it is unwanted pages and not incoming faxes.
Shut it off and unplug it, this should clear the page memory.
Hope this helps
Ed
Apr 30, 2009 | Office Equipment & Supplies
My Sharp UX-355L Fax machine printed unwanted information
Sounds like you have the machine set up to print reports on all occasions, fax transmission, error, etc. You can change this by doing the following:
1 Press these keys:
FUNCTION
TRANSACTION LIST
2 Press a number from 1 to 5 to select
the condition for printing.
ALWAYS PRINT A report will be printed after each
transmission, reception, or error.
ERR/TIMER/MEM A report will be printed after an error,
timer operation, or memory operation.
SEND ONLY A report will be printed after each
transmission.
NEVER PRINT A report will never be printed.
ERROR ONLY A report will be printed only when an
error occurs.
To print from memory:
If the memory becomes full...
♦ Press the START/MEMORY key if you want to transmit the pages
♦ Press the STOP key if you want to cancel the entire transmission.
Hope this helps. : )
Mar 30, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
Fax running slow
try unplugging machine. then press and hold "stop/exit" button while plugging in machine. continue holding button for 5 secs, then release. that is a procedure to clear any faxes stuck in memory.
hth,
razors
Feb 18, 2009 | Brother IntelliFAX 4100 Laser Fax
How to clear Memory in Sharp UXP115
FIRST:1-PRESS START/MEMORY KEY IF YOU WANT TO TRANSMIT THE PAGES WHICH STORED UP TO THAT POINT IN MEMORY THE REMAINING PAGES WILL BE REJECTED FROM THE FEEDER.AFTER TANSMISSION THE MEMORY WILL BE CLEAREED.AND YOU CAN TRANSMIT THE REMAINING PAGES.YOU NEED ALSO TO TRANSMIT THE PAGE WHICH WAS BEING SCANNED WHEN THE MEMORY FILLED UP.
PRESS STOP IF YOU WANT TO CANCEL THE TRANSMISSION.
Feb 20, 2008 | Sharp UX-P115 Plain Paper Thermal transfer...
How do I get it to print docs in memory?
Does the fax machine produce a copy? If there is a paper jam/toner error, this needs to be sorted first. What is on the display?
Aug 20, 2007 | Brother IntelliFAX 5750e Laser Fax
60 people viewed this question
k24674
jasbo
jasbo
