Question about Pioneer DVR-7000 DVD Recorder
I have pioneer dvr-7000 with japenese language display. I have 2 problems . No.1 I am not able to record from TV via RCA auidio video cables(Red,Yellow and White). No.2 While playing with the onscreen menu display, my remote has been disabled. Now i am in real trouble.. Please tell me the soloutions for both of these problems. or reply.
5 Suggested Answers
premtech
  • 934 Answers
SOURCE: pioneer dvd recorder dvr 310
I've seen this problem somewhere before, ran across it on a service call or something and I just can't remember where.. Just getting old I guess.. You should have a "Return" button on the remote. Press it and the "2"... That should allow you to access the unit again. What you've done basically is set the unit up as unit 2 and you could have as many as 3 identical units all operating from the same remote. So, Pioneer, in their infinite wisdom decided to make three specific designation points and allow you to switch the remote to access each one without disturbing the rest... If this doesn't solve the problem you might try calling Pioneer support, 800-421-1404 and they should clearly be able to help. Good Luck Bill
Posted on Jun 07, 2007
  • 979 Answers
SOURCE: help with re-setting system
This format disc is a "hit or miss" on whether it will play. Sometimes, an alignment will help along with a good cleaning of the optics...accordianman
Posted on Mar 21, 2008
ser71
  • 818 Answers
you can reset the configuration to the Configuration factory
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/Blu-rayDisc+DVD/PioneerDVDPlayers+Recorders/ci.DVR-310-S.Support?tab=F
Sergio
Posted on Mar 27, 2008
SOURCE: pioneer dvd recorder dvr-530H
The EPG is the electronic program guide trying to download TV listings.
http://en.wikipedia.org/wiki/Electronic_program_guide
This is normal for this player. To disable this, you would need to turn off the TV guide function.
Posted on Mar 19, 2009
I would like to connect the audio from my Comcast DVR via digital optical thru the TV/SAT IN optical on the receiver at the same time I have a composite connection via the TV RCA composite jacks. ( This...
I'm a little confused by your use of 'composite' with audio, as in "Does anyone know what would happen if I ran both composite audio and optical audio both to their respective TV/SAT IN input jacks on the STRDE935 ?". What is composite audio?
The manual claims on page 48 that you can't record digital audio out to the analog REC OUT jacks.
http://www.retrevo.com/s/Sony-STR-DE935-Receivers-review-manual/id/387dj981/t/1-2/
I say 'claims' because the engineers or manual writers clearly are not as creative as you are in trying to wring as much utility out if this unit as possible.
I can't find an answer but I would offer this - if you are recording anything though any AVR, as soon as you choose to monitor the audio the digital input is usually disabled.
And I would be curous to hear more about what you're doing and how you finally achieve it.
Dec 25, 2010 | Sony STR-DE935
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
I cannot record copy-protected tapes to DVD on my RCA DVD recorde
Here is a link to the installation guide for your Pioneer model - refer to every bit of information on p. 29 (which will refer you to some pertinent info in Ch.1): http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/98391312Installation%20Guide%20DVR-810HS.pdf
If it will not permit you to do the recording:
You have to use a backdoor method. Inspect your TV and see if it has a yellow jack labelled video OUT or monitor OUT - many TV's do not have them. If you are one of the lucky ones that has a video OUT:
1) Connect a VCR to one of the televisions inputs.
2) Connect a red, white and yellow cable from the video and audio OUTs of your TV to either INPUT 1 or 2 on your DVD recorder
3) Make sure that your DVD recorder is set to either INPUT 1 or INPUT 2 - reading the manual for that model is driving me up the wall - I would change the channel on the DVD Recorder (not the TV) to 2 and use the channel down button until it says Input 1 or Input 2 - whichever the appropriate choice is
4) Play the VHS tape and make sure that you can see the picture on your television screen.
5) Press Record on the DVD recorder
Good luck- I would go insane trying to use that Pioneer - it is user-friendly, but not techie-friendly.
-Tha Mp3 Doctor
Jan 07, 2009 | Pioneer DVR-810H DVD Recorder
Pioneer dvd recorder dvr-530H
Sep 28, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
How Do I hook up my Sanyo DVW -7000 To my Dishnetwork Box to record?
Connect the "Out to TV"video and audio on the DVR box to the "Video in and Audio In" on the VCR ...unless it's a single screw type connector on the DVR then hook THAT to the "In from ANT/cable" on the VCR
Sep 08, 2007 | Sanyo DVW-7000 DVD Player/VCR
Pioneer DVD Recorder - can get picture but no sound
If you are using RCA cables, you need to hook up three cables (1) yellow video, (2) white - left audio, (3) red - right audio.
May 28, 2007 | Pioneer DVR-520H DVD Recorder
Digital audio problems
Try using a different cable for starters, regular rca, another optical or coaxial. If the optical works, then its a cable problem. If the coaxial works(and another optical doesnt), then its a cable/jack problem. If the RCA works(and the rest don't), then its a problem with the digital output. Try blowing into the holes, and if nothing works and you can't find any other advice, contact Pioneer. Good luck
Mar 11, 2006 | Pioneer DVR-5100H DVD Recorder
Pioneer DVR-7000 DVD Recorder Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
