Question about Whirlpool LER5636P Electric Dryer
Belt replacement how do i get the drum out to replace the belt?
Some one tell me how to put on a f-n belt
Posted on Nov 16, 2008
    Novelist:
  • 177 Answers
Based on your model number, pick up the correct belt, order online if needed. always first unplug the dryer, remembering once you open the dryer there are sharp edges!
then on the top pull the lint filter out. under the lint filter are two to three screws take them out
now the top will snap off the clips in the front, you may need a putty knife to release them. flip the top up from the front to the back.
on the inside are two screws one on each side the hold the front panel on the top, clips hold the bottom on, set the front panel to the side. if the belt is still in one piece and not broken look at how it rides around the idler wheel to the motor. remove the dryer cylinder and vaccuum out as needed. replace belt.
rebuild dryer in reverse. and let me know if you have questions.
T
Posted on Jun 21, 2008
REPLACING THE DRUM BELT
Belt should go around entire drum then around motor pulley (which is metal) and tensioner/safety pulley (which is the white pulley)
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
Tip
Dryer Belt Replacement Replace Dryer Belt Admiral Amana Asko Crosley ...
If you need to replace your dryer belt and need a diagram to see how it goes, check out these diagrams.
For Admiral all models will look like this
154ceff.gif Style: Flat with ribs
Installation Tips: Ribs against drum
For Amana all models will look like this
Installation Tips: Ribs face toward drum
For Asko all models will look like this
For Crosley all models will look like this
Fridgidaire
1970 – 1985
1985 – 1995
1995 – present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 02, 2010 | Dryers
What does a belt life ends soon mean, on a brother MFC 9440ch color laser printer?
Are you sure of the error message? The Brother printers that I have used have Drum Ends Soon and Change Belt messages.
The Brother MFC-9440CN has a belt that can be replaced. The Belt unit has an life expectancy of ~50000 pages. The belt unit is part BU100CL and costs a bit over $150 at office supply stores. Amazon.com and some other stores have the unit for under $100. http://www.amazon.com/Brother-BU-100CL-HL-4040CN-HL-4070CDW-Series/dp/B000SC245E is one source.
When the unit says Change Belt Unit, follow the directions from the manual's maintenance section to replace the belt unit. See page 178 (page 189 of the PDF) http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002252/mfc9440_usa_usr_b.pdf . You have to remove the Drum and then the Belt Unit. Then slide in the new Belt Unit and replace the Drum unit. Then close the printer and turn it on. Finally reset the counter from the Machine Info sub menu (press Menu 8 4 and select the Belt Unit and press OK. Then press 1 followed by Stop/Exit).
If you mean the Drum Unit, that is part DR-110CL and costs over $175 at the office supply stores. Order this part when the Drum End Soon message appears and replace it if the print quality deteriorates (or when you have the new drum). The Drum Life is ~17000 pages. The steps start on page 166 (182 of the PDF). You need to remove the old Drum unit. Then remove the toner cartridges from the drum. Prepare the new Drum Unit, including putting the cartridges in the new Drum. Then replace the Drum unit and reset the counter.
I hope this helps.
Jun 04, 2012 | Brother MFC-8460N Laser Printer
How to replace a belt on this style dryer, is there a trick
REMOVE THE SOCKET FROM THE WALL OUTLET.
To replace a belt that passes over the drum on a dryer you need to be able
to pass the new belt over either the back or the front of the drum. This
entails removing the front panel to clear the whole drum or loosening off
the rear bearing support to pass the belt under it so that the belt can be
passed over the drum. From there it is just a case of passing the belt
over the motor pulley and replacing all the parts. Select which will be
easier on your machine. After replacing everything but the top panel,
make sure that the belt is correctly installed by turning the drum several
revolutions by hand and ensuring that the belt is running true and still
on the motor pulley. Tension the belt by either adjusting the motor or the
tensioner, if the machines has one of those. Replace the top cover and
you are set to go.
Mar 19, 2011 | Dryers
How do a replace the belt on the drum of my indesit washer dryer
To replace a belt that passes over the drum on a dryer you need to be able to pass the new belt over either the back or the front of the drum. This entails removing the front panel to clear the whole drum or loosening off the rear bearing support to pass the belt under it so that the belt can be passed over the drum. From there it is just a case of passing the belt over the motor pulley and replacing all the parts. Select which will be easier on your machine. After replacing everything but the top panel, make sure that the belt is correctly installed by turning the drum several revolutions by hand and ensuring that the belt is running true and still on the motor pulley. Replace the top cover and you are set to go.
Feb 19, 2011 | Indesit Washing Machines
Past few days, dryer got very noisy. Then drum
The noise is coming from a moving part. There are only a few that normally cause a problem. Also the dryer drum not turning freely is what broke your belt. Here is what I would replace. Drum rollers, Drum slides and idler pulley. You can check these parts before you replace them. If the drum rollers don't spin real easy, replace. If the idler pulley does not turn easy, replace. If the drum slides are worn, replace. Your model may be one with a front drum bearing. If it looks worn, replace.
You may be able to take dryer apart, try turning drum. Listen for the noise and notice if the drum is hard to turn. If so, you may be able to determine if the problem is in the front or back of drum. Keep on mind that the noise might have been the belt slipping due to the drum being hard to turn. Either way, when you have it repaired, it should run with the noise. Good luck.
Oct 16, 2009 | Kenmore 400 6943 Dryer
We are trying to replace the belt to our front loader dryer DLE5977W and are not sure how to take the dryer apart. Do we start from the front or the back.What steps do we need to replace the belt. Thank...
If it is a front loading machine:
You would remove the front of the machine, that will expose the drum and belt, remove the drum and belt and that will expose the drum rollers,motor, idler arm pulley.
Before you replace the drum and belt assembly, Check you drum rollers for flat spots, If they have flat spots on them replace them. I would also recommend that you lubricate your drum rollers with a good quality of machine oil such as 3 in One Oil. This will save you later on another disassembly because of noisy drum rollers.Apply the oil at the shaft of the drum rollers.
I hope this helps
Oct 04, 2009 | Dryers
Best way to replace drum belt
The belt is acessable from the front of the dryer you can remove it by popping the top up then taking off the front of the dryer off the drum will come out now place the belt around the drum and put back in now the belt goes around the drum the motor pulley and under the tentioner pulley replace front and top and you are good to go thank you
Please rate me
Apr 18, 2009 | Bosch Axxis WTA 3003 Electric Dryer
Asko T720 clothes dryer - thumping noise like the drum is damaged and shakes when going.
hi
The drum of the dryer is usually turned by a motor-and-belt assembly. There are two very clear signs that the belt is malfunctioning: You can easily spin the drum by hand when the dryer is off, or you hear a heavy thumping sound coming from the drum when the dryer is running. Here's how to test and replace the drum belt:
Step 1: Locate the belt by removing the back or front service panel. Depending on the type of dryer you own, you may have to prop up the drum to keep it from sagging. Don't let the drum hang; the bolts that hold it in the cabinet could be damaged. Don't remove any more parts than necessary.
Step 2: Identify the belt. The old belt may be threaded around the idler pulley and motor drive shaft. Draw a diagram showing how the pulley is installed so you'll be able to replace it properly. If the old belt is worn or frayed, but not broken, leave it around the drum as a pattern for positioning the new belt; cut the old belt and remove it when the new belt is in position.
Step 3: Remove the old belt from the pulleys and stretch the replacement belt into place. The new belt must extend around the dryer drum and the pulleys. The trick is to align the belt on the drum with the pulleys -- the ribs on the new belt go against the drum.
Step 4: Once the belt is aligned, turn the drum by hand, if possible, to make sure the belt is tracking. You may have to reassemble part of the cabinet to do this.
Sep 13, 2008 | Asko Dryers
Transfer belt error
Transfer belt error, this is cause by the OPC drum which connects the belt. Make sure the drum sit well with the belt else replaced the drum.
Jan 29, 2008 | Samsung CLX 3160fn All-In-One Printer
Whirlpool LER5636P Electric Dryer Logo
60 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
