Question about Samsung Televison & Video
Hello, i have a samsung sp43t6hp, the picture seems to be out of line with green fuzzy lines around the picture
  • elliott_pete Jul 16, 2008
    I have replaced the 2 big ICs which normally fix this sort of thing, but till have bad blue convergence at center of pix.
5 Suggested Answers
  • 308 Answers
SOURCE: Rear Projection TV Picture is all green with Horizontal Lines
It looks like you started out with an intermittent solder connection which may have been fairly easy to find early on. Now, unless a technican can make it come and go while tapping on the circuit board and repair the connection, it may be a very expensive shop repair.
Posted on May 29, 2007
SOURCE: HL-P5063W Green lines when the tv warms up
My Samsung DLP is having the same problem.  Not sure what to do, but I will contact my warranty place for the second time.  Hopefully they'll fix it.  Any other suggestions?
Posted on Apr 06, 2008
Russmann
  • 203 Answers
SOURCE: Samsung 56 HLR566 Vertical Green Lines
I suggest unplugging your entire system for one minute to try a reset again. Sometimes a system reset doesn't take the first time. If this does no good you probably have damage to your digital board or dmd board. I have a smaller version of the same set at home and have done samsung's warranty service for several years. They deliver a great picture but do need regular maintenance and or repairs. The upside of all this is if you have homeowners insurance it may be covered, depending on your deductable amount. However, a dmd board can cost 500.00 so you may have to go that route. Hope this helps, Russmann.
Posted on Jul 14, 2008
  • 2920 Answers
SOURCE: how to fix fuzzy pic & red,blue,green lines on your screen?
i would call a repairman and have him come out and fix it.if you like the tv then its worth fixing if you dont then dont invest any money in it. but if it were me id have a repaiman come and fix it
Posted on Jan 26, 2009
racer7x
  • 42 Answers
SOURCE: images have red and green outlines on them picture somewhat fuzzy
your convergence ic's are Shorted
They have a kit for this tv it is available through local parts distributors
If you can't find it locally just Google HITACHI CONVERGENCE KIT
If you are not good with de-soldering and soldering do not attempt this repair. Remember to replace all the resistors in the kit
If you are not sure about doing this repair you should have your local tv guy do it for you
I
Posted on Feb 10, 2009
White fuzzy thin vertical lines appear on screen. The picture is fine, but the lines are in front of it. Is this something than can be repaired?
Hello can you post a picture of your tv set with the fuzzy white lines thank you so I can give you the best sound advice.
Aug 19, 2014 | Sylvania Televison & Video
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
Green line on left side of an image and a red line on right. Such as around a face. Colors just don't line up and picture is very fuzzy. Had another old rear projection and it had a way to align it. Can...
Your other model was more than likely a CRT projector where you coulod manually align the Red/Green/Blue guns. The one you have now is more than likely an LCD projector which can't be readily aligned. Sounds like the panel is failing.
Mar 13, 2011 | Zenith R57W46 57" Rear Projection...
PICTURE IS FUZZY AND DISTORTED
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 26, 2009 | RCA HD52W59 HDTV Projection Television
Green Background with red wavy lines
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
*Screen Looks 3-D
*Colors wont align
Jan 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Green vertical lines
reset the settings to factory default. the resolution doesn't match.
Nov 20, 2008 | Office Equipment & Supplies
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
141 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
