Question about KitchenAid Dishwashers
My kitchenaid imperial 21 kud121ds2 won't drain. It is not hooked up to a garbage disposal
2 Suggested Answers
gypsycat00
  • 224 Answers
SOURCE: I have an Kitchen Aid Imperial 21 Model KUD121DS2.
Make sure the incoming water temp is 120 degress or above and be sure that you restored flow at the angle stop. If you turned off power at the breaker box, make sure it's restored as well. If it's hooking up to a garbage disposal that did not orginally have a dishwasher, you need to knock out the plastic cap at the bypass pipe.
Posted on Jul 12, 2009
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Need drain elbow for kitchenaid disposal KWS200
Parts are available at many sources
Copy following link to repair parts, troubleshoot and replace disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Add a comment as needed, or repost question with detail
Jun 01, 2012 | KitchenAid Batch Feed Garbage Disposal...
Garbage disposal won't work. It just makes a humming noise
might be something lodged in it, like a spoon or something. Turn it off and fish around in it with your hands.
May 01, 2012 | KitchenAid KCDB250G 1/2 HP Continuous-Feed...
Garbage disposal won't stop running
Check switch. replace switch. If switch checks out, then replace disposal to avoid risk of overheating and in-wall short.
Copy following link to repair, troubleshoot and replace disposal:
Dec 18, 2011 | KitchenAid Batch Feed Garbage Disposal...
Our garbage disposal won't turn off. batch feed
Turn off circuit breaker, and replace switch
Sep 03, 2011 | KitchenAid Batch Feed Garbage Disposal...
Water won't drain
Remove P-trap and clean tubular drain and p-trap
Apr 17, 2011 | KitchenAid Batch Feed Garbage Disposal...
I have an Kitchen Aid Imperial 21 Model KUD121DS2. Water, drain, and electrical is hooked up, but unit will not turn on. any ideas?
Jul 12, 2009 | Dishwashers
My quiet partner 4 will no longer drain, I recently replaced my garbage disposal & the problem began after that.
There is a plug you have to remove on the garbage disposal where you hook up the washer drain hose.
Check the instructions with the disposal.
You'll have to deinstall the garbage disposal, remove this plug and reinstall.
May 05, 2009 | Dishwashers
Dishwashers Logo
104 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
