Question about Lexmark X342n All-In-One Laser Printer
My display reads: 857: Time out in wait for MEACC
VHF/UHF RF Power falls to Zero when the Auto ATU tunr logo is on the display. When the tunr logo is off the VHF/UHF RF power is only 10 watts on 2M and 3 watts on 70cms. The Yaesu FT 857 D should have no...
Check for open or shorted Veractor diodes and steering diodes there may be no direct interaction as you say but if a diode is open or shorted the RF circuits might still be selected for the higher bands and the lower output power on your vhf/uhf is an indication of this.
If you do not have a service manual you can get one hear, you will likely kneed one
http://www.tradebit.com/filedetail.php/127575994-vertex-yaesu-ft-857-ft-857d-2005-service-repair
Good Luck Best regarsds Falco
Nov 04, 2013 | Yaesu FT-857D transceiver
857d does not display tunr icon when set up for atu operation
In the extended menu, double check the "tuner mode". Sometimes the 857 requires a "factory reset" (also in the extended menus) to get it working with external antenna tuners.
Aug 09, 2013 | Yaesu FT-857D HF/VHF/UHF Mobile...
Iam trying to connect my sony kdl hx 700 to wireless network and my ps3 but my router is a cisco 857 can it be done?
There are 2 models of the Cisco 857 router. You must have the the Cisco 857W in order to support 802.11b/g wireless. The 857 without the "W" will not support it.
Jan 08, 2011 | Cisco 857 Router (CISCO857K9)
Entered code display now reads waiting 2
must be careful, if you already make a 2nd try. most the 3rd try if the code again wrong. then the next wait time will be more longer to reset the wait. make sure the radio is remain on.
Jan 05, 2011 | Kenwood KDC-PSW9524 CD Player
WHERE CAN I BUY A SONY T-CON BOARD PART NUMBER SONY 1-857-132-11 ? IT IS FOR A KDL-52W4100. 2" Vertical stripe problem all the way across the screen. fades in and out. If iI try resoldering the...
The part # you gave is the Control Board which sells for $668.79. The T-Con board your looking for is part of the LCD Display Panel and is not sold separately. I suggest you start by cleaning the ribbon cables from the control board to the t-con board. If that doesn't help then you had better take it in to a service center to verify which part is bad because there are no refunds, only replacement after you buy a board.
Nov 19, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Display faded to black and standby light blinks 14 times. Sony support said it is an error code and I am trying to find out what the error code is.
14 blinks is a high frame rate error, you can check the LVDS cable connections first, if not work replace the T-con board, if still not work, replace the panel, but it is not worth the money to repair.
There are two different t-con boards for this model, part # 1-857-132-11 cost $270, and 1-857-240-11cost $200. It depends on the serial #, you need to make sure which one is for your TV.
Apr 12, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
How can i config my DSL acount in cisco 857
with a dialer interface:
interface Dialer0
description $FW_OUTSIDE$
ip unnumbered Ethernet0
ip access-group sdm_dialer0_in in
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ppp authentication chap callin
 ppp chap hostname xxxxxxxxxxxxxxx
 ppp chap password xxxxxxxxxxxxxxxxxxx
Mar 10, 2010 | Cisco 857 Router (CISCO857K9)
Jandy Aqualink display reads "waiting"
System locked up. Handheld is frozen at WAITING screen means Microprocessor is locked.
Here is what you do:
1. Turn off power to the system (control box)
2. Disconnect battery at the Power Center (9volt battery in control box/cross tip screwdriver required)
3. Turn on power
4. Reconnect the battery
5. Reset time and date on PDA.
6. Thank me.... BadWally sends
Aug 20, 2009 | Jandy AQUALINK RS TELELINK KIT
I have lost the manual for my aiwa lcx 337 and would like to programme the radio alarm timer.
Well, I had a heck of a time researching, but I found a link to a manual for a model number LCX857, but the page reads that it would also work for your model, the LCX337. I tested the link, and the file is valid and virus free. It's a pdf file, about 7.5 MB. Here's the link: http://www.service-manual.eu/download.php?file=Aiwa-857.pdf Hope this helps.
Jun 13, 2009 | Aiwa LCX-331 Shelf System
How do I get to at least watch a DVD or VCR
if after the hello display you open the tray and inserted already the dvd push play and the thing is always with the hello and after reasonable time (one minute) and nothing change the display stil with the hello thing:
use another dvd and the same answer.
your dvd is not read in the memory because the set is not able to do it and the memory is waiting for that data. So your Dvd memory is waiting for the mechanism to send that data and say: hello.
So time to visit a repair place. to amke sure about any estimate.
Apr 24, 2009 | RCA DRC8335
Lexmark X342n All-In-One Laser Printer Logo
200 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
