Question about Sony Playstation 3 (PS3) Console
Tried to use update 3.50 on my ps3. It failed and my system isn't working normal
  • Sony Master
  • 6,993 Answers
You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
Good luck.
Posted on Nov 10, 2010
How do I correct error code 8002F310
The error code your getting is saying that your PS3 is failing to update. You can disconnect your system from the internet, turn off automatice updates and try it manually or you can try loading the update through the PS3's safe mode. This link will show you how to get your PS3 into safe mode. https://support.us.playstation.com/app/answers/detail/a_id/1488/kw/Safe
Also, you can download the update onto a flash drive and load it onto your system from there. This link will explain how to do so.
http://us.playstation.com/support/systemupdates/ps3/pc_update/index.htm
Nov 04, 2013 | Sony Playstation 3 (PS3) Console
I have a problem with my ps3. The wifi isn't
Try plugging in an ethernet cable for wired access.
http://imageshack.us/photo/my-images/120/sonyplaystation3unveilewa7.jpg/sr=1
Aug 14, 2011 | Sony Computers & Internet
I did an update on my ps3 called ver 3,50 and its saying that all my passwords are wrong for all my acounts if you can suggest anything plz do ill be waiting !!!
There has been a problem with the latest Sony update that unfortunately is causing people to be unable to log into thier Playstation Network accounts.Sony are working to fix it and will hopefully have it sorted very soon.
Hope this helps
Sep 21, 2010 | Sony Playstation 3 (PS3) Console
Console is trying to system up date but keeps failing
There are many reasons why an update wont complete. Normally you are given an error number. Try googling this and see what answers there are. Another reason is faulty internal hardware for example if your blu ray drive is faulty it will not complete an update.
Hope this helps.
Jul 29, 2010 | Sony Playstation 3 (PS3) Console
My playstation network keeps failing in my ps3 and not sure how to get it back working my internet is working fin my ip address succeeds and so does the internet connection when i test my connection on the...
This is a worldwide issue with the Sony Network today which might be due to system maintenance and upgradation.
Sony is working on the problem and the problem will be rectified soon. Kindly wait for further announcements from Sony. Your system should work normally when the issue is fixed.
For details and status updates, click here
Thanks for using FixYa.
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 turns off for every ten seconds and I can't update!
HI. You will need to Clear Any Failed system updates that cause the console to error. Use this procedure to acheive this .
  • With the console off, press and hold the sync up button (the small white one)
  • While holding the sync button press the power button to turn on the console
  • Continue to hold the sync button until the Console has booted up completely.
  • During the boot process the console should clear any failed updates, allowing you to use it normally.
Oct 02, 2009 | Sony Playstation 3 (PS3) Console
PS3 blackscreen, but sound! tried all common tricks to reset!
Try your cable connections..either its not conencting properly to the back of your tv. or your cord is fried. Try a different tv and see if it works, if it does, it may be the connectors on your TV.
Mar 22, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3
Hey fyocksofresh,
If performing a system update with your PS3 fails, you may wish to try updating using a USB flash drive and your home computer instead. In order to do so, you'll need to create the following folders on the flash drive itself:
PS3 > Update
Once this is done, you'll want to visit the website I've provided below to download the most recent software version. The link should be easily found under the "Download the System Software" heading on the page.
http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=275
Once you've downloaded the file and transferred it onto the USB flash drive, connect the flash drive to your PS3 and choose "Update via Storage Media" instead of the normal internet option.
In the event that updating the software this way doesn't work, there are a couple of things you may wish to try before attempting again.
1) Delete all the cache files and cookies from your PS3's internet browser.
2) Power cycle your PS3 (turn it off completely, then back on) before attempting again.
3) Restore the default PS3 system settings. This should clear any potential problems that may be caused by your current system software version.
If none of these help, I'd strongly suggest contacting Sony for more information. You should be able to do so by calling their toll-free hotline at 800-345-SONY (800-345-7669) or by filling out an online repair request form.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 26, 2008 | Sony Playstation 3 (PS3) Console
Ps3 System Update Failed, PS3 boots with error code 8002F14E.
-Open the side of your PS3 where your HDD is. Take the screw out, but leave the HDD in.
-When the update begins, pull your HDD out of the slot. It will tell you an error occured and it tells you to restart your system and try again. Instead, let the count from 60 run out, your screen will go blank for about 30 seconds then it will start back up and tell you that your Hard Drive needs to be reformatted. If you do not get this msg after 30 seconds, do it again until it does! Now, slide your HDD into place again - (make sure your controller is PLUGGED IN) and press the white PS3 button on the controller. It will then ask you to either press start and select at same time OR white PS3 Button - PRESS START and SELECT. Do not agree to user agreements!! Simply hit cancel and it will kick back to the PS3 start up screen.
Mar 13, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
13 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
