Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
My Prima LPR 600 shows the fault code of four flashes followed by a pause. Any ideas please?
3 Suggested Answers
  • 6 Answers
SOURCE: prima lpr 600 dishwahser
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No Heat Dry" button for 4 seconds (or more.  I'd suggest trying this on yours...
Posted on Feb 25, 2008
ginko
  • 19396 Answers
SOURCE: no lights on prima lpr 600 dishwasher just keeps
When there is no light at all, and machine is stuck with inlet valve open from start, then it is probably a faulty timer control board.
Before replacing the control board , the inlet valve, wiring harness, and additional electronic controls must be tested.
Try also unplugging the appliance from main, or tripping circuit breaker to cut power for ten minutes. ~This may unlock a jammed control board.
Posted on May 21, 2009
My flash code is SEVEN PAUSE SEVEN which indicates JOYSTICK FAULT.
PDF]INFINFB2043_Jazzy_600-600XL_Troubleshooting_Rev B ...
www.pridemobility.com/download.php?...Jazzy_600-600...
Pride MobilityWhat if the systems on my Jazzy 600/Jazzy 600XL seem to be "dead" (controller does not ... Each controller will flash a code via the battery ... 7. Joystick error. Contact your authorized Pride Provider. Four yellow LEDs ... This is indicated by the VR2/VSI speed ... flash in a numbered sequence followed by a 2-second pause
Jan 18, 2016 | Pride Jazzy 600 JAZZY 600
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
On/Standby light flashes red four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 27, 2012 | Sony VPL-EX100 3LCD Projector VPLEX100
Hello..i repalce the computer in my 1997 sebring convertable because it had problems it would not start..engine wont turn over..and even after i replace the distributor cap,spark plugs & wires and...
You will need to extract the fault codes from your vehicle's computer, as follows:
1) Turn ignition key: ON, OFF, ON OFF, ON (leave in ON position)
2) The Check Engine light (CEL) should start flashing
3) Read codes as follows:
- First group of flashes indicate 1st digit of code (followed by short pause)
- Second group of flashes indicate the 2nd digit of code (followed by short pause)
Note: a long pause separates each fault code, then codes will repeat again
e.g. Flash, Flash (short pause), Flash (long pause)...... indicates Code: 21
4) Code 55 indicates end of CEL code output
Post your codes results here and I can assist you with the appropriate repair.
Cheers,
"If this has helped you resolve your problem, please be kind enough to leave a testimonial"
Jun 10, 2011 | 1997 Chrysler Sebring
Unable to start the oven prima lpr9023
Hi i have just fitted my new prima double oven Type FCSM9 Model LPR 9030 and the main oven will not work, and i can not set the clock. it came without instructions. can you please help
Nov 10, 2009 | Ovens
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Prima lpr 600
Sounds like something may be blocking the pump, causing overload -- may need a service call.
Feb 10, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Prima LPR 600
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No HEat Dry" button for 4 seconds (or more.  Try this.
Dec 27, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Prima LPR600
my prima LPR intregated dishwasher just not playing ball, has not been washing properly and had a continuous flashing and beeping fault, we cleaned out the filers and the arms which seemed to help the beeping problem but now have a fault where at the end of the cylcle its now showing another fault where it flashes 4 times but beeping has stopped what seems to be the problem and how do we fix ?
Oct 17, 2007 | Dishwashers
Prima lpr 600 dishwahser
Oct 14, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
219 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
