Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Lcd tv pliz help,one night l switched of tv with a remote.rhe next day when l switched it on it didnt butthe red light on the switch on button was flashing red off and on repeatedly but the screen cant light on.the tv is 2 months old,samsung LCD 32".
  • FANUEL Jun 17, 2008
    no comment
  • ptpumpman Jul 04, 2008
    LE32M86BDX SAMSUNG LCD IF YOU SWITCH IT OFF AND TRY TO SWITCH IT ON AGAIN STRAIGHT AWAY IT WILL NOT COME ON ,YOU HAVE TO WAIT HOURS SOMETIMES OTHER TIMES IT WILL COME ON AFTER 30 MINUTES NO LESS . OTHERWISE ITS A GREAT TELLY BUT THIS IS A BIG PROBLEM.
    PTPUMPMAN
5 Suggested Answers
  • 9 Answers
SOURCE: No picture
try chicking the horizontal section or vedio section...
Posted on Jan 29, 2008
  • 58 Answers
SOURCE: DIGITAL SOFTWARE UPDATES FOR SAMSUNG 32 INCH LCD TV
you cant force updates, and they may never be another update. updates are only made when there is a problem with the software in the tv
Posted on Mar 12, 2008
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
  • 41 Answers
SOURCE: Same problem: LA40R71B
Does it make the the samsung jingle when it trys to turn on? if it does you need a power supply if not then most likely it is the main board. I would contact you r local service center for help and if the standby lights in the front blink in a certain pattern write that down it is a error code that the technicain can use to solve the problem.
Posted on Oct 07, 2008
  • 10 Answers
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
My olevia LT23HVX does not power on
Try unplugging and replugging after waiting.
Jun 13, 2008 | Olevia LT23HVX 23 in. LCD Television
My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
hi first you will need the proper remote control once you have this press the menu button on the remote, retune the tv hope it helps
regards
shaun
Apr 01, 2014 | Proscan Televison & Video
Power is on in standby, but takes several times pushing the power button for the power or tv to actually come on
Very bad for the TV, don't do this!
Got the remote control? Switch on or off (full operation) from Standby with it and just use the main manual switch on the TV for, say, morning ON for the day and evening OFF for the night.
Sep 21, 2011 | Soyo Crystal DYLT032B 32 in. LCD...
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Daewoo DSL-17DW3 NO RESONSE at all, remote nor manual
There is a problem with these, common to many other badly designed TVs. They get too hot for the capacitors which dry out and cause all sorts of probs.
May 18, 2009 | Daewoo DSL-17DW3 17.1 in. HD-Ready LCD...
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
Jerry Greenberg
Jerry Greenberg
