Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
Canisters on my ge smart water filtration system gxsv10c model are stuck tight. How do i get them open
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 306 Answers
Make sure the water is turned off to system. Open the faucet to system to drain any water and keep the faucet turned on to keep pressure off filter housings.
1.Use the wrench to take housings off.
2. If they still won't budge take a small 2x4 block of wood and hammer, set the block of wood on the RIB for the housing and tap with hammer.
3. Change the o-rings in both housings, lubricate with silicone lube and lubricate the threads on housings with silicone also.
3. Rinse housings with small amount of bleach and clean thoroughly.
4. Replace filters and housings.
5. IMPORTANT: Only tighten housings by hand. NEVER tighten housings with wrench.
RJ
Posted on Jul 03, 2011
My GE Smartwater filtration system makes a whining sound
The system is most likely running to the drain. Bypass the water softener to see if the whining stops. If it is running to the drain it is either stuck in backwash cycle or the interior seals are bad and need to be replaced. If it is stuck in backwash the drive motor is probably bad and needs to be replaced.
Here is a link to GE website for manual
http://genet.geappliances.com/DocSearch/Dispatcher
RJ
Jun 17, 2011 | General Electric GE SmartWater Household...
I need a handle for the Smart Water System
Here is the web page for GE. You will probably have to replace the whole faucet. When you call have the model # available for your system so they can supply the appropriate faucet. You may as well order more filters as they will be less expensive ordering on-line. These filters should really be changed every 6 months.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Dual_and_Single_Stage_Water_Filtration
These faucets are relatively easy to replace for the do it yourselfer.
RJ
Feb 24, 2011 | General Electric GE SmartWater Household...
WHAT SIZE SOCKET NEEDED TO REMOVE ANODE ROD?
Hello EDAN I believe it is 1 1/16" socket.I had 1/2" drive & extention bar as it very TIGHT & hard to turn the rod nut.
Jul 15, 2010 | General Electric GE SmartWater Household...
MY GE SMART WATER FILTRATION HAS A DRIP ON THE
If it is coming from the canister, pull it off, check the o-ring, it is probably pinched. It will need to be replaced.
RJ
Mar 29, 2010 | General Electric GE SmartWater Household...
I have a ge smart water electric water heater and
does it not have adjustments for heat settings. I thought these were smart as in maintaining heat with demand
Mar 05, 2010 | General Electric GE SmartWater Household...
How do you change the GE smart water filters?
This page might help with changing it, as different models vary.
Feb 18, 2010 | General Electric GE SmartWater Household...
Instruction manual for ge smart water filter
Here is the website that you can get your users manual. You will need the model #. Pls rate ny answer
Kurt
http://www.geappliances.com/service_and_support/literature/
Apr 19, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
295 people viewed this question
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
