Question about HP laserjet Cp2025dn color Card Printer
My HP CP2025 is printing too light. Most noticeable when printing maps, black in gray red is pink and the rest is unreadable.
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: my HP CP1700 prints out gray tones in pink.
Your head / nozzles must be dirty , perform a nozzlecheck /head clean from printer software maintainance utility,
regards
Posted on Mar 28, 2008
duane_wong
  • 6826 Answers
SOURCE: my HP printer is not printing reds or pinks. Only
sounds like it's low on ink.
Posted on Jul 03, 2010
  • 17 Answers
SOURCE: HP3500 all colors are printing too light - black
Calibration is a printer function that optimizes print quality. If experiencing any print quality problems, calibrate the printer.
  1. Press (Select) to enter the MENUS .
  2. Press (Down arrow) to highlight CONFIGURE DEVICE .
  3. Press (Select) to select CONFIGURE DEVICE .
  4. Press (Down arrow) to highlight PRINT QUALITY .
  5. Press (Select) to select PRINT QUALITY .
  6. Press (Down arrow) to highlight CALIBRATE NOW .
  7. Press (Select) to select CALIBRATE NOW .
  8. Wait for the printer to calibrate.
that should solve your problem
Posted on Aug 13, 2010
Danco instructions
Umm, yeah I think so....
Nov 10, 2013 | Danco Home
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
My HP CP2025 printer will not print color text and color shading in Word. It prints color photos, pdfs, and paintbrush files, but will not print color in Word or Word Perfect.
I had this problem on Windows 7 64x.
The solution that finally worked for me:
1. Go to your Devices & Printers window. (from the Start menu)
2. Right-click on your HP CP2025 printer and select Printer Properties.
3. Select the Device Settings tab.
4. Scroll to the bottom where you see Device Type. It probably says "Auto Detect."
5. Click on the words "Auto Detect" to activate a drop-down menu. Select "Color". Click the Apply button.
To test if this fixes your color printing, go to the General tab and click the Print Test Page button at the bottom. The page should print the Windows logo in color at the top of the page (the rest of the page is b&w).
Note: I did not install any additional drivers from HP for this printer. Windows automatically detected it and installed HP's Universal Print Driver PCL 6.
Kudos to Ken from the HP forums for this knowledge: http://h30499.www3.hp.com/t5/Printers-LaserJet/CP2025-Won-t-Print-in-Color/td-p/1151762
Feb 10, 2011 | Office Equipment & Supplies
HP Color Laser Jet CP2025. Replace Supplies message on screen and can't get it off. Put in a new print cartridge. Message still won't go away. Please advise how I can get a User Manual for this...
HP Color LaserJet CP2025 - "Replace Supplies" message.
black cartridge is blinking. Printer won't print and message will not go away. Any suggestions?
Nov 09, 2010 | HP Office Equipment & Supplies
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
HP3500 all colors are printing too light - black is gray, blue is light blue, red is pink, etc. All cartridges are full, no error message on printer
Aug 12, 2010 | HP Color LaserJet 3500 Printer
LaserJet 6L Prints Outlook content too light
You can run into these problems when using non OEM toner cartridges. It sounds like anything that is printed in a light gray is not printing correctly.
Apr 28, 2008 | HP LaserJet 6L Printer
I also had the google maps print issue on my HP3030 and fixed it by setting the "Default Quality" under "Copy Setup" from the HP3030 menu to "Photo" from "Test".
That's a hardware setting on the HP 3030:
Menu/Enter > Copy Setup > Default Quality > Photo
Hope this helps.
Terry
Sep 30, 2007 | HP LaserJet 6Lxi Printer
HP laserjet Cp2025dn color Card Printer Logo
495 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
