Question about Efficient Networks SpeedStream 5100 Modem
MY 5100 keeps dropping my DSL (LIGHT TURNS RED AND KEEPS FLASHING) My phone co. says my lines are fine and my provider says my DSL service is good. After it is on awhile the problem goes away until the next time I shut the system down & restart it. I always shut it down in bad weather & unplug all power and phone lines. Is there a way to test the modem ???
5 Suggested Answers
  • 57 Answers
SOURCE: Internet connection
I think your modem needs to be configure by your ISP.
I change my modem here in my house with other brand and did'nt work, so i put the original modem i used and it works again..
Posted on Nov 15, 2007
  • 3 Answers
SOURCE: speedstresm 5100 modem
check for physical setup between your modem and the wall jack
if u don know how exactly the physical setup is pls contact your isp for help for u to run through the steps
Posted on Feb 06, 2008
fossilruins
  • 114 Answers
SOURCE: Trying to use SpeedStream 5100 with new DSL Provider
I have Centurytel myself, so maybe I can help:
A link to your Speedstream 5100 router:
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
And the typical setup for the westell 6100 that centurytel uses:
Centurytel will provide you with your username and password.
PPPoE Configuration:
VPI 8
VCI 35
Protocol: PPPoE
Hope this helps.
Posted on Jun 12, 2008
  • 12 Answers
SOURCE: speedstream 5100
red light on DSL implies no ADSL communication to ISP. Check your phone line connection and make sure there are filters on all the other phone equipment in the home
Posted on Sep 09, 2008
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
Nov 11, 2012 | Computers & Internet
Internet signal keeps dropping
There's a lot of possiblities here.If you have a DSL/dialtone lineshare,listen for noise on the line(humming,crackling static,dropped calls).If you have a dry loop(DSL only),connect a phone in place of the modem and see if it has an "intercept" message(like "you have tried to call a number out of your service area" or something like that).If it does,you can use a phone to check the line when the DSL drops(don'touforget to put an inline filter on it).If the DSL light doesn't go out when the Internet light does,it is NOT a problem with the physical line.This would be an issue with the modem or the equipment at the serving end.( I am a DSL tech,and spend lots of wasted time diagnosing and trying to fix problems that are beyond my reach(central office server issue) or that I didn't need a dispatch for(it is cheaper to send a new modem than to send a tech).
Jun 02, 2012 | D-Link DSL-2640R Wireless G ADSL2 Modem...
I have a flashing icon on my WRT120N linksys router and when i connect my dsl modem to it, i have no internet connection. How do i fix this?
  1. check the line has internet service enable (telephone provider),
  2. check the microfilters on each telephone plugs
  3. check the dsl light stays always on. if not is a line/provider service problem.
  4. enter the router webpage.
  5. configure the user and password internet acess codes. (check the internet provider for your internet account)
  6. check the internet light turns on
Nov 06, 2010 | Linksys WRT120N Router
2wire 2700HG-B Dsl light blinks green than turns turns red, keeps repeating. does not connect.
If your DSL light goes green solid to red check to make sure all your phones are filtered. Make sure your not filtering your 2Wire.
May 14, 2009 | 2wire 2700HG-B Router (2700HGB)
Intermittent ADSL connection
The DSL light blinking or going out indicates that the DSL modem is loosing sync. This is usually caused by noise on the line. When you get the DSL service you should be given filters to put on all of your phones so that the phones will not interfere with the DSL signal. Those filters need to be attached to anything connected to the phone line that has the DSL on it except for the DSL modem. Other than that the problem could be on the service providers end, something outside your home, or the DSL modem going out. I would suggest that you verify everything is filtered, then contact your service provider so they can run test on your DSL line.
Dec 23, 2008 | Siemens SpeedStream 4200 (13A4200001)...
My SBC 2Wire modem (yellow light) in the middle between the green lights goes on and off. Intermittent....
The middle light is the light for internet services. If it is flashing that means its looking for a dsl signal, if its solid orange that means it needs authentication information (IE: username/password entered into it) and if its solid red that means you have no signal at all. What I would recommend is first check all the phones/alarms/satelite dish systems in your house and make sure they all have dsl filters on them before plugging into the wall, since this will cause an intermittent dsl connection. If everything is fine then call your Internet Provider and have them do some line tests for you to see if the service is having problems.
Aug 15, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Speedstream 5100
Aug 01, 2008 | Efficient Networks SpeedStream 5100 Modem
Westell 327 wireless router
you have the DSL filters plugged into all your telephones, but NOT plugged into the DSL modem?
is the DSL modem configured to automatically connect using your username and password?
have you tried using a different phone cable, or plugging into a different phone jack?
Mar 29, 2008 | Westell Wirespeed VersaLink...
2701HG-B
Hi. I will not repeat the check the phone line and resetting comments as it's now redundant.
I always have a spare modem as a line tester.
I've seen several 2700HG-B 2wire modem/routers burn out and every single time it's the DSL signal or modem portion that is burnt out. Even if you have two or three phone line surge protectors these 2700s are prone to shorting out unless you have a direct signal splitter DSL setup.
Here are a few things you can try to confirm if the 2700 is no longer functional on the DSL signal light problem.
#1: Turn on (plug in) your 2700 without the phone line plugged in and wait. If the DSL starts flashing red then there is a hardware problem in the modem/router.
#2: Plug the phone line into the 2700 while the dsl light is flashing red. It might take about 3 seconds however it should start to flash green and let it flash for about (usually) three minutes. If it turns red then the 2700 is indeed damaged.
#3: If you can enter into your modem using the http://2wire... and check the connection status. The first two status lines should read attempting to connect and no connection.
Nov 01, 2007 | 2wire 2700HG-B Router (2700HGB)
Open Questions:
Efficient Networks SpeedStream 5100 Modem Logo
98 people viewed this question
Top Efficient Networks Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
