Question about RELIANCE ELECTRIC WATER HEATER
Hello, i have a reliance 606 im having a problem that the reset button, it keep on tripping. when i reset it last like 2 days then it trips again. i have changed the upper thermostat and element and it still trip had to reset it again. now yesterday i changed the lower thermostat and element. what do u think is the problem
  • Reliance Master
  • 5,245 Answers
  • 18 Answers
As a precaution just double check the wiring and make sure the upper thermostat isn't set higher than the lower thermostat as this runs the risk of the upper element running continuously.
Posted on Nov 10, 2010
    Genius:
  • 1,015 Answers
It sounds like you have things pretty well covered. I would change reset and if it continues to trip breaker I would check wiring very carefully where it enters top of water heater. Check for any nicks or bare spots on wiring insulation. Other than that about all I can think of is to change breaker. Sometimes they do get weak and trip to easily. Hope this helps. Thanks
My reliance 606 electric water heater keeps tripping the breaker. When it is reset the water gets real hot and trips again, then no hot water. Help!
You water heater most likely has a shorted heating coil, don't run it like this, call a service technician.
Nov 10, 2016 | Reliance Water Heaters
We have a reliance 600 about 4 years old. Recently when you turn on the hot water you get a lot of air out of the line. Also the other day we had scorching hot water and then no hot water. We reset the...
1) Reliance 606 Electric water heater, AO Smith subsidiary.
Good brand.
Copy following links:
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) First: Test elements using cheap multimeter from hardware store.
Next: If elements test OK, then replace both thermostats.
3) If that doesn't solve problem, then add comment Jan 2013 and report what you find.
Jan 26, 2013 | Water Heaters
Reliance 606 electric 40 gallon hot water heater will get extremely hot and then shut off. I have to push the reset button after showers. I have turned the heat down but it still gets to hot. Thermostat...
ECO reset button trips for several reasons.
1) Easiest thing without testing, is replace both thermostats.
2) If problem persists, then test elements.
3) If problem continues, do full troubleshoot
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 08, 2011 | RELIANCE ELECTRIC WATER HEATER
I just replaced my old rusted out water heater with a new Reliance 606 and now I am having problems with the circuit breaker being tripped, usually during the night. It doesn't happen everyday but is...
I would check with your owners manual to see what they reccomend for minimum breaker size. I don't remember on this particular model but it may be a single element instead of dual element. The single element usually use more power than dual. I would also check thermostat settings if this is a dual element. They should never be set at same temperature. Also if it continues to trip breaker I would check all wiring,then replace breaker. Sometimes they do wear out and trip when they really shoul not. Hope this helps. Thanks
Nov 15, 2010 | RELIANCE ELECTRIC WATER HEATER
My electric water heater keeps tripping the high temp cut off switch every day. I've replaced the thermostat and the problem still occurrs.
the element is shorted out causing this issue.
I have had that happen to me before.
or there is a water leak dripping down on it and causing it to trip the reset switch.
Nov 14, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a reliance 606 electric water heater. it heats water fine when its on...it keeps tripping the circuit in the breaker box though...How do I fix this? thank you!
Open covers on tank and inspect for burned connections or melted parts
1) Test electricity to water heater:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
2) Test water heater elements
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Aug 31, 2010 | RELIANCE ELECTRIC WATER HEATER
Water Too Hot
needs new thermostat(s) If the whole tank is heating( next time it trips, before using any hot water check the lower tank thru the lower element access(breaker off) If the lower tank is hot-you need a new lower thermostat. if just the upper part of the tank is heating -you need an upper thermostat.
Jan 18, 2010 | RELIANCE ELECTRIC WATER HEATER
Reset continually trips.
reset button on the upper thermostat keeps tripping
Nov 04, 2009 | RELIANCE ELECTRIC WATER HEATER
RELIANCE ELECTRIC WATER HEATER Logo
474 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
