Question about Canon ImageClass D861 Printer
Canon D861, paper jam at exit roller. How can I get to it.
5 Suggested Answers
SOURCE: Paper jammed at exit rollers of Canon D860. Paper
You can download the repair manual for a similiar Canon printer, the iR1200-1500, on Ebay for $ 3.00 to $ 5.00 and this will tell you how to take apart the printer. I had the same problem and the manual allowed me to remove the fuser assembly and clear the jam. If you prefer, Canon sells the Image Class D860/880 repair manual for you printer for $54 plus shipping. The Ebay dealer also included the parts maunal, which is a sepatate charge from Canon.
Posted on Jul 18, 2010
checkitright
  • 1362 Answers
SOURCE: paper jam at "exit" - canon D660
open side door and front door, there should be foor screws holding the fuser.
remove screws and take out unit ( be careful, there is a wire connected to the machine, you do not nesscessarily have to disconnect it. ) take out paper and replace.
Posted on Nov 14, 2007
  • 56 Answers
SOURCE: Hi I have a paper jam at the fuser rollers on a
You accually need a new fuser unit and to take it out its quite a mission.
you need to remove in this order:
the drum unit
the left panel holding the glass
the glass
where the scanner is there is a black thin guide holding the ribbon cable...take that off.
the display panel
bottom left side panel
bottom read side panel
bottom top panel
flip over the black milar cover over the power supply.
disconect the 3 cables
move the platern about half way and you will see the holes on top of the platen aligned to the bottom so to get to the 3 screws holding the fuser unit.
undo the screws with a long star screw driver and slowly wigle the fuser out.
to put it back you do everything in the opposite order.
Good luck
Posted on Oct 09, 2009
canontech
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
Does error P07 on a Canon DR-G1100 indicate that there is a paper jam or that a counter needs to be reset?
P007 indicates that a document has jammed before exiting the registration post sensor. Make sure the path is clear and no staples are stuck in the rollers. I like to use a microfiber cloth, with a small amount of 50/50 alcohol on it, to wipe down the entire feed path; top and bottom. The microfiber cloth will grab staples that may be wedged between the rollers/roller openings. Beyond that, it could be a timing issue from a bad/loose drive belt. Actually, there are quite a few things that could cause a paper jam before exiting the post registration sensor. Wipe it down and let me know.
Scan-R-Store
Dec 01, 2014 | Canon DR Office Equipment & Supplies
Paper keeps getting jammed
Verify the paper way,clean the rollers and check the paper way sensor actuators.If jammed to fusing/exit parts verify the fuser rollers and strippers.
Apr 19, 2013 | Canon MX700 Office All-In-One InkJet...
If you remove the plastic covers on that side of the printer, you will see a small screw holding a bar against the rollers. Set the printer on end so you can remove this screw with out dropping it into the printer, and then the rollers will be loose enough that you can get the paper out.
May 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
Paper jam. paper tore at the exit roller. I
FUSER ASSEMBLY NEEDS TO BE REMOVER/REPLACED, THE COST AND LABOR MAY NOT BE WORTH THE REPAIR
Jan 22, 2010 | Canon ImageClass D660 Copier
Paper jam in canon Imageclass D861 copy machine
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam from bottom tray.
You might have a piece of paper out of sight. It usually is before the toner and after the pick up area. BEst to call 800-ok canon to find a local service center. This unit comes with a 3 year warranty, and you might still be covered.
Jul 09, 2008 | Canon ImageClass D861 Printer
Paper jam
Your best bet is to have a canon tech check this problem out. There are several causes for this issue; a bad delivery roller, a small piece of paper lodged out of sight. Canon help is 800 ok canon.
Canon ImageClass D861 Printer Logo
109 people viewed this question
old marine
old marine
