Question about Canon PC-795 Copier
I have a PC-795 the paper feed doesn't take the paper completely through the copier. I also have a finger screw that has come out and I can't find where it goes.
  • 25 Answers
Throw the finger screw away. packing for the mirrors. look at the exp lamp are the ends black. if so change the ex lamp. causes jam at regi. otherwise change the feed clutch
Posted on Nov 12, 2010
A friend gave me a Marling 22 rifle model 795 but it has no magazine. Where can I find one and how much?
you need to find a magazine
and thats not that easy
a local gunshop may have a source
magazine are the problem with this rifle
While we’re discussing the magazine, let me say this is my least favorite element of the rifle. The mags are straight-walled stamped metal with a red plastic follower. While their design helps them keep a minimal footprint and weight, they don’t facilitate easy loading. The springs on these are stiff, and even after thousands of rounds it’s a battle to feed them to capacity. Their shape doesn’t help either; there’s no great way to grip them and the lips of the mag are also prone to nipping at your fingers and thumbs as you feed in the tiny rounds. The only thing about the 795 that made it less fun to shoot was stopping to reload the magazines.
Apr 16, 2017 | Optics
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
PC795 Won't feed from originals tray
Hello sir; There have no paper jam because the paper pick up roller not kickout the paper, replace the paper pick up roller.
Mar 30, 2009 | Canon PC-795 Copier
I have a canon pixma mp180. some little plastic pieces fell into the paper feed. I pulled what i could see out but now the paper jams when being fed. I did the maintenance roller cleaning. I was wondering...
I kept running the maintenance roller cleaning with paper in the feed and eventually I was able to see the tip of the plastic piece that had fallen in as I pulled the paper through with my fingers, I was able to get the whole piece and now the printer is golden.
Jan 28, 2009 | Office Equipment & Supplies
Paper will not feed through machine
Brass screw is probably the chrome packing screw which normally sets in a hole near the front of the copier when you open the "**** shell" Paper pick up could need feed wheel. clean with fantastic or soap and water and see if it helps. Also on this model check your exposure lamp is it coming on, if not it may on flicker, On all these PC when the lamp goes bad the paper jams usually at turnaround. Good luck.
Jul 07, 2008 | Canon PC-795 Copier
Canon pc 430 feeder problem
You may have to fabricate a new anchor for one end of the spring on the side opposite the control panel. There is a wimpy plastic tab that breaks off here, right next to a black Phillips-head screw. Remove this screw and bend a piece of light wire around it, leaving a small hooked end sticking out for the spring to fasten on to. Replace the screw and install the spring. When you install the spring, it must go over the top of the tiny white plastic wheel, in the U-shaped groove.
This is how I repaired my PC430 several years ago and it's still working fine.
Jan 27, 2008 | Canon PC-430 Color Copier
PC-795 Shuts Off Mid Copy
clean big rubber paper feed roller above paper tray with a microfibercloth moistened with rubbing alcohol.
open copier look in lower section under the toner cartridge you will see a black foam roller wipe it off also and then try to use.
Jan 17, 2008 | Canon PC-795 Copier
Pc795
pc 795 copier wont pull paper through,error light comes on,machine stops.
Dec 16, 2007 | Canon PC-795 Copier
Canon PC-795 Copier Logo
90 people viewed this question
old marine
old marine
