Can you give me a complete list of the command prompts??
    Guru:
  • 2,178 Answers
Type "Help" at the prompt. Hit enter and you'll get a list.
Posted on Nov 10, 2010
I forgot my password xD
1) Start your computer
2)Toggle F8 to enter "Safe Mode" then navigate to the "Advanced Boot Options".
3) Select Safe Mode with Command Prompt.
4) Wait for a while, you can see Windows 7 boots up to the login screen. Choose administrator,
5) Go to Start > Run and type cmd.exe, a Command Prompt dialog box pops up.
6) Type net user and press Enter. All the windows accounts will be listed, then type the acount you wish to change.
7) when the command is completed successfully, the new password has been successfully reset.
Sep 02, 2017 | Computers & Internet
Tip
Disable/Enable Hibernation in Windows
To make hibernation unavailable, follow these steps: <br /> <ol> <li>Click Start</b>, and then type <span>cmd</span> in the Start Search</b> box. <li>In the search results list, right-click Command Prompt</b>, and then click Run as Administrator</b>. <li>When you are prompted by User Account Control, click Continue</b>. <li>At the command prompt, type <span>powercfg.exe /hibernate off</span>, and then press ENTER. <li>Type <span>exit </span>and then press ENTER to close the Command Prompt window.</li></ol> To make hibernation available, follow these steps: <br /> <ol> <li>Click Start</b>, and then type <span>cmd</span> in the Start Search</b> box. <li>In the search results list, right-click Command Prompt</b>, and then click Run as Administrator</b>. <li>When you are prompted by User Account Control, click Continue</b>. <li>At the command prompt, type <span>powercfg.exe /hibernate on</span>, and then press ENTER. <li>Type <span>exit </span>and then press ENTER to close the Command Prompt window.</li></ol>
on Mar 26, 2011 | Computers & Internet
Tip
How to Reset an Password for Acer eRecovery
Acer eRecovery is a vendor-specific method you can use to restore your computer to its original factory settings, or to custom settings you create and store on your hard drive or other removable media. eRecovery also contains a back-up utility you can use to back up data to your hard drive or other removable media. Access to eRecovery requires you to use the default "000000"password or one you select. While it is important to store a custom password in a safe location, if you lose or forget it, there are steps you can take to reset your Acer eRecovery password.
Access the Diskpart command prompt. Acer stores custom eRecovery passwords on your computer in PQService, a hidden rescue partition. Locating this partition requires accessing the Diskpart utility from the command prompt. Diskpart allows you to run a scan on your hard drive and bring up hidden partitions.
02d2ca3.pngstep 1. To access Diskpart, go to "Start" and type "cmd" in the Search bar to bring up the black command prompt box, and then type "diskpart" at the prompt to switch to a Diskpart prompt. Depending on your computer, a new command prompt may open with the Diskpart prompt.
Step 2. Scan your computer configuration. At the Diskpart prompt, type "rescan" to run a system configuration check. When the scan finishes, you will receive a message informing you the scan is complete. At the command prompt, type "list disks" to bring up available disks and then type "select disk 0."
Step 3. Locate the hidden partition. At the command prompt, type "list partition" to view a list of partitions on your disk. Locate the partition with no name and a size of approximately 10 GB. At the command prompt, type "select partition (number)."
Step 4. Determine the partition type and unhide the partition. The hidden PQService partition will be either a type 27 or a type 12 partition. If the partition is type 27, unhide it by typing "set id=07 override," and if a type 12, then unhide it by typing "set id=0B" at the command prompt.
Step 5. View PQService partition. Return to the disk containing PQService by typing "select disk 0" at the command prompt, and then type "list volume" to view the contents of the disk. PQService will be visible in the list, preceded by a number. Type "select volume (number)" and then assign PQService a new drive letter so you will be able to open and view it from your computer interface window. At the command prompt, type "assign letter=f."
Reset eRecovery Password
Step 1. Open PQService. Navigate to the drive containing PQService. If you are using Windows XP, use My Computer; if you are using windows Vista, use Computer. Find the file "aimdrs.dat." Right click on the file and select "Open with" and then "Textpad," "Notepad," or whatever text editor you prefer.
Step 2. Open file and find password. Open the file with your text editor and locate the eRecovery password. Look for a line that reads, "Password=password name," "Hint=the password hint." Write down the password and close the file.
Step 3. Open eRecovery using the recovered password and follow instructions to create a new password.
Partner: Windows Password Recovery Tool
Contact:annyyu22@gmail.com
Blog:http://www.blog.lostwindowspassword.com
on May 18, 2010 | Computers & Internet
Acer eRecovery management Restore system to factor default but I don't know the password
Locate and Unhide Hidden Rescue Partition
  • 1 Access the Diskpart command prompt. Acer stores custom eRecovery passwords on your computer in PQService, a hidden rescue partition. Locating this partition requires accessing the Diskpart utility from the command prompt. Diskpart allows you to run a scan on your hard drive and bring up hidden partitions. To access Diskpart, go to Start and type "cmd" in the search bar to bring up the black command prompt box, and then type "diskpart" at the prompt to switch to a Diskpart prompt. Depending on your computer, a new command prompt may open with the Diskpart prompt.
  • 2 Scan your computer configuration. At the Diskpart prompt, type "rescan" to run a system configuration check. When the scan finishes, you will receive a message informing you the scan is complete. At the command prompt, type "list disks" to bring up available disks and then type "select disk 0."
  • 3 Locate the hidden partition. At the command prompt, type "list partition" to view a list of partitions on your disk. Locate the partition with no name and a size of approximately 10GB. At the command prompt, type "select partition (number)."
  • 4 Determine the partition type and unhide the partition. The hidden PQService partition will be either a type 27 or a type 12 partition. If the partition is type 27, unhide it by typing "set id=07 override," and if a type 12, then unhide it by typing "set id=0B" at the command prompt.
  • 5 View the PQService partition. Return to the disk containing PQService by typing "select disk 0" at the command prompt, and then type "list volume" to view the contents of the disk. PQService will be visible in the list, preceded by a number. Type "select volume (number)" and then assign PQService a new drive letter so you will be able to open and view it from your computer interface window. At the command prompt, type "assign letter=f."
  • 1 Open PQService. Navigate to the drive containing PQService. Find the file "aimdrs.dat." Right-click on the file and select "Open with" and then "Textpad," "Notepad" or another text editor you prefer.
  • 2 Open the file and find the password. Open the file with your text editor and locate the eRecovery password. Look for a line that reads, "Password=password name," "Hint=the password hint." Write down the password and close the file.
  • 3 Open eRecovery using the recovered password and follow the instructions to create a new password.
Read more
May 23, 2015 | Acer Computers & Internet
MY LAPTOP IS HP PAVILION dv6 I get the error message vssx80042317 or vss writer failed when I try to run a restore. Also in IE9 when I click on a link nothing happens.
1. Click Start, click Run, type Regedit, and then click OK.
2. Locate and then click the following registry subkey:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\EventSystem\{26c409cc-ae86-11d1-b616-00805fc79216}\Subscriptions
3. On the Edit menu, click Delete, and then click Yes to confirm that you want to delete the subkey.
4. Exit Registry Editor.
5. Click Start, click Run, type services.msc, and then click OK.
6. Right-click the following services one at a time. For each service, click Restart:
  • COM+ Event System
  • COM+ System Application
  • Microsoft Software Shadow Copy Provider
  • Volume Shadow Copy
7. Click Start, click Run, type cmd, and then click OK.
8. At the command prompt, type vssadmin list writers, and then press ENTER.
9. If the VSS writers are now listed, close the Command Prompt window. You do not have to complete the remaining steps. If the VSS writers are not listed, type the following commands at the command prompt. Press ENTER after each command.
  • cd /d %windir%\system32
  • net stop vss
  • net stop swprv
  • regsvr32 ole32.dll
  • regsvr32 oleaut32.dll
  • regsvr32 vss_ps.dll
  • vssvc /register
  • regsvr32 /i swprv.dll
  • regsvr32 /i eventcls.dll
  • regsvr32 es.dll
  • regsvr32 stdprov.dll
  • regsvr32 vssui.dll (does not work in Windows XP)
  • regsvr32 msxml.dll
  • regsvr32 msxml3.dll
  • regsvr32 msxml4.dll
Note The last command may not run successfully.
10. At the command prompt, type vssadmin list writers, and then press ENTER.
11. Confirm that the VSS writers are now listed.
12. At the command prompt, type vssadmin list shadows and then press ENTER.
13. Confirm that there are no errors listed. On Windows XP you should see: No shadow copies present in the system.
14. Congratulations your machine should work again with any VSS compatible programs.
Oct 27, 2011 | Computers & Internet
What is the ip address of my dell dimention 2400
To find out your IP address you need to access the command prompt. To do that, click on the start button, click on accessories and then click on command prompt. Then type in ipconfig and hit enter. That will give you your ip address.
Thanks for using FixYa!
Jul 11, 2011 | Dell Dimension 2400 PC Desktop
Cant find my mac address
Assuming this is a Microsoft Windows system...
Click on Start
Then either Run (Windows XP)
Or just type into the dialogue box above the Start button (Windows 7)
Type in: CMD and press Enter
In the black window next to the >
Type in ipconfig /all and press Enter
In the output look for the Physical Address in the 12 character alpha-numeric format of:
xx-xx-xx-xx-xx-xx
This is the MAC address
Jun 02, 2011 | Computers & Internet
Drivers for windows xp, went to Toshiba and not on the list.Anything compatible?
Hello droth770,
It might be helpful to use the SFC command (Type SFC /? ) at the command prompt. The command prompt can be opened by clicking Start > Run and entering 'CMD' in the input box. Here's a good article about using the SFC command: http://www.computerhope.com/issues/ch000749.htm. I hope this helps you
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw562
Aug 09, 2009 | Toshiba Satellite L305-S5907 Laptop
My computer starts and takes me to a black screen where it gives me a choice of " run windows normally or run from last known good configartion etc. however when i click either 1. it reboots and takes...
Did you try Command prompt only? I think it will boot and give you command prompt like C:\>.
  • Try to remove RAM, clean its connection point and then put it again. If no success then try the followings.
  1. If you get command prompt just type SCANREG and press enter.
  2. Follow the on screen instruction, it will make a backup of system files and then will list previously well booted dates.
  3. Select any one date. It will restore system files of that date and will try to boot.
  4. Then Boot normally, if no luck then try again the above process to choose another date.
  5. If still no luck then its time to take a complete installation of your OS.
Good Luck
Iqbal
Apr 21, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
