Question about Dell Inspiron 1525 Laptop
I HAVE DELL INSPIRON 1525 MODEL No4150 MY PROBLEM IS THE SCREEN HAS GONE OFF. IF YOU TURN IT CERTAIN WAYS YOU CAN JUST MAKE OUT THE DELL LOGO ON STARTUP CAN YOU HELP.
  • Dell Master
  • 3,287 Answers
Most laptops and thin screen monitors require a "back light" to allow viewing of the screen. This is done with the use of a compact fluorescent light bulb(s) and ballast. These lamps are slightly shorter in length than the monitor and about an 1/8" in diameter. Like all fluorescent lamps, they require a ballast to start. A failed back light system is the result of one or both of these components failing.
It is possible to replace these components yourself, but often times dis-assembly of the monitor is a tedious task - consisting of many very small screws, clips, clamps and ribbon connections that must be removed. Most times, soldering will be required for lamp replacement. The ballast is usually not too hard as they often have a plug or jack connection and clipped or screwed into place. The problem is that you'll probably have to replace both without knowing which is defective.
Posted on Nov 10, 2010
Dell inspiron 1525
It's a bad hard drive. The only solution here is replacing the hard drive.
Feb 05, 2013 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 shows black screen after dell logo?
The computer cant find a bootable device. Either your boot sector on your Hard drive is gone/damaged (most likely a virus) or the Hard drive failed. Start with booting with your windows disk and try to do a repair installation.
Nov 03, 2010 | Dell Inspiron 1525 Notebook
The left side of my Dell Inspirion 1525 laptop is darker than the right side. Any ways to fix that?
Replace the LCD screen. Probably $120 to buy a "pre-owned" screen, or double-that for a new screen, plus $60 in "labour" for a qualified technician to do the work.
Oct 31, 2010 | Dell Inspiron 1525 Laptop
Booting with External DVD for Dell Inspiron 1525
Power on your system, Press F2 on Dell logo. This would take you to system BIOS. Ensure that USB controller is ON, and USB emulation is also set to ON. Save settings and Exit. System would reboot now. Press F12 on Dell logo, and select USB ROM as the boot device. This should boot your computer through your External drive. If it still doesnt work, try switching to a different USB port. If none of these steps work, it may be a problem with the boot sector on your External drive.
Good Luck!
Abhishek
Mar 22, 2010 | Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1545 start up problem
try press F12 when you see the DELL Logo, if it still goes to BIOS you need to replace keyboard
Feb 19, 2010 | Dell Inspiron 1525 Notebook
My dell inspiron laptop wont let me log on, says i need usb flash drive or floppy disk
Try accessing the BIOS setup (System setup) by tapping F2 on the dell logo screen at startup. and set to load defaults, or change the boot sequence to 1. Hard drive.. Hope this helps
Dec 12, 2009 | Dell Inspiron 1525 Laptop
I have an Inspiron 1525 Notebook and I turn it on and it starts like it is suppose to and then Right before I get to my sign on page it goes to a blank gray screen, What could be wrong
it could be corrupt windows or your resolution in windows was set to high that your monitor does not support or you may have installed the wrong video driver or if you have daul video outs the secondary may be enebled thru windows causing the monitor on laprop to turn off thinking its on ext video!
Sep 01, 2009 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 as a blue screen and error code 0x0000006F. I have tried starting it in safemode but it just freezes. Help!!
I had this issue Call dell and tell them to replace your CPU as it has gone bad. This blue screen happends in this exact model because of the line of cpu's they put in where from a bad line. Call Dell you be glad you did.
Aug 31, 2009 | Dell Inspiron 1525 Laptop Jet Black
My Dell inpiron 1525, does turn on but the display is extremly low... can hardly even read anything... plzhelp
This sounds like the backlighting/inverter has gone out. This can be fixed. It is a fairly tedious job. To have it serviced would range from 100-200$ depending on cost of parts and your location.
Thanks,
Lee
Jul 08, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Dell Inspiron 1525 Laptop Logo
46 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
