Question about Acer Aspire 6930-6771 Laptop
Laptop Screen is Cracked , need to replace lcd 16"
  • Acer Master
  • 5,660 Answers
Let's get back to reality here.
Prices vary from city to city, or township to township, much less country to country.
I'm in the central USA. I can go to the next city, and prices will change.
If I went to California, or New York for example, the prices generally would increase.
I suggest YOU replace it, and save a boatload of money.
I'm going to look around on the internet, to check on Acer Aspire 6930-6771 LCD screen prices.
The search hits I provide will not be advertising, just examples.
I don't advertise for anybody.
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=9008&zenid=e05ea4721d32d7a4c9e6a1fef6cffc14
Cheapest I found so far from a Reputable dealer, but you may want to try your hand.
Now you're going to need a Service Manual. See how to correctly disassemble the Display Assembly, to replace the LCD screen.
The Acer Aspire 6930-6771 Notebook PC is one of the Aspire 6930 series.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
These service manuals are free to download, although donations are accepted.
(Just what I read)
Go down to the second Aspire heading. The one that begins with Aspire 1200.
Now go down to line 8. The one that begins with 5738GZ.
Go across, and left-click on > 6930
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
(I would recommend upgrading to Adobe Reader 9 if you do not have it. It's free)
After you click you won't see anything happening for a few seconds. Then the first page pops up.
Took approximately 8 seconds before the first page popped up for me.
It also takes additional time for the file to fully download.
Took a total of 85 seconds in all for the file to fully download for me.
I'm using a medium speed DSL connection.
Advise let the file download all the way before looking through it.
In the Bookmarks menu to the left, click on the + sign next to >
Machine Disassembly and Replacement
Now click on the + sign next to Main Unit Disassembly Process
Finally scroll down, and click on Removing the Switch Cover.
Page 76 in the PDF page number box at the top.
The actual page number is 66)
The last page you will finish with is Page 84 (PDF page number. Actual page number is 74)
A) You have to remove ALL power to the laptop First.
Remove the AC adapter (Charger) and Battery.
B) Observe Anti-Static Precautions.
Cannot stress this enough. If you have an ESD wrist strap available, use it. Connect the alligator clip to a good ground. If not, suggest you buy one, and wear it. Average cost is $3 to $6 ,for an economical one that will do the job just fine. Available in a multitude of stores, and online. (Electro Static Discharge)
Example;
http://www.amazon.com/Cables-Unlimited-ACC-1400-Static-Grounding/dp/B000EDMPQK
(If you look they have new ones available for $3.50. Not advertising for this people. Just one example)
C) Use a multi-compartment container for the various screws you will remove. Mark the compartments for the various screws you will remove.
You DO NOT want to mix those screws up. Some look VERY similar to others, but they Aren't.
You can use a clean egg carton in a pinch. Label each egg holder.
D) The Switch Cover has to come off first. There's 10 securing screws on accessed from the bottom.
Laptop open, DO NOT lift straight up on the Switch Cover. There are cables attached.
(Just in case you are not aware. You can enlarge the view on a PDF file. Go to the top header, and click on the Zoom In icon. ( + )
E) Remove the Power Board (It's a circuit board)
One connector on the cable for the Power Board is a ZIF connector.
(Zero Insertion Force)
These connectors Do Not come all the way apart. They just spread open.
This action unlocks the connector, and allows a Flat Flex Cable to be removed.
The connector is shaped like a fat T, with small tabs being the top of the T.
These small tabs, (One on each side) are eased towards the LCD screen.
The ZIF connector unlocks allowing you to remove a flat flex cable.
Just the flat cable. There will be no connector attached to it.
To expound;
http://www.youtube.com/watch?v=RblDBWRFB7o&feature=fvw
At 1:18 he's opening a ZIF connector, and removing a flat flex cable.
F) Remove the Keyboard. (Another ZIF connector is used)
G) Remove the Speaker Module
H) Remove the Antenna Cables
I) Finally remove the LCD Assembly.
I would like you to now go to the Bookmark menu, and close Machine Disassembly and Replacement.
Click on the Minus sign ( - )
Scroll down to the heading > FRU (Field Replacement Unit) List, and click on the + sign to the left.
Now click right on > LCD Module
This shows you an exploded illustration of the Display Assembly.
Gives you an idea of how the parts fit together, how they come apart, and the names.
If you wanted to you could print this off.
Now close this section, (Click on the - sign), and open Machine Disassembly and Replacement once more.
Go down to where it states LCD Module Disassembly Process, and click right on it.
Follow the next few page to disassemble the Display Assembly.
Then reverse with the new LCD screen installed.
Do I think you can do it?
ABSOLUTELY
If you have problems ANYWHERE along the way, come back here, and post it/them in a Comment.
We'll walk through it together.
Regards,
joecoolvette
Posted on Nov 10, 2010
How do i fix the screen on a dell inspiron 1501
the LCD Display has been cracked, there is no way to fix this without replacing the LCD display which in some cases is as expensive as a new laptop. I'd suggest taking it to a screen repair professional and getting a quote on a replacement screen and compare that with the price of a new laptop.
Nov 07, 2013 | Computers & Internet
LCD HELP!
When you go to this WEB site foe LCD screen parts, just enter the make and model of your laptop.
LCD screens and Inverterswww.lcdparts.net
Dec 29, 2011 | HP Pavilion Computers & Internet
The screen on my lg 42pc1da tv is cracked is it cost efective to repair or replace the tv
That's a tough one to answer with constantly changing prices, and different prices in different areas, but in most cases, a plasma screen is more expensive to replace than the entire unit (especially if you move to LCD or another technology).
You'll have to call around your area and see what places quote you for a new TV and what shops will charge to get you a new screen.
Mar 19, 2011 | LG 42PC1DA 42 in. Plasma HDTV
Cracked screen, black patches, rippled screen
Hi in this situation you should change the screen once it is crack, and if you still see the black part on the screen you can adjust the display using the hardware control management
if you please with my answer give me a vote thank you hristol173
Mar 29, 2010 | Dell Inspiron E1405 Notebook
Broken screen on 42'' LCD Vizio TV, how much to repair?
If you ave cracked the plasma panel it may be very expensive to replace as the plasma panel is a very expnsive spare part, even for us who get trade prices on things like that. The cheapest way to find out the cost is to deal with the authorised repair agent as they are the ones who get trade prices on the spare parts and items. I hope this helps. Good Luck.
Dec 05, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Cracked screen
Unfortunately if the screen is cracked the only remedy is to have it replaced which will be expensive, therefore it might be worth considering a new TV
Oct 28, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Cracked screen
probably not but there are some brands that will interchange. Problem is the cost to do so will be more than buying a new one
Aug 05, 2009 | Televison & Video
My tv screen is cracked is their a way and a place i can buy one and relpace it or will it be cheaper to just buy a new one!
The screen is very expensive to buy or hard to find, with the prices of these TVs lately it's cheaper to buy a new one.
Hope this helps.
Jul 02, 2009 | Sanyo DP26648-R 26 in. LCD TV
Acer 6920 LCD Screen damaged
The screen is impossible to repair if its cracked. Getting a new LCD isn't that expensive but only if you know how to replace it. Getting one from manufacturer is around 130. but there is an ebay link on the bottom you can get one for 70 or so with shipping.
This link shows you how to replace a LCD screen. even tho its not your model but is very close to how yours look.
http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-acer-aspire-3620-laptop/
This is the link to a new LCD screen for your laptop.
http://cgi.ebay.com/NEW-ACER-ASPIRE-6920-LAPTOP-LCD-SCREEN-16-WXGA-GLOSSY_W0QQitemZ350199312405QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5189817015&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A15%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
May 12, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 6930-6771 Laptop Logo
171 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
