What is an UTI? I have a Lexmark C782 color printer
3 Suggested Answers
SOURCE: lexmark c782 ps printer has
hi
If this is the firsttime the error has occurred, try turning the printer off. Let it sit turned off for atleast 20 seconds before powering it back on. If powering the printer offand back on clears the error, continue using the printer but watchit to see if any printhead errors return. If your printer continues todisplay a Printhead Error message, make sure it is plugged straight tothe wall and not through a surge device or power strip. Power strips anduninterrupted power supplies can cause a low amperage problem in your printer.This can trigger a printhead error even if the printer has worked on this surgedevice for months.
If theprinter continues to post a 930 Printhead Error, it thinks thewrong printhead unit is installed. If the printer was recentlyserviced, make sure the correct parts were used. This is especially true if theparts replaced were either the printhead unit or the printer's engine/systemboard. It is in one of these two parts that the printer is detecting theproblem. Note: If you are the personrepairing such a printer, please be aware that parts from different,though similar, printer models may not be compatible with this printer.Also make sure to check the laser cable going from the printer's engine boardto the printhead unit, as it reads that signal. If the printer was notrecently serviced before this error occurred and powering the printer off andon does not help, the printhead unit and possibly the laser cable or theengine/system board to this printer may need to be replaced.
If the printer continues topost a 931 Printhead Error, it thinks there is an error in the signalgoing to the laser or the Hsync part of the printhead assembly. If the printer continues topost a 932 Printhead Error, it thinks there is an Hsync error occurringin the printhead assembly. If the printer continues topost a 933 Printhead Error, it thinks there is a failure in either theHsync signal or with the mirror motor unit of the printhead. If the printer continues topost a 934 Printhead Error, it thinks there is a "lock"failure with the mirror motor assembly within the printhead assembly. If the printer continues topost a 935 Printhead Error, it thinks the mirror motor unit within theprinthead unit cannot reach its operating speed.
If powering the printer offand on does not clear any of these errors and it is alreadyconnected directly to the wall, your printer may require service. Itcould have a defective printhead unit or there might be a problem with theengine board or one of the printhead cables. Note:If you are the person repairing such a printer, check all of the cablesgoing from the printer's engine board to the printhead unit for any damage.Also check the continuity across these cables.
Posted on May 31, 2011
Will the toner out of a C760 work in a C782
Color Laser Toner Cartridge is compatible with Lexmark X762E, X762, so it will not work in C782
Lucas
Jul 07, 2011 | Lexmark C750, C752, C760, C762, C770,...
Have a lexmark c782 and it says it is calibrating but it wont stop what should we do
Check the toners, sometimes one of the toners are bad and the chip on the cartridge is not good..
-Techlex-
May 09, 2011 | Lexmark C750, C752, C760, C762, C770,...
I have a lexmark c782 office printer that is showing a code of 942.05 service yellow tmc sensor what does this me
The error indicates either a defective yellow cartridge metering cycle or a sensor problem that usually requires service. But you can try replacing the yellow cartridge first. If problem continues, I recommend you contact Lexmark technical support or your authorized service provider for further assistance. Thanks.
Aug 20, 2010 | Lexmark C782N COL LASERPR 25PPM 1200DPI...
STREAK ON ITU OF LEXMARK C782
The only thing that helps is replacing the ITU.
Jul 09, 2010 | Lexmark C782dn Laser Printer
My lexmark c782 keeps coming up 100.01 ITU error. Please help.
That usually means that the intermediate transfer unit(ITU) is defective but try these troubleshooting steps found in the Lexmark website. Just go to this link: http://bit.ly/dzs6o1. Follow the instructions but if all else fails, I suggest you contact Lexmark Technical Support.
May 04, 2010 | Lexmark C782N Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
