Question about Konica Minolta bizhub 350 All-In-One Laser Printer
We are getting the message "have the image transfer belt unit replaced soon." We ordered the image transfer belt unit, but it came with no instructions. Is this something where we have to unscrew the back of the printer? If you cannot provided a picture how-to, can someone explain it to us step by step? Thanks in advance for your assistance.
  • Konica Minolta Master
  • 11,800 Answers
You should better get the service manual and follow it to the letter. You can find it here for free
http://www.eserviceinfo.com/downloadsm/22178/konica-minolta_bizhub%20c350.html
Posted on Nov 10, 2010
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
Tip
I did this. When I place the imaging unit back into the printer. I got a message...
If your printer prints like this:
87192f1.jpgThis is because the developer blade for the black toner needs to be cleaned. The developer blade meters the right amount of toner that is deposited onto the drum which ultimately end up on the paper to create the image. What happens is over time, as the printer is being used, toner starts to build up a film on to the developer blade. This film get thicker and thicker reducing the amount of toner from the developer. When this occurs, the image on the paper will look faint show vertical white streaks. This can occur on any or all of the four toner developers in the imaging unit. Below describes how you can clean the developer blade.
  1. Open front panel.
  2. Remove the imaging unit by pulling green tab.
  3. Cover the green imaging drum with a towel.
  4. Remove screw from the left arm, it is located on the top left of the drum.b931d8c.jpg
  5. Remove the waste toner tank.
  6. Remove screw on right side attached to the waste toner sump arm. 9cc6cc9.jpg
  7. Pull the sump arm to the right and upwards to dislodge it.
  8. Pull the left arm away from the developer section. The arm is recessed into the developer section and will require some force to unseat it.
  9. With both arms free, pull the drum back to separate the drum from the developers. Do this carefully, there is a spring that sits on top of the yellow developer that may fly off.
  10. The drum is connected to the developer assembly with some wires on the lower left side. Swing the drum to the left carefully to avoid damaging the wires.233e6b6.jpg
  11. With the drum out of the way, side each developer cartridge out for cleaning. Don’t tip the developer cartridge hole down, since this will allow toner to spill out.0b1b92d.jpg
  12. The developers are cleaned using the same process. Remove the 5 screws that hold the plate down. Two screws hold a z shaped plates, remove them with the screws.
  13. When the screws are removed, lift the plate up and flip it upside down to expose the developer blade.
  14. The bottom side of the plate is the developer blade. It is the part of the plate that touches the developer roller. The developer blade is a thin metal strip with a 90 degree bend. It is the outside corner of this bend is where the toner builds up preventing toner to reach the image on the paper. By using a cleaning tool such as a knife or one of the z shaped plates, very very gently scrape the developer blade from one side to the other. Then change the angle that you hold your tool to get the blade edge clean. You will need several passes with your tool to ensure that the entire edge of the blade is clean of toner. You will know when you are done when the blade edge gleams and you tool will glide freely as you move back and forth down the blade.b57c9e0.jpg
  15. Reassemble the plate/developer blade back to the developer cartridge. Reinstall the middle screw and the two back screws first. There is some foam at the ends of the rollers. Using a knife or toothpick, carefully move the foam in such a way that it does not get trapped between the developer blade and the roller. Once the foam is out of the way and the blade is seated, then replace the Z plates and screws.a1c9ca4.jpg
  16. Clean the other developer blades using the same process. Once all the developer cartridges are clean, reinstall the cartridges in to the developer assembly. Don’t forget to reinstall the spring on top of the yellow cartridge.
  17. Align the feet at the bottom of the drum to the holes on the developer assembly. Press the left arm back into it’s position on the developer assembly. This will require some force to reseat it.
  18. Reseat the right arm back into it position, then reinstall the screws back into the left and right arms. Reattach the waste toner tank and reinstall the imaging unit back into the printer, and close the front panel.
  19. Run a couple of test prints to see if the streaks are gone.
  20. If the streaks are still there, You could try cleaning the blades again, it could be that the blades were not cleaned enough.
  21. If the blades or drum are damaged in the cleaning process, then you will need to get a new imaging unit.
on Sep 30, 2010 | Samsung CLP 300 Laser Printer
How to clear notification transfer roller needs to be replaced soon.
1. Touch Menu.
2. Touch [Counter].
3. Touch [Display Keypad].
4. Press the following keys in this order.; Stop -> 0 -> 0 -> Stop -> 0 -> 1
5. Enter the CE password and touch [END]. (IF required)
6. Counter
7. Life
8. Transfer Roller Clear
Nov 19, 2015 | Genuine Konica Minolta Konica Minolta...
My machine tells me that the Transfer Unit has to be replaced.
http://www.konicaminoltaonline.co.uk/index.php?page=shop.product_details&flypage=vmj_ritz.tpl&product_id=551&category_id=147&option=com_virtuemart&Itemid=82
http://www.copiersupplystore.com/ProductModels/KONICA+MINOLTA/BIZHUB+C250.aspx
http://www.supplydepot.com/Amazing/ItemDesc.asp?IC=KON4038R74300
Jul 10, 2012 | Konica Minolta bizhub C250 All-In-One...
Problem with a Xerox Docucolor 3535 Copier
Reset the tranfer unit counter,and change the transfer unit chip fuse(located in transfer unit contact house)
Apr 12, 2012 | Xerox DocuColor 3535 Copier
I've getting the "Replace transfer roller" message
  1. reset count in printer menu
  2. clean the optical sensor
Mar 15, 2011 | Dell 5100cn Laser Printer
Re: Samsung Printer CLX3175FN -- receiving message "Replace imaging unit soon." I've read other expert replies but am still missing some information. Can I replace the unit myself? How do I do...
Nancy, Your imaging unit has a limited lifecycle. Documentation states that it can make 24,000 B&W pages and 6,000 color. The message is telling you that you are getting close to that limit. Eventually you printer will stop printing, and your messahe will state "Replace imaging unit". This can be done by you. It is very easy to do. The imaging unit is fairly expensive: around $150 or more depending on the merchant and shipping charges.
Drew
Feb 16, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Error message 457 on my ricoh af4106 copier
Hi!
This information might help you.
SC457 Position error for the image transfer belt’s cleaning unit
- Timing & Condition
• When the belt cleaning section touches the image transfer belt, but the belt cleaning sensor signal remains LOW.
• When the belt cleaning section releases from the image transfer belt, but the belt cleaning sensor remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning shift clutch
• Defective drum peripheral component motor
• Defective I/O control board
• Defective main control board
1. Pull out and re-insert the image transfer
belt unit.
2. Clean the image transfer belt cleaning H.P. sensor.
3. Replace the sensor. (Input Check: 5-803- 012)
4. Replace the belt cleaning shift clutch. (Output Check: SP5-804-036)
5. Replace the drum peripheral component motor.
6. Replace the I/O control board.
7. Replace the main control board. [Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O
control board
Sep 19, 2009 | Office Equipment & Supplies
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
96 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
