Question about Radio Communications
Sirius 10 I have a sirius 10. I recently put in a new battery. I than charged it with the computer. The charged new battery only lasted 75 minutes. Prior to that the charge would last for two hours. please advise
  • 27 Answers
THE battery MUST be charged with the correct charger. Assuming that is the case new batteries need to be cycled a few times before they come good...Also you MUST use the exact same spec battery in mAH. if you are using ni-cads they need to be fully discharged to a safe low level before recharging as they suffer from memory effect...ni-mh type the need to be charge cycled a few times before they come good. There are problems with all types of rechargable batteries...Makers have still not reached perfection..never leave a radio always connected
to the ac line , this will stagnate the battery/cells causing problems you must use your device on battery power in order to cycle the same. This is the main reason why laptop batteries have a short life.
flyingfox@people.net.au
Posted on Jun 23, 2008
I HAVE SONY WALKMAN NWD-B103F- BATTERY DOES NOT LAST FOR 10 MINUTES-AFTER CHARGING ON COMPUTER
The battery does not hold charge. It is weak. Replace it with same type number. Brand name of the battery isn't a matter, check its type number printed on it.
Jul 09, 2016 | Sony Walkman Audio Players & Recorders
After fully charged battery power lasted about 20 minutes.
Since it's brand new, return it. You didn't say what type of tablet it is, but they should last for many hours on a charge.
Oct 02, 2015 | Tablets & eReaders
Rover 75 forum
the car as a wire connected to the chassis and he is descharging the battery. you have to go to a car electrician and look wall the cables to see where he is not isolated.
Mar 11, 2014 | Cars & Trucks
How long does the battery life last on a stiletto 10 SL10PK1 of how long i can use it before i have to charge it again
My stilleto lasts about 1 hour, but it's been used for a while now. I would reccomend buying a new Li-Ion batery if you absolutely need long battery life.
Dec 30, 2010 | Directed Electronics Stiletto 10 SL10PK1...
How can I check my alternator on my 1999 Ford Ranger. The Ranger died on the side of the road today, and all that showed was to check the battery prior for about 10 minutes.
well...whenever the battery light comes on in a vehicle its almost always a charging problem,i would suggest replacing the alternator and charging the battery before starting it,alternators were meant to keep a battery charged NOT charge a battery, hope this helps
Oct 12, 2010 | 1999 Ford Ranger SuperCab
Compaq Presario v2000 notebook reduced battery life
you may try:
1) check the battery alarm at windows power managment, to set 5-10% alarm level.
2) discharge the battery to the empty then charge longer time, you need monitoring how long it charged (see charge lights change), need to change new one if charging time much less then before(less then 10-20 minutes)..
3) plug-in AC adapter monitoring charging current,
this step you need a current meter to make a series connection in the circuite, the battery is over life cycle if the current less then 500mA.
May 02, 2009 | Computers & Internet
SL10 - lock up
I had the same problem...... SL10 is overheating the BGA chip there is 2 of them so you need to open your radio and install some heatsink tape but if you listening at home just put a fan on it so it wont overheat .......................
May 15, 2008 | Sirius Stiletto 2 Portable Satellite Radio...
Stiletto constantly powering off
Solution is downloading the sirius recovery software from sirius.com My radio would not connect to my computer because it would not fully turn on. disconnect the battery. Hold the DISPLAY and OPTIONS button on the radio face when reconnecting battery. Connect to PC and Sirius Recovery Program will pop up. Run program, takes approx 10 to 15 min and radio works good as new.
RUNNING PROGRAM WILL ERASE YOUR LIBRARY ON YOUR RADIO....
Dec 26, 2007 | Sirius STILETTO 100 MP3 Player
SIRIUS S50
When the S50 is place overnight in the Home Base Unit or connected to the AC Adapter it will not charge battery completely.
The I have purchased two new batteries and both have not been properly charge by the units mentioned.
The charge provided to the Battery is of short duration 10 or 15 minutes maximum.
I have telephoned Sirius Company and their response was that they don’t have repair service for this unit any longer.
Nov 03, 2007 | Sirius Satellite Radio S50-TK1 Satellite...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
