Question about Xerox CopyCentre C118 Copier
Front door will not close - Xerox CopyCentre C118 Copier
    President:
  • 2,072 Answers
Make sure the toner and drum unit are installed properly.
The other likely thing is one of the tabs on the inner cover is not seated properly.
Posted on Nov 10, 2010
GP215 Canon Photocopier says close front door when its closed!
THIS PROBLEM DUE TO YOUR COMPOSITE POWER SUPPLY PROBLEM
Nov 28, 2013 | Office Equipment & Supplies
Close front door message when front door is already closed
I am having the same problem... did you manage to resolve it? Let me know
May 16, 2013 | Saeco Xelsis Digital ID Automatic Espresso...
Hp cp2025 error reads "front door open" when front door is closed
pront door liver switch open not work it ,or it displace.you should check it or service need
Sep 12, 2012 | HP Laserjet Cp2025n Printer
Kyocera Mita KM-2530 error close front coveR
The front door switch or actuator is broken or the door may be warped .Have you tried putting pressure on the front cover? as this may help to indicate if the switch is faulty.
Sep 10, 2012 | Kyocera Mita KM-2530 Laser Printer
Doors where hard to close without the weather door seals. But with them on they will not close. The body plates more but not enuff on the cab? I need HELP.
Hi!!
The doors Hinges or Striker need to be adjusted to make up for the weatherstrip thickness. To do this, loosen the hinge-to-door bolts for lateral adjustment only. Loosen the hinge-to-body bolts for both lateral and vertical adjustment.
REAR DOORS
BEFORE YOU START:
  • Determine which hinge bolts are to be loosened and back them out just enough to allow movement.
  • To move the door safely, use a padded pry bar. When the door is in the proper position, tighten the bolts to 19-25 ft. lbs. (26-35 Nm) and check the door operation. There should be no binding or interference when the door is closed and opened.
  • Door closing adjustment can also be affected by the position of the lock striker plate. Loosen the striker plate bolts and move the striker plate just enough to permit proper closing and locking of the door.
TO ADJUST ON A: F-150, F-250, Expedition and Navigator
HORIZONTAL AND VERTICAL ADJUSTMENT
  • Loosen the front door hinge to front door bolts.
  • Adjust the front door alignment.
  • Tighten the front door hinge to front door bolts to 19-25 ft. lbs. (26-35 Nm).
FRONT DOOR FORE AND AFT ADJUSTMENT Check the rear door hinge adjustment before adjusting the front door hinge.
  • Remove the front fender.
  • Loosen the front door hinge to body bolts.
  • Adjust the front door alignment to specification.
  • Tighten the front door hinge to body bolts.
  • Install the front fender.
1999-00 F-Super Duty Models
DOOR ADJUSTMENT The following procedure is for performing fore, aft, up, down and tilt adjustments.
  • Remove the door striker.
  • Loosen the bolts only enough to allow for slight door movement.
  • Carefully close and adjust the door until flush with the adjacent body panels.
  • Carefully open the door and tighten the bolts.
  • Re-install and adjust the door striker.
  • Check the door for proper operation and alignment.
STRIKER ADJUSTMENT Mark the position of the striker before loosening.
  • Loosen the striker retaining bolts.
  • Adjust the door striker and tighten the striker retaining bolts.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 09, 2010 | Ford F Cars & Trucks
My lamp "paper" blinkikg brother hl-2030
Remove the Toner Drum unit and look for a little blue tab. Slide it back and forth a couple of times to clean a corona wire and see if that helps.If the problem still exists, you may try this 2nd option.
> the front door. There is something wrong with the front door, or the mechanisms that signal that it is closed. Closing the front door (the one that you open to pull out the toner and drum) all the way to where it snaps into place then the paper light flashes red. However closing the front door to the point where the "ready" light comes on (don't snap the door into place, just close it and let it rest in place without snapping it closed) and the printer prints fine, pulls paper from the tray and prints like it should.
So give it a try, don't snap the front door all the way closed to where it snaps closed, just close the door to where it's resting closed to where the ready light comes on and see if this helps you.
Nov 20, 2010 | Brother HL-2040 Laser Printer
Canon machine message front cover is close but
there are switch behind the front door that are activated by the front cover. you may have a broken or missing actruator pin on the front door. look very carefully on the door for anything that seems to be missing. if ther is just use a piece of paper to actuate the switch. jaime
Jul 15, 2010 | Canon imageRUNNER 400S Copier
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Jul 06, 2009 | Canon imageRUNNER 400S Copier
"Close the front cover" sign even the door is closed already
On Canon copiers the close front door can be caused by other doors besides the front door.Try the fuser door an the left and the vertical transport door.Good Luck
Mar 27, 2009 | Canon imageRUNNER 400S Copier
Leaking....front door won't close
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
Mar 28, 2007 | Kenmore 43042 Front Load Washer
Xerox CopyCentre C118 Copier Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
