Question about Kalorik 35 SS Slow Cooker 1
Low , high settings reversed ?????? - Kalorik 35 SS Slow Cooker 1
I have a rival 3215 with no temp control. Is it a "low, high, or warm" temperature setting?
There is one setting for this unit which is the same as low (200) degrees on those with high low
Mar 28, 2011 | Rival 3215-WN 1.5-Quart
Hi the crockpot controls have erased the settings could you tell me what is hi...low or heat
Most crockpots have only two settings: low and high/heat. Use the high/heat setting for dishes that will cook in 2-4 hours. The low setting is for your "all day" cooking, typically 6-8 hours.
Hope this helps.
Mar 03, 2011 | Hamilton Beach 33141
I have Ronson slow cooker with no manual, it has settings 1,2 qnd auto. Which is high and low, and what does auto setting do>
I also have a Ronson slow cooker.
Instructions from the book read as follows:
- On setting 1 (low), the slow cooker can operate all day and night if required.
- When set to 2 (high), it is very much like a covered pot on the stove. Foods will cook in half the time required for 1 (low).
- When set to auto, the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature, then switches to 1 (low) and maintains a constant slow cooking temperature. Auto is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
I always use the auto setting, unless I don't have as much time, and will then use setting 2.
Sep 15, 2010 | Crock Pots & Slow Cookers
No manual for my old Crock Watcher by Proctor Silex
The auto setting cooks on high for the first hour, then adjusts the setting to low for the remaining cooking time.
Auto Shift allows the slow cooker to heat up to high and then internally shift down to low, so it gives more flexibility in cooking time. Example: A certain recipe may take 4 hours on high, 5-6 hours on Auto Shift and 7-8 hours on Low.
Oct 19, 2009 | Crock Pots & Slow Cookers
Which setting is high, which is low?
4 hr setting is the highest setting then as hours go up setting goes down. Hope that helps.
Dec 14, 2008 | Rival 38601 Smart Pot 6-Quart
How do I get both 8 hours time and high setting on this crockpot?
I got it on high for 1 hour and then reset it to low for 7 more hours and everything appears to be fine. I suspect that this crock pot runs at a little higher temperature. The *low* setting seems as hot as my older crockpot on high...... With this crock pot - set the hours while turned off with the right button and then turn it on. You may have to play with it several times to get the proper heat setting. As I said, I could only keep on it *high* for 1 hour.
Nov 22, 2008 | CorningWare SC60 Slow Cooker
Corningware slow cooker 6qt
If you choose the auto selection the slow cooker will cook for three hours on high then will automatically reduce to the low setting.
Aug 22, 2008 | Crock Pots & Slow Cookers
Overcooks
The older crocks did not seem to get as hot as the ones form the past 10 years. I have an old blue and white one that I use only to make yogurt, since it is not as hot. I do not believe you can adjust the newer ones, just use the low setting. Good luck.
Jun 21, 2017 | Rival 38601 Smart Pot 6-Quart
Kalorik 35 SS Slow Cooker 1 Logo
139 people viewed this question
Top Kalorik Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Kalorik Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
