Question about Sharp Office Equipment & Supplies
Al1540cs All copies come out about 75% of normal size reguardlss of the size setting selected
  • Tanned Nov 11, 2010
    No, it's not connected to a computer. Any other ideas?
    yes, tried that.
    Genius:
  • 1,280 Answers
I have limited info on your problem so I am only offering this as a suggestion to try....There usually 2 ways that size is selected ....one on your computer and the other on the copier. If you have a computer connected to your printer check there first and be sure it is set on 100% in the print function. best wishes...
Posted on Nov 11, 2010
  • Daryl Nash
    Daryl Nash Nov 11, 2010
    This may sound silly but have you tried unplugging your printer then plugging it back it then trying to print a document? I am hoping if you do that it will return to factory settings.
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
How do you enlarge on the HP309A SERIES
  1. Use the following guidelines to determine which setting to choose:
    • Copying an original to letter or A4 paper : Choose Fit to Page , or choose Full Page 91% to prevent unwanted cropping.
    • Copying a legal-size document to letter paper : Choose Legal > Ltr 72% .
    • Copying a photo to full-size paper : Choose Fill Entire Page .
    • Copying to a custom size : Choose Custom 100% , use the Up or Down arrow buttons (c01314741.gif ) to reduce or enlarge the size of the copy, and then press OK .
  2. On the LCD screen, choose Copy from the options (use the arrow buttons) and press OK .
  3. Press the Settings button (the button below the Home button) twice, to access the Copy Settings menu.
  4. Select Size and press OK to access the copy size options.
  5. In the Copy menu, use the arrow buttons to select the appropriate size settings. Press OK to continue.
  6. Press Start Copy Color or Start Copy Black .
Mar 05, 2011 | HP Photosmart Premium C309A All-In-One...
I need tires but don't know the size
Usually the factory recommended tire size is listed on the door tag. There is also a size on the tire it self. Yours should be something like 255/75/16. If there's an "R" in there somewhere it stands for radial. Likewise "LT" stands for Light Truck, "A/T" for all terrain, "MS" Mud and snow, etc... Just check the door tag and the side of the tire as there are many different sizes. The first set of numbers is the height of the tire. The second set of numbers is the width of the tire: 255/75...means that the width is 75% of the height (255) as an example. The last digits are the rim size. I hope I've helped, if so please rate my assistance and leave a testimonial. Thanks for using Fixya.
Feb 12, 2011 | 1999 Ford Expedition
How do I access the menu/control panel?
MFP and scanner settings can be changed several ways: through the MFP control panel, the software application in use,
the print driver, MarkVision™ Professional, or the Web pages. Settings changed from the application or print driver apply
only to the job being sent to the MFP.
Changes made to print, fax, copy, and e-mail settings from an application override changes made from the control panel.
If a setting cannot be changed from the application, use the MFP control panel, MarkVision Professional, or the Web pages.
Changing a setting from the MFP control panel, MarkVision Professional, or the Web pages makes that setting the user
default.
Menus (A key is shown on the button.) Touch to access the menus. These menus are only
available when the MFP is in the Ready state.
The Menus button is on a gray bar called the navigation
bar. The bar contains other buttons described as follows.
Understanding the copy screens and options
Copy From:
Opens a screen where you can enter the size of the documents you are going to copy.
Touching any of the paper size icons on the follow-on screen will make that your selection and return you to the
Copy Options Screen.
When Original Size is set to Mixed Sizes, you can scan different size original documents (letter and legal size
pages). They will be scaled automatically to fit the selected output media size.
Copy To: Opens a screen where you can enter the size and type of paper on which your copies will be printed.
If the size settings for Copy From and Copy To are different, the MFP will automatically adjust the Scale setting to
accommodate the difference.
If you have a special type or size of paper that you'd like to copy onto that is not normally in the MFP paper trays,
you can select MP Feeder, and manually send the type of paper you want through the MP feeder.
When using Auto Match, the MFP will match the size of the original document as specified in the Copy From box.
If a matching paper size is not loaded in one of the paper trays, the MFP will scale the copy to fit loaded media.
Scale: Creates an image from your copy that is proportionally scaled anywhere between 25% and 400%. Scale can also be
set for you automatically.
When you want to copy from one size of paper to another, such as legal size to letter size, setting your Copy From
and Copy To paper sizes will automatically change the scale to keep all the original document information on your
copy.
Touching the arrow to the left lowers the value by 1%; touching the arrow to the right increases the value by 1%.
Holding your finger on an arrow makes a continuous increment.
Holding your finger on an arrow for two seconds causes the pace of the change to accelerate.
************************Darkness: Adjusts how light or dark your copies will turn out in relation to the original document.****************** here is the link to the full pdf manual for your unit: http://www.lexmark.com/publications/pdfs/2007/x644e/en/ug.pdf#xml=http://support.lexmark.com/lexmark/index?page=answeropen&segment=SUPPORT&userlocale=EN_US&locale=en&type=open&searchid=1270220491739&answerid=16777216&iqaction=6&url=http%3A%2F%2Fwww.lexmark.com%2Fpublications%2Fpdfs%2F2007%2Fx644e%2Fen%2Fug.pdf&productCode=&highlightinfo=106955230,537,548
Apr 02, 2010 | Lexmark X 646e MFP - multifunction ( B/W )...
Hp laserjet 3055 scans larger than print area
When you place a document for scan, you must select the portion you want to be scanned.
You must also set the resolution which is set to 300 by default, if you want a actual size then set the resolution to 75, which is 3% larger then actual image.
It will reduce size in KB or MB of your image and it will be exact size.
Similarly, when you want to print, you must select option "Exact Fit" and print your document.
Everything will be normal.
Cheers
Nov 06, 2009 | HP LaserJet 3055 All-In-One Printer
How to do copies,ie what buttons do i press
Making a Single Copy
Place the original face down in the ADF.
2 Press Copy/Help twice.
To cancel, press Stop.
Do NOT pull on the paper while copying is in progress.
Copy Options: Single or Multiple Copies,
Reduce/Enlarge, Sort/Stack
You can choose additional copy options. First, you can select the number of copies. Next, you can
choose whether multiple copies will be STACKED (all copies of page 1, then all copies of page 2, etc.)
or SORTED (collated). Finally, you can choose an enlargement or reduction ratio. To automatically
reduce the copy to the paper size you have set for the paper tray, select AUTO. To reduce the copy by
a fixed percentage, choose 93%, 87%, 75% or 50%. Or, to enlarge the copy, select 150%, 125% or
120%. To copy a document at its original size, select 100%.
1 Place the original face down in the ADF.
2 Press Copy/Help.
3 Enter the number of copies you want (1-99).
For example: Press 9 for nine copies.
To start copying now, press Copy/Help.
If you would like to select additional copy options, like
SORT, ENLARGE or REDUCE, press Menu/Set.
Oct 02, 2009 | Brother FAX-T74 Plain Paper Thermal...
Canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Jul 27, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Printing envelopes
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
Jun 29, 2009 | Minolta bizhub 200 All-In-One Printer
How to scan legal documents on Canon MF5770?
This information is available on CANON WEBSITE
Unfortunately, they imbed the text in javascript, and there is no way to link or c/p the information here. Try THIS HYPERLINK to take you to the exact page.
Enter your model # in "search knowledgebase" at the above link.
Type PAPER SIZE
You will have a clickable link that says How do I specify paper Size and Type.
Instructions will appear.... starting like this... (i used C/P, and it may not come out slearly after I submit this answer)
Issue: How do I specify the paper size and type?
Solution: Specifying the Paper Size and Type
  • When making copies on LTR-size paper after having continuously copied on paper smaller than LTR-size paper, the copies may be dirty. To prevent copies from being dirty, wait about 1 minute before making copies.
  • The paper in the multi-purpose feeder is fed prior to the paper in the cassette.
  • The settings changed in the Menu do not return automatically to the settings you set previously. Change to the previous settings again if necessary.
  • When making copies of a small size or heavy paper*, etc., the copy speed may be slightly slower than usual.
    *The paper type should be selected in the Menu.
  • If you intend to make a copy and print with a thermal transfer printer using the same sheet of paper, make the copy first. Failure to do so may make copies dirty or cause a paper jam.
  • When copying onto transparencies, remove each transparency from the output tray as it is output.
  1. Press <Menu>.
  1. Press <Menu>.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
HP6110 default paper size for copying
Yes, manually set your paper size using A4 or begin with A4 and leave it on auto (default) it will try and match it.
Instructions...
  • Press Menu
  • Option 1
  • Option 2
  • Select copy Setup
  • Select paper size
  • Hit the black triangle until the size you want displays
  • Then hit enter.
Dec 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
20 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
