Question about Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
Magnavox model 32md25id/37 wont power on? have unplugged main power cord and waited 2-5 minutes and replugged in but to no avail......any help?
  • 13 Answers
SOURCE: 32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Posted on Dec 26, 2008
SOURCE: magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Posted on Mar 27, 2009
  • 4 Answers
SOURCE: Magnavox model 32MF23ID/37 42
Just use a core from a old comouter it is the same thing
Posted on Aug 24, 2009
  • 6 Answers
SOURCE: My Magnavox plasma screen tv, model number:
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Posted on Jan 03, 2010
jhinsincity
  • 616 Answers
SOURCE: My Philips Magnavox 50MF231D/37 won't turn on.
The tv needs the power supply serviced, most likely ( 2) 3300u 10v capacitors. (they can be spotted because they will bulge on top) best to have a pro replace them, however since I am telling you what the problem is try to negotiate a fair price - no more than $150 dollars. you can try to do it yourself but you will need soldering equipment and some level of electronics knowledge. good luck.
Posted on Sep 14, 2010
Magnavox 42MF439B TV stuck in stand by
First thing you can try is:
1. Unplug it from the power cord and wait a few minutes.
2. Turn it on (when it's still unplugged from power)
3. Plug it in power and try to turn it on again
Let me know if this fixes your problem or we need to look for other solutions.
Jan 05, 2014 | SNK Magnavox 42MF438B/27 42 in. LCD TV
How to reset my magnavox flat screen tv
Unplug the tV from AC amins socket, and replug it after some time, say 5 minutes or so. This must make a hard reset to your Maganvox.
Apr 26, 2012 | Philips Magnavox 42MF521D/37 Television
Can't get online
Try power cycling the router:
1. unplug the power cord from the router
2. unplug the power cord from the modem
3. replug the power cord to the modem
4. replug the power cord to the router
for best results, wait approx. 30 seconds before re powering the devices.
Mar 03, 2011 | Computers & Internet
The magnavox hdtv model number 37mf33id-37 will not come on but the green light flashes above the on /off switch
Tries tv unplug,replug it back like about an hour later.Now the tv should be resetting itself back to the factory setting.The tv now should work again.If not the problems and the causes is the tv power supply board problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 02, 2010 | Philips Televison & Video
Dell 1800mp projectors turns on for a few seconds then turns off and lamp light stays solid orange...what's the problem. New bulb?
Hello
If the Lamp light and power lights are blinking orange, the lamp driver has failed, and the projector will automatically shut down. Unplug the power cord from AC mains wall socket, wait for three minutes and replug and see whether it helos you. If not, contact Dell service center.
OK.
Nov 19, 2010 | Dell 1800MP Projector
My wii has no power at all. ive unplugged and reconnected all the wires put there is still no power, and every thing else in the outlet works
I just had the same problem moments ago, if you unplug the power cord from the wall and the unit and let it sit for a few minutes, then replug it back in, it should come back. Unplugging and plugging back in without waiting won't work, you have to wait 2-5 minutes.
Dec 16, 2009 | Nintendo Wii Console
Copy
- try doing the power cycle.
- unplug the power cord w/o turning off the unit
- wait for about 2 minutes.
- replug the power cord.
- then try to do copy again.
- if still not working, try to press set-up go to tools and clean the printheads. if still not working go to next steps.
- took all the cartirdges out.
- clean the electrical contacts of the cartridges and the carriage with a lint free cloth moisten with an alcohol.
- wait for 30 seconds
- replug the power cord and install the ink cartridges if the printer ask them to install
- try to do a copy
- is still not working
- try to do a reset
- unplug the power cord again
- then press and hold the # and 6 key while the printer is unplug
- and while holding them both replug the power cord
- then do not yet release the two buttons, wait for the printer to start up and if the screen turns off thats the time you will release the two buttons
- then follow the on screen instructions.
Aug 25, 2008 | HP Officejet 6310 All-In-One InkJet...
Tv screen black
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent. If the picture does not return, then you might need the expertise of a repairman.
Jul 01, 2008 | Philips Magnavox 42MF521D/37 Television
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo Logo
230 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
