Question about Bosch 24 in. SHX57C05UC Stainless Steel Built-in Dishwasher
My bosch shx57c05uc is not cleaning my dishes. It leaves food on the plates and does not rinse properly. glasses are spotty I have check rinse aid and reduced soap usage any ideas? I had a repair man just push a few buttons and said it was not using the hot water cycle. but he did not show me how he did it, maybe it needs reset again. any ideas?
  • 677 Answers
SOURCE: Bosch SHX46A dishwasher
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Posted on Apr 10, 2008
codfish124
  • 36 Answers
SOURCE: Dishwashing detergent in rinse aid compartment
not good there is no way to drain it out. you might be able to take the door apart and take off the rinse aid reservoir and clean it out
Posted on Dec 20, 2008
  • 423 Answers
SOURCE: dishes not cleaned
When ever I hear of a dishwasher "suddenly" not cleaning properly, with spots on the glassware and soap not dissolving:
-If the spots are white patches, you can suspect the DW detergent powder. Go buy a name brand of detergent powder and I bet you will see a dramatic improvement. You may need to run a cycle or two with white vinegar added (up to two cups added after the DW starts, fills and begins to wash.)
-If the spots are a film / slime, you should suspect that the heating element. For the dW to be effective cleaning and rinsing clear,the DW needs to raise the water temp during the ~wash~ cycle (after the detergent dispenser has magically opened. After the heating element has been replaced, you will see an immediate improvement.
-If you had reported food debris sticking to dishes, (which you didn't), the first thing to do is clear the holes in the wash arms, then open the sump area , remove the filter assembly and inspect closely with a flashlight to locate blocking debris. (watch out for broken glass!) Inspect the impeller and make sure it is not damaged. If after assembly, the cleaning is still poor, it is time to replace the wash pump / motor assembly.
Good Luck! Ask more questions as needed!
Posted on May 09, 2009
  • 677 Answers
SOURCE: dishwasher Soap scum left on dishes
the problem is hard water. There is a new product out called The Dishwasher Filtration System. It filters the water going into your dishwasher leaving your dishes spot free with every load. It is very affordable and fits right under the sink. You will be amazed how sparkling your dishes look just after one load. You will love this product. Get it at www.dishwasherfilter.com.
Posted on May 13, 2009
dnewcombe1
  • 1564 Answers
SOURCE: I think my Bosch dishwasher might be a "lemon". I
Don't be afraid now, but , what I'n going to tell you works VERY often. Pour two cups of bleach into the washer and let it run a potscrubber cycle. They do this all the time at restaraunts, yes really! Let me know how this turns out. P.S. leave the machine empty when you run it. Thanks, Dana
Posted on Aug 22, 2009
Brand new bosch dishwater does not get dishes clean - food residu
Try the cascade new soap they have been changing the ingredents due to state requirments for the water treatment. also make sure spray arms and jet are free from food particles,also clean soap dispencer,If you want run CLR through dish washer no dishes to clean machine.Thanks
Jul 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
My Bosch dishwasher leaves soap on the dishes and glasses. I wind up rinsing and drying everything over again by hand.
It looks like rinsing is not proper inside the chamber.
Check your water inlet. Clean the strainer attched to it at the machine end.
Apr 11, 2010 | Bosch SHU9915UC Dishwasher
Dishes are not getting clean, leaves food particles
may be problem in final rinse not happening.
1)check the final rinse happening at end of the cycle
2)if not happens clean the solenoid filter.
3)clean the boiler tank.
Jan 06, 2010 | Bosch Integra 800 SHX98M05UC Built-in...
Not rinsing glasses clean
If the glasses are spotty from hard water try a rinse aid like Jet Dry. If they are actually dirty, depending on the brand of DW you may need to rinse them better before putting them in the DW. Not all brands are cerated equally, some do work better then others
Oct 11, 2009 | Dishwashers
Aug 22, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dishes not coming out clean
Check your hot water supply. It should be at least 125 degrees. Are the dishes spotty or still dirty with old food? Try to pre-rinse your dishes before putting them into the dishwasher. You can also run your hot water until it's nice and hot coming from the sink before turning your dishwasher on. If they're spotty, use less or better quality detergent. My guess is going to be water temperature or pressure.
Jul 03, 2009 | KitchenAid Dishwashers
Dishes not cleaned
Mar 30, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Cutlery is cloudy and dirty, some food is dried onto knives and forks. Cups and glasses are cloudy and not clean on inside. Coffee or tea stains are not removed. Plates and soup bowls seem OK , and water...
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
Mar 21, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Not cleaning dishes
Our Bosch does a pretty good job of washing dishes. But we rinse most of the time. Not a hard rinse, but a rinse.
Are both spray bars rotating? You can test by seeing that the bars rotate easily by hand, and also by starting a cycle and opening the door real quick when you hear the spray hit the door.
Make sure the spray bar nozzles are all clear.
Has it ever done a good job of cleaning dishes?
DI you leave a heavy build-up of food on the dishes, and allow it to dry before washing?
Jan 26, 2009 | Bosch SHU5315UC Dishwasher
Not draining properly, leaving film, debris, & soap, draining through air gap
you wont get clean results if loading a dishwasher up with dirty plates, the food debris will circulate around with the water and keep reistating itself on the plates- as it may not get through the filters. try a powder wash with rinse aid topped up and the most important thing is that the salt bottle is topped up. you may also want to check that the spray arms are not all blocked up with debris.
Jun 03, 2007 | GE 24 in. GSD2120C Built-in Dishwasher
Bosch 24 in. SHX57C05UC Stainless Steel Built-in Dishwasher Logo
81 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
