Question about Texas Instruments TI-89 Calculator
The following program can not quit normally
Lbl ad0
input "distance",a
input "time",b
Goto ad0
The program is in a loop always...
when is displayed "speed" the next line order to go the begging and ask again the distance...
you have to include an instruction to quit
Lbl ad0
Input "distance",a
Input "time",b
Title "Again"
DropDown "Repeat?",{"Yes", "No"},a
if a=1
Goto ad0
Posted on Jul 11, 2008
Programming Issue : "Error : Variable or Flash application is locked, protected or archived"
Apparently the variable "a" is archived or locked. Press 2ND VAR-LINK (the subtract key). Find the line containing "a". If there's a little x-like thing to the left then its archived. Press F1 9 to unarchive it. If there's a little padlock to the left then its locked. Press F1 7 to unlock it.
Sep 15, 2012 | Texas Instruments TI-89 Calculator
I receive the error "Missing
Put an EndFor command 2 lines down from the For j,1.n/2 line. Right above y1(p) store p. You'll have to have a 0 store p inserted into the program or, you'll get a circular error. I put mine right under input n. Also where you store 0 in s and v.
Jan 19, 2011 | Texas Instruments TI-89 Calculator
A train increases its normal speed by 12.5 % and reaches its destination 20 minutes earlier. What is the actual time taken? My email id is
You have two variables on the question. That is the Speed of the Train and the actual Time taken.
So you shouold be have two equations to resolve the two variables.
Lets assume the speed to be x and the actual time in minutes to be y.
So the 1st equation,
If the train goes with the actual or the normal speed x the train reaches within the time y.
we know that speed = distance X Time
so X = Distance x Y or
Distance = X/Y ------- 1
Next the 2nd equation.
[{(12.5/100) x X} + X] = Distance x (y-20) or
Distnace = [{(12.5/100) x X} + X] / (y-20) ------ 2
Now you can equate 1 and 2 to get the results.
Nov 22, 2010 | Office Equipment & Supplies
I am trying to graph to evaluate each expression. how could i do it on the calculator(ti-83) a:(f+g)(0) b)(f-g)(-1) c)(fg)(1) (d)(f/g)(3()
Let us see if I understand what you want to do. You have two functions f and g. With f and g you create four functions,
  1. f+g, which you want to evaluate at 0
  2. f-g, which you want to evaluate at -1
  3. f*g, which you want to evaluate at 1
  4. and f/g, which you want to evaluate at 3
If that is not what you intend to do, then I am sorry to I that interpreted incorrectly and you will have to post a comment with more information.
If however I did understand what you want to do, then there is a simple way to achieve this
  1. In the [Y=] function editor, enter Y1 and Y2
  2. In your mind decide which one represents f(x) and which represents g(x), probably f(x)=Y1(x) and g(x)= Y2(x)
  3. Validate each one by pressing [ENTER]
  4. Do not worry about graphing the function.
  5. Press [2nd][QUIT] to return to main calculator screen
  6. Enter a value (for example 5) and store it in variable X; to do so you press 5 [STO->][X,T, theta,n] [ENTER]
  7. To calculate f(x)+g(x) or (f+g)(x) on the command line in main calculator screen
  • Press [VARS][=>][Y-VARS][1:Function][1:Y1][ENTER]. Main calculator screen echoes Y1
  • Press [+]. Screen shows Y1+
  • Press [VARS][=>][Y-VARS][1:Function][1:Y2][ENTER]. Main calculator screen echoes Y1+Y2
  • Press [ENTER] to obtain the value of f+g at X=5
As you can see, if you want a different operation f-g, f*g, or f`/g for a different value of X, you will have to repeat steps 6 and 7.
I am going to show you how to create a small program that will perform all the 4 operations in sequence, each time asking you for the value of X you want to use. If you are not interested, you can ignore what follows. I remain convinced that it will be helpful for other visitors.
Creating a simple program
Press [PRGM]
Use arrow to highlight [NEW]
Press [ENTER]
Screen displays
Name= with alpha cursor blinking
Type in the name, for example FOPG ( meaning F operation G) or anything else. Do not use a keyword (reserved command of the TI84Plus) These are what you find in the [CATALOG].
The top line on each screen capture is inserted by the program editor after you choose the name. The last line of first screen is the the same line as the second line on 2nd screen. It must not be entered. The colon : is supplied by the program editor. It is the beginning of an instruction.
There are only to commands that are repeated here: Disp and Prompt
Disp orders the program to display
  1. a message (what is between the quotation marks) or
  2. the result of a calculation: Y1+Y2, Y1-Y2, Y1*Y2, or Y1/Y2
Prompt X will display X=? and the blinking cursor. You are supposed to enter the desired value of X and press [ENTER].
The Disp and Prompt command are accessed through the command catalog by pressing [2nd][0] (CATALOG) then scrolling along the list of commands to find the one needed. Shortcuts are possible (see below)
How to key in the program steps within the program editor
: Disp "F+G"
Press [2nd][0] (CATALOG) [X^-1](D) [Scroll Down [till...] Disp
Press [ENTER]. Editor shows :Disp
Press [ALPHA] [+] ("). Editor shows :Disp "
Press [ALPHA][COS] (F). Editor shows :Disp "F
Press [+]. Editor shows :Disp "F+
Press [ALPHA][TAN] (G). Editor shows :Disp "F+G
Press [ALPHA][+] (") Editor shows :Disp "F+G"
Press [ENTER] to validate instruction
Calculator inserts a new line :
: Disp Y1+Y2
Press [VARS][=>][Y-VARS][1:Function][1:Y1][ENTER]. Editor shows :Disp Y1
Press [+] . Editor shows :Disp Y1+
Press [VARS][=>][Y-VARS][1:Function][1:Y2][ENTER]. Editor shows :Disp Y1+Y2
Press {ENTER] to validate instruction
Editor inserts a new line :
:Prompt X
Press [2nd][0] (CATALOG) [8](P) [Scroll Down [till...] Prompt
Press [ENTER]. Editor shows :Prompt
Press [X,T.theta,n] key. Editor shows :Prompt X
To save program
Once all instructions are entered, press [2nd][QUIT] to save program.
To run program
  1. Press [PRGM]
  2. Under the [EXEC] menu, the list of available programs appears.
  3. Type the number corresponding to the one you want to run ( FOPG) and press [ENTER].
  4. The main calculator screen displays prgmFOPG and blinking cursor.
  5. Press [ENTER] to make it run
  6. Enter a value of X and press [ENTER]
  7. Follow instructions.
Dec 21, 2009 | Texas Instruments TI-84 Plus Calculator
How do I get newtons method into my calculator?
Press [PGRM] [|=>][NEW][1:Create New][ENTER]
At the prompt NAME=, Type the name of the program.
Use the catalog [2nd][CATALOG] to enter the commands Input, Lbl, nDeriv(, Disp, Pause, If, abs(, Stop, and Goto.
In the catalog, the entry mode is ALPHA
  1. The fisrt two lines of the second screen are not to be entered. (It is an overlap). I had to scroll down to get to the bottom of the program editor screen.
  2. Before you can use it to solve for the zeros of a function, you must define it in the [Y=] editor.
  3. The symbol Y1 in the program listing can be entered by pressing [Vars][|=>Y-VARS][1:Function][1:Y1].
  4. When finished entering the program press [2nd][QUIT] to exit the editor.
To run it, press [PGRM]. Under the menu [EXEC] you see a list of the available programs. Select the one you want and press [ENTER]
During the run, the program finds an iterate and waits (Pause) for you to press [ENTER]. You must keep pressing [ENTER] after each iteration, until it returns Done.
Hope it helps.
Thank you for using FixYa.
Do not forget to rate the solution.
Nov 24, 2009 | Texas Instruments TI-84 Plus Calculator
Here is the program taken from the manual for the calculator. Key it in and use.
6f5d0fa.jpg The program requires 94 bytes.
Hope it helps.
Aug 18, 2009 | HP 32sII Calculator
Programing using if then statements
HP's RPN calculators have always followed the "do if true" rule. If the test is true, the next step is executed. If false, the next step is skipped. So, in your case, you would simply follow the x>y instruction with the goto instruction. If the test is true, execution will brance to the specified label. If false, execution will continue with the step following the goto.
Apr 02, 2009 | HP 35s Scientific Calculator
TI 84 Change brightness command
Couldnt you just do 2nd up or down multiple times
Oct 24, 2008 | Texas Instruments TI-84 Plus Calculator
I can not escape the following program
This program has an infinite loop in it. Remove the "Goto ad0" statement. With this in, the program computes the speed and then goes to the beginning and asks for the distance and time again. And again, and again...
With the "Goto" statement out of the program, you can also remove the "Lbl" statement as well.
Jun 17, 2008 | Texas Instruments TI-89 Calculator
Locate % button
There is no % button on the calculator, but depending on what you need it for, there are some simple basic programs that could work for this. If you just want to find percent from a fraction or decimal, use this one.
Hit the program button and press right two times the enter to get a new program.
Name your program "PERCENT"
hit enter
hit program, right, enter, to paste "Input" onto your screen
In quotes, put "Number?", then a comma, then N (not in quotes)
Press enter to get to a new line.
Enter "100N-->N" (once again, not in quotes)
The arrow is found directly above the on button
Press ENter again, putting you on the third line.
Hit program, right, 3 to paste Disp on your screen.
Put N after, not in quotes
Your screen should look like this:
:Input "NUMBER",N
:Disp N
Press 2nd Mode to quit, then hit the program key and select program Percent to run (making sure you are in the "Exec" menu)
Hit enter to run your program: it should turn decimals or fractions to percents.
Don't feel that your intelligence is being insulted by me giving explicit instructions that may be below your level in programming: I did not know whether or not you were proficient.
Apr 24, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-89 Calculator Logo
80 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
