Question about HP PSC 2175 All-In-One InkJet Printer
Not printing or scanning
On attempting to scan, I get
The function you have requested cannot be performed because another program already has control of the device. If the program currently using the device, save any unsaved work, close the program, and try again.
Which isn't even English!
On attempting to print, I get
This document failed to print.
blablabla
To fix this problem................blablabla
    Problem Solver:
  • 12 Answers
For this issue try uninstalling the drivers compltely and resintall using the CD which came along with the printer
Posted on Jun 17, 2008
When I attempt to sacn I get the following error: The function you have requested cannot be performed because another program already has control of the device. If the program currently using the device,...
Have you tried restarting your computer and the printer? If not, restart both the computer and the printer and then try again, if there is no hardware issue with your printer, this will definitely fix your issue.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 29, 2011 | Office Equipment & Supplies
I have a 2006 Chevrolet Malibu and the keyless entry started working intermitantly and now randomly works maybe once a week. It wont pop the trunk or lock or unlock the doors. I replaced the batteries in...
Unfortunately you may not have a choice in the matter ! You have no idea of the electronics involved here . No one knows your GM vehicle better . And $ 85 dollars is a heck of alot better then $115.00 dollars a flat rate hour . Pep boy's , firestone , AAMCO .
The keyless entry system has the following main components:
• The transmitters
• The body control module (BCM)
• The remote control door lock receiver (RCDLR)--When you press a button on the transmitter, the transmitter sends a signal to the RCDLR. The RCDLR receives the signal and sends a X Link serial data message requesting the appropriate function from the BCM.
Customer Programming Method for Enabling/Disabling the RVS Feature
Using the driver information center (DIC), the RVS feature can be DISABLED and ENABLED just like other items programmable via the DIC. When a lock control, entry-remote entry, extended range (AP8) equipped vehicle has RVS added to it and the vehicle is not DIC equipped and the customer wants to disable RVS. The dealer will perform the DISABLED remote start function since the owner cannot perform the function on thier own without a DIC.
Important: All transmitters that are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon receipt of the programming signal from the first transmitter.
Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
The scan tool must stay connected until all of the transmitters are programmed. All doors must be closed to perform this function.
Install CANDI module.
Install a scan tool.
Turn ON the ignition with the engine OFF.
With the scan tool, select Vehicle Control Systems.
Select Computer/Integrating Systems.
Select the proper engine size.
Select Module Setup.
Select Body Control Module (BCM).
Select Program Key Fobs.
Follow scan tool on screen instructions.
Remove the scan tool.
Exit the vehicle. Attempt to lock/unlock the doors to verify the programming.
Operate the transmitter functions in order to verify correct system operation.
May 04, 2017 | 2006 Chevrolet Malibu
When i format it only 1 meg formats and the system says everything is OK I cannot get it to format to the full size
USB devices least require formating once acquire from retail. Ascertain that the devcie is compartible to the computer that is requesting resourcefulness. For example, in a situation that computer displays messages either requiring complementary codes resources to attain functionality is indication of system outdate. Ascertain each devices compartibility. For example, recent computers are innovative already compartible to USB devices. Depending on the request from the device would require adjusting features on the computer. For example, USB device assume functionality soon after being pluged into computer. However the type of files documents that require communcations with device predicts teh sequecne of events. Computers that perform with media files, documents or programs in complicated formats would require modifications to attain functionality with USB device.
Feb 20, 2011 | Memorex 32GB Mini TravelDrive Flash Drive...
Hp psc 1513 all in one series scan problem
reformat your system so that you can install properly your HP printer, this time the system are being invaded with spywares & viruses...
Jun 18, 2009 | LaserJet 3052 All-In-One Printer
HP Printer will no longer scan
Hi Keithcarrol
Please do the following
1. Go to Control Pannel then sellect Add/Remove Programs and uninstall all HP Software.
2. Disconnect all Prinetrs
3. Go to Control Pannel then sellect Printers and Faxes make sure there is no Printers in there if there is delete them
4. Install Psc 2210 software and follow instructions on when to connect printer.
Dec 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP LASERJET 3052
plz try by reloading the software
Aug 13, 2008 | HP LJ 3020 All-In-One Printer / Scanner /...
Scanning
My Photosmart 2575 v has worked fine as well for over a year and now it won't scan. I get the same message: "Refer to device documentation to troubleshoot". I ran all updates and they said I have them all and everything is working perfectly. It's not though. I still can't scan. I tried their work-around by opening paint and then acquring image from the scanner but that does not work either.
Apr 30, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP PSC 2175 All-In-One InkJet Printer Logo
157 people viewed this question
Seeker5211
Seeker5211
