Question about Samsung Televison & Video
How do i change my lcd tv from air to cable - Samsung Televison & Video
  • Samsung Master
  • 4,348 Answers
What you are seeking is changed by a button usually labeled INPUT or source. this button toggles through the input sources.
Posted on Nov 10, 2010
Moved tv from one house that had cable to another that has antenna will not down load channels
change the input from cable to antenna most of the over the air stations do not download .
Jun 20, 2015 | Philips Magnavox 26MF605W17 26-Inch...
How do I change from Analog air to cable?
there are no analog over the air channels, only digital ones, there should be an input button, maybe even an antenna select button on your remote, or in the set-up menu using the buttons on the front of the tv. there may also be a seperate connection in the back of your tv for cable, or over the air antenna
Oct 22, 2013 | Sansui HDLCD-2612 LCD TV
How can i change on dtv ,the mode air with cable
When in the main menu, there should be a setting/option for tuner. Then if you have regular tv, switch it to AIR. If you are using cable, then switch it to CATV.
Feb 07, 2010 | Protron PLTV3250 32 in. LCD Television
Need to disconnect cabl;e and used rabbit ears for outside use,,TV will change off blue screen from cable
you need to get to the menu and change your tuner mode from cable to t.v antenna air signal
Sep 21, 2009 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
Can't turn off TV unless unlug the power.
Check ur cable or air tv signal.
Turn off and on agian ur your cable box ,if u have free over the air signal u must ajust ur in door or out door antena.Clean ur off/on on ur tv with a little DW40 on the rag clean the switch.Change ur batteries in ur remote,every year,solve most ur tv remote prob.
Aug 09, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Could I change NTSC to PAL N my LCD Sansung LN T
NTSC and Pal are mainly related to Cable/Air reception. Unless you are trying to connect a SCART cable, you can probably just use the video inputs of the TV. Power Supply differences will be the big issue probably.
Jun 21, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Changing TV set up to cable from "air"
Try setting tv to channel 3 or channel 4, this should coincide with the back of satellite box (a little black switch with a 3 or 4). then switch channels with your satellite box. I would recommend using another output off the satellite box to feed the other tv, a splitter loses some signal quality an can go bad as well. get a long rca cable to feed tv!
Mar 01, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
The screen says Air, No signal the channels will not change on tv or remote DTV 265-D with built in DVD
Do you have an anntenna connected to the tv?  if so go to the menu and do Auto Channell Search. If you do not have a anntenna and have a cable or sattilite box you need to change the tuning band from air to cable.
I can assist further if needed.
lone99star
Dec 31, 2008 | Mintek DTV-263 26 in. LCD Television
Air Digital No signal on the screen. Cannot change channels
hi my name is mark, since you have a cable box. you need to switch the tv back to the analog signal on the tv through setup or menu screen. then use cable remote to change channals. thanks for your question.
Dec 26, 2008 | Mintek DTV-263 26 in. LCD Television
Olevia tv erased all channels accidently
BEVERLYQC::
How do you " accidently erased all my chanels " from a tv??
Was the TV connected to a 'cable box' ?
Was the TV conected to 'air waves' or antena input.?
If the TV is attacned to a cable box, temperly remove the cable box INPUT wire, attache an antenna to the IMPUT AND AUTOSCAN WITH THE REMOTE CONTROL
If the TV cannot 'autoscan' in 'air wave' reception...goto menu and set input channel to ch.3 or see if there is a switch in the back that can change to ch.3 or ch.4
You should get all the 'air wave' chanels which will include ch.3 & ch.4
Oct 22, 2008 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
