Question about McCulloch 16" Electric Chain Saw 35 HP
I'm trying to replace the fuel lines on the primer button of a small McCullough chain saw. The old ones had dry-rotted and fell off, and I couldn't determine which line goes where. My first configuration didn't work.
    Brigadier General:
  • 4,088 Answers
The primer is just a small pump--it is supposed to draw fresh fuel through the carburetor and expel it back into the tank. There are also just two lines on the carburetor--the upper one should go straight to the fuel tank and filter, the other goes to the intake side of the pump. Just pick a port of the primer (remove the other line for the moment), and try to pump fuel into the bulb (make sure the bulb is not decayed as well)--it should fill with fuel if you have the correct connection--if not, just place the line from the carburetor on the other primer port and try to pump again. If still no fuel, something is plugged in the carburetor or the fuel filter. Hope this helps!
Posted on Nov 10, 2010
Testimonial: "Amazing response to my inquiry. I was surprised to hear back so quickly from a very knowledgeable individual. Thanks for the help. "
  • martrpjr Nov 27, 2010
    I have an older model Mac 4600 chain saw...the fuel lines around carb have rotted off...thre appear to be 3 diff lines....one to fuel filer 2 more but do'nt know how to route them....is there a diagram I can access to properly repair?
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My fuel lines dry rotted, what is the correct configuration for the lines
Fuel hose from the tank with the filter on the end goes to the fuel inlet on the carb ( nearest to the pump cover held eith a single screw ) then tak a pipe from the other cinection on the carb to the short conection on the back of the primer ( suction side ) then tak a pipe from the longer conection on the primer ( pressure side ) back to the tank, the primer pulls fuel from the carb and dumps it back to the tank.
Apr 07, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Sep 14, 2009 | Poulan Garden
I have a McCullah chain saw 39cc that I had to replace the primer bulb on, when taking the old one out I discovered that the old hoses were dry rotted and crumbled. My problem is I know one hose goes from...
Without seeing your saw it is difficult to visualize. There is usually an overflow from the carburetor back to the fuel tank. I suspect that is your third hose. Lou
Aug 27, 2009 | Garden
Need digram to install fuel lines
First, you sould have one with a filter in the tank going to carb. Next run one from tank to primer bulb and from one from primer bulb to carb.
May 18, 2009 | Garden
Mcculloch gas chain saw / 3200 changed fuel hoses due to rot
The line from carb goes to bulb inlet, the bulb outlet goes to tank. Line with filter goes to carb inlet.
Mar 21, 2009 | McCulloch 26cc Gas Blower Mcb3208
I need a repair manual for a McCullough gas, 35 chain saw
Mc chain saw fuel lines rotted away need to know where they go
How the primer lines go! There are 2 outlets on carb. two tank lines two primer lines
Jan 11, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch 16" Electric Chain Saw 35 HP Logo
279 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
