I'm trying to scan multiple pages using a Ricoh mp c5000, but when I go to look at the scanned image, its only the first page. what am I doing wrong???
  • 16 Answers
SOURCE: scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Posted on Jan 05, 2008
adonscott
  • 106 Answers
SOURCE: Scanning multiple pages
hi,
For you to be able to scan multiple pages using the .pdf and save it in one file, here are the steps that i want you to follow.
SOLUTION I.
1. Open the Solution Center.
2. Click on Settings, then go to scan settings.
3. Click on Scan preferences.
4. Make sure that the "Prompt for additional scans from glass/TMA has a checkmark. then click OKAY.
SOLUTION II.
1. Solution Center is open, click on Scan documents.
2. Scan document settings is open, choose SCAN TO: .pdf and file type is .pdf
3. Click on SCAN below. It will start scanning, and just click on ACCEPT everytime it gives preview on each document.
Thank you.
adonscott
Posted on Jul 04, 2008
safenude
  • 124 Answers
SOURCE: scan multiple pages to email
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
  • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
  • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
  • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
  • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
  • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
  • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
  • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
    • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
    • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
    To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
    1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
    2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
    3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
  3. Do one or more of the following:
    • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
    • To change the location for the saved files, click the Change button on the Output tab, and select a location.
    • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
    • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
  4. Click OK.
Scan your pages
  1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
  2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
  3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
  1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
  2. In Document Imaging, click Open on the File menu.
  3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
  4. Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
  • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
  • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
  • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
Posted on Jan 27, 2009
  • 11 Answers
SOURCE: Scanning Multiple pages into one pdf
Typically it is possible, in advanced settings for scanning it will typically give you an option to scan multiple pages into one document.
Posted on Jun 26, 2009
  • 1121 Answers
SOURCE: does HP 8500 scan multiple pages into one file?
yes if you use a pdf editor or office suite.
Posted on Dec 25, 2009
How to clear memory in a mp c5000 macine
There are many counters in this machine. Jam, Error, Feed, All, Memory, Service Codes etc, that are located in the service software of the machine. If you don't know what each one does you can end up doing more harm than good by wiping out the wrong ones. Best to call a trained tech.
Aug 14, 2014 | Ricoh Aficio Mp C5000 Color Copier - 129k...
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
Aug 07, 2013 | Canon MP Navigator EX for Windows
Ricoh MP C5000 can't scan to gmail
once again the tech boyz mix up the formula ssl is a device unique identifier technology which has many permutations i'd expect it will take an act of God to get gmail apps to do this for a single device, and Ricoh is not in that business
keep an eye on the gmail apps forums and you might get lucky
May 29, 2012 | Ricoh Aficio MP-C5000
Can't save multiple page scan to multiple page pdf document
that should be because you scanned the pages separately, did you notice if the PDF document converted was the very last page of the 13paged document which you wanted to make a document from? if that's right, then you just only converted the last scanned page into PDF, to stick all the pages together, i recoment you treating them as images and using word to stick them all together with the "insert>image> from archive" adjusting the size of the image at 1 page and with each 13 pages do the same until you have a full document of 13 images in 13 pages then you can convert it into PDF
Sep 14, 2009 | Brother Multi-Function Center MFC-240C...
I need to scan multiple papers on the mp 460. How do I do this?
Use the MP Navigator. Select the scan/import and then click photo/document. You can then scan or specify the settings of the scan. When you click scan, have your first page ready allready on the glass and when it's done a box will appear and the ICON of the image. Put your next page on the glass and then click OK on the box. This will repeat till you press cancel. You can change the settings again and then press scan it will then add more ICONS to the screen. If any scans go wrong deselect all the ICONS (after you have finished scanning) and reclick them one at a time (except the faulty ones) from where you started from, to save them in the right order!
Jan 18, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Scan multiple page with X4550
The 4550 will not allow multi page scanning into a single doc using the provided software. You should try another scan software that is TWAIN or WIA compatible. Those should work okay if you are using a USB connection.
Aug 23, 2008 | Lexmark X6570 InkJet Printer
Go to the Epson web site and download the Reference Guide that they provide free. This guide includes instructions on using the scanner in Professional mode so you scan multiple images simultaneously
Jul 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
hi,
SOLUTION I.
SOLUTION II.
Thank you.
adonscott
Jul 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Scanning with Canon Pixma MP450
I just did it then! With help from solution posted Feb 08 leave the acual scanner alone can be done from the computer. Steps:
1. Go to - start - control panel - printers & hardware - scanners.
2. Once inside the scanners folder just click once on the scanner icon (mine is called WIA Canon) so it is highlighted.
3. Then click on the toolbar 'File' > 'scan', then select the correct program from the list (mine was MP Navigator 2).
4. Use the MP Navigator program to select "scan photo/document", follow the instructions. At the bottom if the window that is open you can change the document type to PHOTO or DOCUMENT!
This is where the problem lies it is scanning the document as a photo which is why it is coming out as multiple documents.
Feb 06, 2008 | Office Equipment & Supplies
138 people viewed this question
jasbo
jasbo
