Question about Samsung SyncMaster 940MW 19" LCD Monitor
When i go to turn the set on with either the remote or manually it takes a number of attempts
  • Samsung Master
  • 1,684 Answers
Yes, The problem you are having is caused by a failing power supply with problem capacitors. We have a step by step repair guide posted on our web site at:
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/
Anybody that can solder should be able to do the repair. The repair guide was a full parts list for the repair.
I hope this helps, if so please rate our solution.
BuddyMc
Posted on Jan 31, 2011
    President:
  • 1,623 Answers
Probably a few capacitors are on there way out inside, you can tell which as the tops will be bulging out, replace with the same and your problem will be solved, eventually they will go and then it wont come on at all
Posted on Nov 10, 2010
Bose music system remote is inconsistent.
The notoriously unreliable SMD capacitors which Bose installed are long defective. That's just the start of your problems.
You'll need to replace those defective capacitors with much higher-quality units than the original.
Only a tech experienced with SMD work should attempt this repair.
Replacing the PCB will solve your problem for only a short time, as you are just getting the original standard junk again, but new.
Dec 29, 2014 | Bose & Wave& Music System
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Previous tenant left ac window unit Haier HWF05XC5, but took the remote. Can I manually turn on this ac unit? when turning the power button, only the fan turns on, I'm unable to switch to AC
According to the Model Number you listed, it's a Mechanically or Manually Controlled AC unit. There is no remote control for it.Please be certain the Model Number you listed is correct and get back to me.
If it's the correct model number and it's manually controlled. You should have 2 rocker switches. One is to turn the power ON & Off. The other is to set the Fan Speed either on Low or High. Then there is a dial, numbered 1 to 10 to set the cooling level. 1 is min cool and 10 is Max Cool.
If the controls on your unit match what I described above, it's a manually controlled unit. No remote.
I hope this helped you. Please advise. Thanks.
Jul 11, 2011 | Heating & Cooling
How do u program. With and withoit codes
Manually:
To enter the code into the remote, turn on the device you want to add. Point the remote control at the device and hold the "Code Search" button until the LED light is solid red. Press the button for the device you want to set, such as "TV" or "DVD." The light will blink once and then stay solid red. Use the number buttons on the remote to enter the first code associated with your device. Once the code is inserted, the LED light will turn off. Point the remote at the device and press the "On/Off" button. If the device turns off, the code is correct. If the device does not turn off, repeat the preceding steps using the next code on the list.
No Code:
To use the code search, turn on the device you want to set. Point the remote at the device and hold the "Code Search" button until the LED is solid red. Press the corresponding button for the device you wish to set, such as "TV" or "DVD." With the remote pointed at the device, repeatedly press the "On/Off" button. Continue to do this until the device powers off. When it shuts off, press the "Enter" button to set the remote control. Use the "On/Off" button and see if the device turns on again. If it does, the setting is complete. If it does not, attempt the code search again and be sure to press the "Enter" button quickly when the device turns off.
Feb 28, 2011 | Innovage Jumbo Remote Control
My digitallifestyle remote, no longer turns on or off my tv. I have (2) universal remotes (1) is a phillips model (pm335) the other is a RCA. don,t know the model ofthat one
There is an process for cleaning the IR on both units as listed below. Try this first before we reprogram the units.
Please take these actions before we try yet another universal programmable remote 1. Clean the IR screen on your tv set. It will often appear clear in view with a reflective window which often has a black, blue, or red tint to it 2. Clean the same window on the programmable remote 3. From tons of experience, I've noticed that Sony tends to provide the most compatible remote for replacements 4. Please confirm with me which codes your attempting to use when programming, and type /model number of the universal remote 5. Keep in mind that the remote that does not work as a replacment may very well be exchanged 6. Only use approved batteries for your remote and keep in mind that rechargeable batteries account for 50 percent of electronic errors 7. If your old remote simply stopped working for no reason at all, then we may have a communication problem with the tv combo set itself. 8. Ensure that the tv set is ready and able to receive a signal by setting it to the factory defaults within the settings menu 9. If we know why your older remote simply stopped transmitting the signal, we will acheive a must faster solution 10. Please attempt a fresh set of batteries in the older remote to determine the root cause behind the transmission problem 10. Check your power cord for crimping, dents, or pinched underneath unit. Each of these activities will cause power to stop transmitting to your unit 11. the digital display is not popular for having problems. 12. Ensure that you press the power on button on the digital display firmly at an attempt to power the unit on. 13. If you still have not recieved power, we will continue to troubleshoot the internal portions
Jan 28, 2011 | Philips Televison & Video
I am unable to click on features on the Tv. I changed the batteries and nothing happens as per a connection. # rm-yd016
IR REMOTE programming error Please take these actions before we try yet another universal programmable remote 1. Clean the IR screen on your tv set. It will often appear clear in view with a reflective window which often has a black, blue, or red tint to it 2. Clean the same window on the programmable remote 3. From tons of experience, I've noticed that Sony tends to provide the most compatible remote for replacements 4. Please confirm with me which codes your attempting to use when programming, and type /model number of the universal remote 5. Keep in mind that the remote that does not work as a replacment may very well be exchanged 6. Only use approved batteries for your remote and keep in mind that rechargeable batteries account for 50 percent of electronic errors 7. If your old remote simply stopped working for no reason at all, then we may have a communication problem with the tv combo set itself. 8. Ensure that the tv set is ready and able to receive a signal by setting it to the factory defaults within the settings menu 9. If we know why your older remote simply stopped transmitting the signal, we will acheive a must faster solution 10. Please attempt a fresh set of batteries in the older remote to determine the root cause behind the transmission problem 10. Check your power cord for crimping, dents, or pinched underneath unit. Each of these activities will cause power to stop transmitting to your unit 11. the digital display is not popular for having problems. 12. Ensure that you press the power on button on the digital display firmly at an attempt to power the unit on. 13. If you still have not recieved power, we will continue to troubleshoot the internal portions
Jan 27, 2011 | Sony The Miracle Remote for TV Remote...
I don't know if I can make it any clearer. My remote RM-PP411 suddenly stopped working. It has new battries and the use mode light lights up when any key is pressed. I turned the STR-D685 on by hand and...
Jan 26, 2011 | Sony RM-PP411 Remote Control
Manual menu button not working after adding channel-no RCA remote only disconnected DirecTV remote
Normally if you unplug the tv for 10 min everything resets, if not look behind for a reset button
May 13, 2009 | RCA F25216BC 25" TV
It takes about eight or so tries before the set turns on.
Here's the easy fix for your problem, it'll cost you $5.00 in parts from The Shack and a half hour to do it if you take your time: http://www.fixya.com/support/t778853-tv_lcd_akai
Good Luck!
Ren
Mar 15, 2009 | Akai LCT2785TA 27 in. LCD Television
One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Dec 27, 2007 | One For All URC-3021 Remote Control
Samsung SyncMaster 940MW 19" LCD Monitor Logo
922 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
