Question about HP LaserJet 5550 Printer
HP Color Laserjet 5550 not printing duplex
Hi
Printed a job double sided fine on black and white printer but same job doesn't print on colour. All settings seem to be fine and ready to go but it still prints single sided.
  • Anonymous Mar 13, 2014
    Hp color laserjet cp2025 printing not colour
Hi, Check that the printer driver has duplex (double sided) turned on.
That's if u hav not already solved it :-)
Posted on Sep 17, 2008
Y U
Posted on Oct 07, 2008
HP color laserjet cp2025 will not print. Help.
No.
Very few printers will print if they're out of toner, even if the colour toner is exhausted and the print job is only black. Replace the empty toner and if this is the only problem, the printer will continue printing.
Jan 20, 2015 | HP Laserjet Cp2025n Printer
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
I am trying to set the printer to automatic duplexing...?
Hi
If you want to set Print on Both Sides (duplex) as the default setting for all print jobs (even single page jobs) use the following steps.
  1. Click Start , Printers or Printers and Faxes from the Microsoft Windows desktop.
  2. Right-click the HP Color LaserJet 2605dn_2605dtn and select Printing Preferences (Properties in Microsoft Windows 2000).
  3. Click the Finishing tab.
  4. Select Print on Both Sides under the Document Options section.
  5. Click OK to save the setting and close the Printing Preferences window.
  6. Close the Printers or Printers and Faxes folder.
Note:In this scenario, all print jobs, even single print jobs, will be treated as Print on Both Sizes (automatic duplexing) for media that is supported by the duplexing unit. For media that is not supported by the duplexing unit, the job will be treated as Print on Both Sides (Manually) (manual duplex).
Jun 13, 2011 | HP LaserJet P4014n Printer
Hi there, How do I set up my HP Colour Laserjet 2600n to print double sided automatically instead of having the alter the paper half way through! Thank you, Theresa
From the application that you are trying to print, click Print and then Preferences. On the next window you will have Print on both sides, tick Flip on long edge and if your printer has duplex capability it will print both sides now.
Dec 17, 2010 | HP Color LaserJet 2600n Printer
Printer will not print
If you go to control panel, printers and fax, right click on your printer, then select properties you will see a section for color or grayscale printing. Select grayscale for all your jobs to be printed in B&W.
Good Luck,
Jesse
Jan 11, 2010 | HP Color LaserJet 3500 Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
HP 1600 Colour laserjet Double image
Colour registration problem (some printer loose their registration from time to time).
There will be an option somewhere in the menu system of the printer, or the HP 'Toolbox' to correct this.
Apr 04, 2009 | HP Color LaserJet 2600n Printer
HP laserjet 5000 series PCL 6 driver
have you tried from the print command dialog box from pc
Apr 28, 2008 | HP LaserJet 5000dn Printer
Samsung CLP-500 cutting off print
The duplexer is bad or needs to be realigned, shake up the cyn color. it mostly likely low.
Dec 06, 2007 | Samsung CLP-500 Laser Printer
HP LaserJet 5550 Printer Logo
3,563 people viewed this question
Ben Johnson
