Where to I place the sensor on a wall mount heater? Also, how do I get the heat to go into the other rooms? It seems to me to be hot in the immediate area where it is placed. Thank you.
  • 3,289 Answers
Thermostats and sensors should be installed in spaces with airflow. This means it should not be on a wall where it may be blocked by an open door or similar objects. It shouldn't be where the sun can shine directly on it (and make the sensor believe it is warmer than it actually is), not should it be on outside walls (and make the sensor believe it is colder than it actually is).
If it is a thermostat, a comfortable height is about 5 feet. This makes it easy for adults to read and set, without worrying about young children changing the settings after your leave. If a simple sensor, this 5 foot height applies still - but lower is just as good. Remember, since heat rises, the air on your face while standing may be a couple degrees warmer than when sitting. A sensor left on the floor will cause the room to feel much warmer than the desired temperature when standing and to a slightly lesser extent while seated. This also translates to higher heating costs.
As mentioned above, heat will naturally move up. Getting it to move side to side requires additional equipment. Fans do the job inexpensively and very nicely. Place them in higher locations (where the heat is) and set the speed to a low setting, aimed into the cool space. This gently moves the warm air into the cool space - without causing a breeze that may actually feel cool on your skin.
I hope this was helpful - good luck!
Posted on Nov 10, 2010
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
Dcs oven wos130 wont reach set temperature on bake
Good afternoon Steve!
The answer may depend a bit on what you mean by 'stops heating'.
  • One interpretation could be 'the heating shuts off, and the oven goes back toward room temperature
  • The other would be that it heats up, but it heats to a certain temp and then stays there. it's just not as hot as it's supposed to be.
If it's the former, that sounds like something is overheating and an interlock is engaging because it's interpreted as 'I'm too hot where I shouldn't be, and I should shut off before I cause a fire. I'd leave that to a better trained service tech.
If it's the latter, then it'll depend on how low it is. If it's way low, then there's a couple possibilities:
  1. The heater element is defective, and even at the full current draw the oven can run, it can't get any hotter than that upper temp. This would mean replacing the element.
  2. The temperature sensor in the oven is defective or mis-mounted. There should be a temp sensor inside the oven cavity. if it's disconnected, or, say, bent out of place and much nearer the bake element then it should be, then the heat coming direct off of the element may be fooling it into thinking the oven is hotter than it really is. this could mean replacing the temp sensor, or just re-mounting it to proper position.
If it's just a bit low, then there could just be a calibration problem. If you look at the manual here
DCS WOS 127 Use And Care Manual Child Safety User Option you can see how to adjust the calibration up or down in temperature to, hopefully, match the oven thermometer you're trying to use as a check.
Hope this helps!
Good Luck
D
Nov 18, 2015 | DCS Wot-130 30" Wide Single Electric Wall...
How do you insulate a tankless water heater for winter
If you have tankless electric, it can simply be insulated... but tankless electric are seldom mounted outdoor.
Service bulletin says: "the only way of assuring protection is to completely remove the heater during those times the area may experience freezing temperatures.
There are tankless with built-in heater for exterior installation.
Check your manual, or add a comment with specific model number and maybe I can find the information.
Here's why they install tankless outdoors: Because tankless burn more fuel per gallon of hot water. This requires larger gas line and larger vent pipe than typical tank-type gas water heater that is usually installed indoors.
They install tankless outdoors, so there is no need for expensive vent pipe, and because there is ample incoming air to support combustion.
So if tankless does not have factory-installed internal heater, then the unit can freeze easily when the combustion draws in cold air.
Of course you can put heat-tapes on the pipes but the heat exchanger inside will quickly freeze during periods when hot water is not being used, and combustion is not taking place.
You can move the tankless installation inside and use correctly-sized vent and intake pipes directly through the wall. This will generally protect tanklesss from freezing if room is heated adequately.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 26, 2012 | Rinnai Webstone The isolator EXP tankless...
Dimplex LC Series causing wall to get very hot
Talked to my electrical supplier and he told me to avoid them. They are the same wattage in a smaller package, thus creating more heat in a smaller area rather than spreading it out to a larger baseboard. He said he doesn't know how they passed fed. Regulations. I am on the fence if I should get them.
Nov 20, 2011 | Heating & Cooling
The top grill on my Vulcan wall heater gets very hot is this normal please let me know thank you
this is normal as the wall unit heats and hot air is blowen into the room the grills will get hot
Jun 11, 2011 | Heating & Cooling
I have a glow warm 20000 btu natural gas unvented heater. The unit is wall mounted. It won't stay on for more than 15 minutes, then shuts itself off. Its in a corner if that makes a difference... but has...
well, these heaters are typically thermostat-bound, and I have found that they simply will not burn continuously, like a blue-flame heater. Try turning up the setting--this will make it come on/off more often, effectively heating at least one med-lg room, and partially for adjoining areas. Keep in mind that these only rated for 700-1500 SF--that is NOT the floor measurements, but square feet of airspace; eg., a 10' x 15' room has 10' x 15' x 8' (8 foot ceiling) =1200 sf. That said, My 15k btu wall unit had been the sole heating source for my entire home for 5 years, until last year, when I acquired another smaller unit. However, I typically only use a few rooms, and shut off unused areas (ya, was 'cool' in unused back room areas).
Dec 16, 2010 | Desa International GWP20T GLOWARM Wall...
I'm puzzled by what may be causing low heat output from a Markel wall-mounted 240V electric heater, new from around 1984; cannot find model number. I'm not sure of the wattage rating. The heater element...
your element may have metered out but still may not getting as hot as it used too found this on my hot water cylinder, the hot water was only warm not hot like it should be so pulled out it meterwd fine but when i placed a new one in the cylinder and let the water heat up it was a lot hotter than it had been and now i can't get out of the shower but it was the element not heating as it should have and thats just old age i bet i don't run as hot when im old and it was nearly thirty year old heater, if it was new from 1984 it sounds like its had a full life i don't really expect heater to last more than thirty years well really more than twenty years anyway and a heater from the eighties couldn't have never been that efficient and **** a bit of power too i'd upgrade to at least a 2000 model heater you'll actually save money by buying a newer one!
Nov 19, 2010 | TPI H3327TDRP Markel Electric Wall Mounted...
Connect my 24 milivolt gas (between the studs) wall furnace ( in my hall) to my thermostat that operates my electric heat central unit. problem: to sync both units to give home more balance ( hall is...
the first problem is you need a milli-volt t-stat and your central has a 24volt t-stat if you connect the 2 it will fry the controlls in the wall heater the second problem is t-stat location if the wall heater is near the central heats t-stat it will shut off the central to soon . maybe relocate wall unit to coldest room ?
Nov 16, 2010 | Honeywell Heating & Cooling
We are having a wood burning stove installed near a wall in dinning room.no fire place.will we need a heat shied so wall will not get damaged or cracked? Installer will follow manufactures instructions...
Nothing wrong with a little added security.
Go with the extra heat shield.
Keep in mind this heat shield can be decorative too!
You will sleep better at night knowing there is little change heat build up will occur on that wall.
Oct 04, 2009 | Dacor 36quot; Internal Blower Wall Mount...
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
