Question about Linksys Wireless-G Broadband Router
Linksys settings site not opening
Hello sir my linksys settings not opening how can i change the settings.iam trying with 192.168.0.1 with this iam nt able to open my settings..is anyother way to control it
  • xCAUSALITYx
    xCAUSALITYx May 11, 2010
    Have you tried pinging the address to see if the router is getting any requests from you.
    Cheers
    Guru:
  • 1,463 Answers
Isnt the linksys address 192.168.1.245
riz.
Posted on Jun 17, 2008
I am using 3g wireless router buyed from wifi digisol company. can anyone please help me to tell is this product is right for internet communication. for more details related to this product visit htt
Sir
Using 3g wireless Linksys Routers is best router you use for inter net connection,
For customers using the AT&T 3G MicroCell and a Linksys / Cisco router model WRT54G2 or equivalent, the following settings should be made to the router.
NOTE: Changing the broadband router / modem / gateway settings may cause other applications to stop working, and / or change the broadband router security settings for outbound data transmissions. Please see the router / modem / gateway instruction manual for more detailed information.
Procedure
1.Open Internet Explorer and navigate to the router setup page at http://192.168.1.1
2.Enter the User name and Password, click OK
3.Verify the following settings:
Automatic Configuration - DHCP
MTU: Auto
4.
Select the Security tab, verify IPSec Pass through is set to Enable
5.Click Save Settings
I Hope Your Router Linksys Routers Problem Is resolved By now:
In case you need online Linksys Routers help then follow us on for:
Linksys Router Support
Apr 02, 2014 | Linksys Computers & Internet
Sir iam using nokia 2730, iam put password to memory card, then after remove my password then restore all so my card not open it asks password tell me solution sir (iam using micro sd amagan 2GB
Hello Praveen,
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file to unlock the memory card.
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
Jun 06, 2011 | Nokia 2730 Cell Phone
Hello. I am trying to get my NAT open with my linksys BEFSR41 V4.3
You are trying to open the NAT on the router.
For this you will need to reduce the MTU settings on the router
to 1365. Disable the UPnP on the router.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Sep 14, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
DVD DRIVE OF MY HP LAPTOP
Hi there:
If you know how to boot the computer into bios look for the boot section and check to see if the cd rom is there if not change the settings to show a cd rom and than save and reboot but i think you may have damaged the cd rom when you forced it open these are pretty delicate devices , force should never be used .
best regards mike
Feb 16, 2009 | Toshiba Satellite U305-S2804 Laptop
Old DOS program in WIN XP
hello sir
i have f500 compaq laptop i have no winxp driver in sound driver plz help me
thanks
Aug 31, 2008 | Microsoft Windows XP Professional With...
Hello Sir/Madam , Our Company has Cisco's ADSL2 Gateway Router (Linksys) Model No. AG241 . At our end Internet is ok . We own a website , Our Router is not opening our website , all other sites are opening...
Check the setting of your router, sometimes it is set to block some websites, but you can disable website blocking, use your router manual on how to open the SETUP of your router.
Jun 11, 2008 | Linksys Computers & Internet
My se w850i call directory deletes by itself
hi there did you try to reset the phone? if not go to menu, settings, master reset, reset settings, then it will ask a code2.gif, default code 0000 unless you have'nt change it.
try it maybe it will solve your problem.
peace!
Dec 14, 2007 | Sony Ericsson W850i Cellular Phone
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Wireless routers
I understand that you want to expand the coverage area, it is possible to connect multiple BSSs through a Distribution System. This forms an Extended Service Set. To do this you need to wired them together via Ethernet ports.
Nov 30, 2007 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G Broadband Router Logo
54 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
