Question about Lexmark X5495 All-in-One &USB Cable/Ink/Paper/Software InkJet Printer
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
  • Lexmark Master
  • 7,733 Answers
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Posted on Nov 10, 2010
My lexmark laser printer e120 prints smeared pages.please suggest how to solve the problem Thanks!
have you tried cleaning your infeed rollers as if sticking/slipping ( check for paper bits stuck within system ) print will be all over the page?? also you must have cleaned your print heads..
Jan 16, 2013 | Office Equipment & Supplies
Prints blotches and marks down the left edge
Hi
That sounds like classic wear and tear issues. All those rollers and gears have very close tolerances and any variation out of the rang and the paper grabing and jamming starts. And that could be cause of the toner leaking. You must have a lot of miles on that ol girl and you got your moneys worth out of her. They dont make them like that anymore and I dont think you could find the parts even though that was back when they supplied parts. I asked an engineer once "couldn't they make that one gear out of metal like the rest of them?" He replied "well sure, but there wouldn't be any money in that..." You beat the system on that one. Time to start your research on a replacement I'm afraid.
Jun 18, 2017 | OKIPAGE 12i Led Printer
Black dots/blotches on the sides of printed sheets - whats is the cause and how t to fix it
If you have random blotches on both sides of the sheet, your printer probably needs cleaning, especially in the fuser section. If the fuser is difficult to get at, here's a good cheat developed for HP LaserJet 6 printers: Use a basic graphics program such as Microsoft Paint to draw three solid black rectangles about 2.5" top to bottom, going all the way across the paper (the space in between is not critical - the key is that you go as close to edge-to-edge as you can get). Print out this sheet.
Put the sheet back in the paper tray so it will print on the blank side (usually printed side up). Open up a quick text processor (Notepad in Windows). Type a single space, then print (some text editors won't print a document with no data in it). Dirt in the fuser will get stuck to the black areas on your cleaning sheet. Test your work by printing another copy of " ". Repeat with a new cleaning sheet if necessary.
May 02, 2011 | Brother HL 2140 Laser Printer
Paper jams after first sheet prints. Tried adding more paper and then taking paper out. Nothing is working. No other sheets are jammed in the printer.
Poor quality paper can cause feed problems as the edge may be poorly sheared causing the sheets to stick together and often leaves fibers on the rollers which reduces their grip. Always 'fan' paper when replenishing to loosen the sheets.
Also, printers with heavy usage will occasionally needs the rubber pickup rollers cleaned. Don't use alcohol since this can dry out the rubbers surface complicating the problem. I have used naphtha to remove the built up paper fibers successfully.
Dec 03, 2010 | Brother HL 5250DN Laser Printer
Canon Pixma MP630 Printer\r\nWhen printing a document with 5 or 6 pages, after 2 or 3 pages you get a message that the printer has run out of paper. If you open the paper tray, you will find that the next...
their is problem with the rollers in the system.. u might using it from a long time!!!! rollers needs a replacement!!! Please contact the cannon for replacement!!!
Oct 15, 2010 | Canon Office Equipment & Supplies
Paper jams w/ all types of paper, Ink blotches...
If you're getting spots on the prints, run the Remove Ink Smears routine in the maintenance. It will clear the ink from the preheater. User packing tape to pull dust off of pick rollers. It's easy to unclip the unit and roll it on a piece of tape to remove dust.
Jul 30, 2009 | Xerox Phaser 8500/DN Printer
Paper catch rollers out of alignment
Hi.
Try this
1.take a sheet of paper ,,fold it length wise 2-3 times to make it thick.insert this into the paper feed tray...move it left and right a couple of times..this clears the obstruction if any..
if this does not work..call lexmark tech support,,,your printer would be replaced if in warranty..
good luck
Jan 25, 2009 | Lexmark X5470 All-In-One InkJet Printer
Print Output
Try cleaning the feed rollers. these are the rubber wheels that actually contact the paper and pull it through. If they get dirty, their grip on the paper will be less than adequate. Just use some clean water, or perhaps some rubbing alcohol, and a clean rag to wipe them thoroughly.
Feb 11, 2008 | Lexmark X85 All-In-One InkJet Printer
Uneven color on 4 x 6 prints only
Have you tried Uninstalling & Reinstalling?
Nov 05, 2007 | Canon i950 InkJet Photo Printer
Lexmark X5495 All-in-One &USB Cable/Ink/Paper/Software InkJet Printer Logo
637 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
