Question about Uniden CXAI5198 Corded Phone
New Handset Won't Communicate with Base
The handset on my old system was dropped and the numbers were scratched, so I wanted to replace it with a new one while keeping my old system. I had to buy a complete new system, and the new handset doesn't communicate with my original base. Is there any workaround for that?
  • 10 more comments
  • CreekFarm Jun 17, 2008
    How do I answer suggestions? And how do I reprogram my base?
    I can't seem to access any of the other solutions indicated by new emails, either. All I'm getting is the solution from micromaster, and not the ones from joelmar or pagebor.
    Comment by CreekFarm, posted on Jun 17, 2008
    If I knew how to do that I wouldn't be posting here. Please describe the process. Thanks.
    How long do I wait? I took the battery out for about two minutes and that didn't fix it. Thanks.
    My menu doesn't include registering or deregistering. The closest option is Security Code. I do have this model, but the menu isn't the same as is indicated in the manual. By the way, registering is on page 13.
    I already charged the battery. The option isn't there on the menu. I can't deregister my old handset, either.
    I got an email saying that there was a new suggestion from Ajkill, but I can't seem to access that. Also coolguy008 hasn't responded to my comment regarding his suggested solution - neither the new base or the old has the register option on the menu.
    Again, how do I "set it factory setting." I think the register suggestion was the best one, but I don't know how to do that since it's not on my menu.
    My menu doesn't include registering or deregistering. The closest option is Security Code. I do have this model, but the menu isn't the same as is indicated in the manual. I tried plugging in the new base set to see if that had the register option, but that didn't include it on the menu either. By the way, registering is on page 13. Is there another way I can register the phone?
    Still waiting to hear how to register the new handset.
    I called Uniden since it was frustrating dealing with the different people on FixYa. Their response was that my model can't be reregistered; I just have to buy a new system. Which I already did, but I wanted to save my settings and my messages, which is why I was hoping just to replace the handset. So there's no solution to the problem, FYI.
    Genius:
  • 1,665 Answers
Your 's new handset does not communicate with the old base because operate in different frequency. You must take it to a special electronic workshop and ask to tune it to olld base's operation frequency.
Posted on Jun 17, 2008
  • 868 Answers
Your handset has a factory set pin/code set to a frequency in the 1,000 + .You can't do anything to program it your self.It's not going to re-set it's programing no matter what.The idea is so your phone is Privacy-Protected ,so that you have to have the base it was programmed to.Otherwise people would be jumping on your line.Be glad that you haven't found a way to make that work,that is the purpose of protecting your privacy.
    Master:
  • 788 Answers
You should contact FixYa support to request your money back since you solved your own problem. Good Job! You should consider becoming a FixYa expert.
  • 87 Answers
If the new system is the same type as the old one, then make sure that it has the correct settings that the base has... if it does and doesn't work, then this means that the new handset has an upgrade and the old base is no longer compatible. also, if the new handset is not the same type as the base, then it will definitely not work.. you could contact the manufacturer for suggestions or get a whole new system.
  • bill  smith
    bill smith Jun 17, 2008
    please make sure to rate this solution
    Genius:
  • 2,035 Answers
Please unplug the phone for about 30 minutes and set it factory setting and then try connecting it to base................
    Genius:
  • 3,422 Answers
HI,
The first thing you can do is charge the battery pack for 15-20 hrs.Then deregister the handset(see deregister the handset on pg. no. 13 and register the handset on pg. no. 12)
For the user manual please CLICK HERE
Please don't forget to rate or accept the solution.
Goodluck..
  • 1 more comment
  • Priya darshan Jun 17, 2008
    HI,
    Goodluck..
    I told you to charge the battery for 15-20 hrs first.And then proceed with the next step.
    Your phone has eight main
    menu options: DirectLink Mode, Room/Baby Monitor,
    Handset Setup, Base Setup, Answ. Setup, Global
    Setup, Deregister HS and HS
    Registration. You can change
    Room/Baby Monitor, Answ. Setup,
    and
    Global
    Setup settings
    from the base or from any handset.
    DirectLink Mode,
    Handset
    Setup, and Deregister
    HS are only available from a handset.
    Base Setup and HS
    Registration are only available from the base.
    Please reply back.
    Genius:
  • 2,785 Answers
Is the new phone is same as before if yes then resit it again and try by removing the battery and wait for some time and put the battery back.
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Jun 17, 2008
    then it will be better if you send your phone for repair as it is showing no power(plz check out with the suggestion posted by coolguy008 if the problem persists then you can try my suggestion)
  • 96 Answers
Check your new system properly to configure same as your old system.
    Brigadier General:
  • 3,614 Answers
What is the maker/model of your Phone..?
  • micromaster
    micromaster Jun 17, 2008
    you need to re-programmed again your base, so that the new handset will be recognized and work again with your base phone.
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
If you see a "not registered" message on a handset,
you must register it to a base before using it.
1.
On the base, open the menu and select
Register Accy.
2.
On the handset, press and hold #/DND
until the handset display says
Handset Registering (about 2 seconds).
3.
Wait until the handset display says
Registration Complete (about 30 seconds),
then pick up the handset.
If you don't hear a dial tone or the display says
Registration Failed, charge the battery completely,
then try again.
Feb 19, 2015 | Uniden Lands Phones
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
I am trying to replace a handeset on my E5640 answering system. I have followed the procedures to deregister the existing handsets but it will not accept the base code for the last one. The handset I am...
  • Your telephone can accommodate up to four cordless handsets. You can add new handsets (Model E560-2, sold separately) at any time, but each must be registered with the base before use.
  • The handset provided with your telephone is automatically registered as Handset 1.
  • Additional handsets will be assigned numbers in the order they are registered (2, 3 or 4). You can register a maximum of four handsets.
To de-register all handsets
• Unplug the power supply from the base unit.
• Remove all handsets from the charge cradles and base.
• Plug in the power supply while pressing and holding the HANDSET LOCATOR button.
• Continue pressing HANDSET LOCATOR until the IN USE and CHARGING indicators are lit (this could take up to 10 seconds).
• Release the HANDSET LOCATOR button.
• All handsets will display: ENTER BASE ID: XXXXXXXXXX
Once the base indicators turn off (up to 30 seconds), the handsets have been de-registered from the base, and can now be re-registered.
To re-register a handset:
• Make sure your handset batteries are properly installed and charged.
• Your handset will display "ENTER BASE ID".
• Enter the 15-digit Base ID number from the bottom of the base unit.
• Press SELECT to accept the new code and complete re-registration.
To re-register a handset to a new base unit:
• Unplug the old base unit. Your handset will display "SEARCHING...".
• Install the new base unit by plugging it into an electrical outlet and phone jack.
• Press and hold the SELECT key until the handset displays "ENTER BASE ID".
• Enter the new 15-digit Base ID number from the bottom of the new base unit.
• Press SELECT to accept the new code and complete re-registration. The handset is now registered to the new base.
Jun 25, 2011 | AT&T E5640 Phone
Phone has been dropped a few timesaffecting the sound quality in the speaker. Also the back will not stay attched. How do I get it repaired and what is the fee?
Thanks for visiting FixYa!
You have a couple of options that you should carefully consider.
Option 1) Send the phone to the manufacturer for repair. However, when you do you'll probably receive a notice that the handset should be replaced with a new one (because it is beyond repair). Manufacturers would rather sell you a new handset than repair an old one due to numerous reasons. And, the price will probably be much higher than purchasing the handset locally or from eBay.
Option 2) You're going to need to know the exact model number of your phone. There are MANY DECT 6.0 Digital Cordless Phone Models. And, you need the exact model number to replace the handset.
New, replacement handsets can be purchased on eBay for far less than you'd pay for one from the manufacturer. On most phones, a new handset is programmed to the base by setting the handset in the base (not the spare extension charger base - but the main base) for 20 seconds. But, read your user guide to make sure.
If you do elect to send your handset in for repair, (and it can be repaired) I've seen it take from one to two months to get one back. So, keep this in mind when making your decision. The address for service and repair can be found in your phone's owner's manual. Or, you can click on this link to visit the Vtech Support Web page: Vtech Product Support Notice on their web page there isn't an actual link for repairs. As I wrote, they'd rather replace than repair it.
The actual cost for repairs won't be known until the handset is inspected by a qualified technician.
My suggestion is to save yourself a major headache and replace the handset either locally or from eBay.
Apr 19, 2011 | Vtech DECT 6.0 Digital Cordless Phone
I had to purchase a new AT&T cordless phone system since my last set was destroyed by lightening. My old system was CL82409 and my new system is CL82209. I have 3 expandable handsets from the old...
According to the manual starting on page 52, you need to de-register all handsets then re-register the handsets one at a time. The manual covers both cordless model numbers so the handsets should be interchangeable. I have included a link where you can download the manual if you need it.
http://att.vtp-media.com/ecp/documents/product_Product/127/UserManual/1082/cl82209_manual_i3.pdf
Mar 27, 2011 | AT&T Lands Phones
Phone displays a message saying no link to base when it is closer to the base?
Following may be the cause for getting no link to the base.
1. The handset has lost communication with the base unit.Move closer to the base unit, and try again.
2. Confirm that the base unit’s AC adaptor is plugged in.
3. Raise the base unit antenna.
4The handset’s registration may have been cancelled .Re-register the handset.
To Register, follow the below steps.
Headset: Press MENU and then press ‘0’ ‘0’
Base unit: Press and hold HANDSET LOCATOR until the CHARGE indicator flashes.
(After the CHARGE indicator starts flashing, the rest of the procedure
must be completed within 1 minute.)
Handset: Press OK, and then wait until the handset beeps.
Your handset is registered to Base unit.
Thank You
Aug 18, 2010 | Panasonic KX-TG2620 Cordless Phone
Programming old handsets to a new base
Cancel the old handsets registration at the previous base unit if desired.
For additional handsets, you must register each of them at the new base unit. Only one handset can be registered at a time. A handset will be assigned anextension number at registration.
Make sure the base unit and the other handsets are not being used. Program the same way as the extra handset you bought.
Registration must be completed within 1 minute.
Jun 25, 2008 | Panasonic KX-TG2740 Cordless Phone
How do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Jan 27, 2008 | Panasonic KX TGA270S Cordless Expansion...
Handheld won't communicate with the base
i have the same problem and it has happened infrequently several times. you probably have to deregister the handset and re-register it and rest the base and handheld to communicate since my model is different from yours there may be differences in how to go about it but for my model the suggestion is as follows:
go to www.uniden.com for customer support here is a direct link to some frequentlt asked questions http://www.mycusthelp.com/uniden/supportfaq.asp?sSessionID=&lstFilter_a=&lstFilter_b=&lstFilter_c=&txtCriteria=hanset+won%27t+connect+to+base&optcond=2&iStartCount=1
DCT Series Multi Handset Phone - reset to have base and handsets communicate
Question:
I have a DCT Series Multi Handset phone and one or more of the handsets is not working, what should I do?
Answer:
Try resetting the phone system by using the following steps:
1) Enter the "System Reset" menu, then "Deregister HS" submenu.
2) Press volume/up or down arrow keys to select the handset ID to be de-registered from the list, then press the OK soft key.
3) Press the OK soft key. You will hear a confirmation tone. When de-registration is complete, "Deregistration Complete" appears.
4) After de-registering the handset, move to "Replacing the Base Setting" below. When you go through the deregister procedure if you get "out of range", That is okay. Go ahead and go to the next step.
1) Enter the "System Reset" menu, then "Replacing Base" submenu. "Do you want to replace Base?" appears.
2) Press the OK soft key. You will hear a conformation tone. The base information will be deleted. When replacing the base is complete, "Please Register" appears, register the handset to the new base.
If your handset is reading out of range. Check the the main base and make sure you unit has power. This can be done by placing the handset in the main base to see if the charge in use light comes on.
If your main base isn't getting power please make sure the ac adapter is plugged in and is warm to the touch. If not the ac adapter would be damaged.
To resolve out of range follow the below steps.
Press and hold the end key.
Press and hold the # key.
Release the keys and select replacing base and press select.
You will see Replace base?
Select Yes and press select.
Now place the handset on the base and it should register to the base and allow for calls to be made.
Jan 23, 2008 | Uniden CXAI5198 Corded Phone
Uniden CXAI5198 Corded Phone Logo
304 people viewed this question
Top Uniden Lands Phones Experts
Dave Ellis
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
