Question about Nike Imara Strive Black/Silver WC0061 095 Watch for Women
My watch keeps switching to military time...how do I make it stop?
Setting military time
If you mean switch from 12h to 24h and vv,all you have to do is to press the "ADJUST" button until digits on the display blink.Then press the "MODE" button until 12H blinking appears.Press the "START-STOP" button to switch to 24H.When finished press the "ADJUST" button again.
Dec 14, 2013 | Casio G-Shock G-Rescue Tide Graph Watch
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    My watch after a half of day switches over to military time. How do i stop this from happening?
    http://world.casio.com/wat/download/en/manual/
    Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
    Hope this tip helps
    R/
    David
    Feb 11, 2010 | Casio G-Shock Sports Watch
    My TGHK watch is stuck in ''military time'' and I've lost the instruction manual. Any ideas how to get it to am/pm mode?
    advance the hours. The first time you go through the 24 hour cycle, it will be in am pm mode, the second time in 24 hour mode, the next time in am pm. Just keep advancing the hours until it comes up the correct time
    Nov 03, 2009 | Watches
    How do i get my athletic watch off of military time? It's a water resistant watch up to 165 ft. model # aw60447w
    military time:
    1. When setting the time on your watch, IF you watch can change to Military time(and most can)
    2. when you are adjusting the hours go through a full 24 hour cycle. You'll notice that the 2nd time through it is on military time.. 3rd time through back to 12 hour day AM/PM cycle .. 4th time back to Military.
    So you can do this as many times as it takes to get to the right time ..
    In 24 hour time you will see an "H" displayed where you normally see and "A" for AM and "P" for pm.
    Sep 23, 2009 | Watches
    Time confusion
    Possibly you can change it back by pushing the hour-setting button through a 24 hour cycle--you can see if you are on military time during the PM part of setting it. If it's on military, just keep pushing till you start over at 12 am again (hint: that's 0:00 in military.) At least, that's how it is on my watch.
    Jul 15, 2008 | Timex 1440 Nylon watch
    Military Time
    Hello I have the same watch and had the same problem. You press the mode button till you get to the point to change the main time, you then press the reset button (bottom button on right side of the watch)to toggle to the hour place, you then cycle thru the time untill the "h" in the top right hand corners disappears and then the watch will be back on regular time.
    Chris
    Jun 17, 2008 | Bulova Men's Watch
    Timex Mid Size Sports 1440 WR50M
    If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
    Than follow these steps:
    1. Press Lap/Reset and hold. You should see the time the alarm was set for.
    2. While holding Lap/Reset, press Mode.
    3. Let go of all buttons.
    4. There you go!
    Hope that was a help
    Mar 11, 2008 | Timex 1440 Nylon watch
    Set watch
    I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
    Feb 21, 2008 | Watches
    Nike Imara Strive Black/Silver WC0061 095 Watch for Women Logo
    111 people viewed this question
    Top Nike Watches Experts
    Jimmy Accardi
    Electro Med Services...
    Are you a Nike Watch Expert? Answer questions, earn points and help others
