Question about Lexmark X7350 All-In-One InkJet Printer
Where can i find the ink cart - Lexmark X7350 All-In-One InkJet Printer
    Guru:
  • 2,178 Answers
Receiving cartridge error consilt user guide, can you help mke?
Well, without knowing what printer it is or the full text of the error message, or what lead up to your proboem, this is a guess.
Wrong ink cart.
Empty ink cart
Missing ink cart.
Mis-installed ink cart.
Many ink carts have a piece of tape over the contacts or over an air breather hole. This must be removed before installing it.
Some printers have delicate contacts that can be bent or broken if the cart isn't installed carefully.
Jun 29, 2015 | Office Equipment & Supplies
Lines show up throughout print jobs
Your print heads most likely need to be cleaned.
When you don't use your ink carts for a while, when you get new ink carts that have been stored in warehouses for a number of months, or when you have refilled a slightly too dry ink cart, the print head nozzles on the bottom of the ink carts get clogged with dried ink. The printer head cleaner menu will not disolve the dried ink. Water will. Try this. Soak the bottom of the clogged ink cart in 1/2 inch of hot water for 15-30 minutes. Blot dry with clean paper towel(you should see the ink color on the towel). Retry.
Mar 07, 2011 | Dell 942 All-In-One InkJet Printer
My 926 dell printer will not recognize my color cartridge. How can I fix it?
This could be a few things. It could be dust or some debri blocking the connection. take out the ink cart and use a lint free cloth to wipe off the copper looking contact. if that doesn't work then it's one of 2 problems. it's a bad ink cart, or the printers sensor is bad. It's usually a bad ink cart. If the ink has been refilled, then i guarantee that's the problem. Best thing to do is buy a new ink cart. If that fixes the problem then you are set. if not, the printer is faulty. Dell's ink carts have a 2 year warranty. If the ink cart is under warranty, then they should be able to replace it. Just be sure to tell them that another ink cart resolved the problem. If the printer is the problem and it's out of warranty. pitch it. Dell is gonna charge somethign like 29 dollars to troubleshoot and tell you the same thing. If it's still under warranty, the of course, call dell and get it replaced.
Oct 28, 2009 | Dell 924 All-in-One InkJet Printer
Canon MX850 willnotprint from Large Black Ink Cartridge - PGI-5BK
Ink Carts do act finicky at times. Especially Canon carts.
In many cases, the ink carts have a small fuse built into the back of the cartridge that opens up if the cart has been removed for any reason. Replacement Carts come with the fused portion reset, thus when you insert it into the printer, it works great. If the cart is FULL, it still may not be observed as full or new by the Printer itself. Best way is to use a new cart, not necessarily a Canon Brand. Use an inexpensive company like
https://www.carrotink.com/canon-pgi-5-cli-8-combo-10-pack-ink.html
Feb 15, 2018 | Canon PIXMA MX850 Multifunction Printer
My machine keeps saying No cartridage Open scanner cover then reinstall ink cartridage
This can sometimes happen when a cartridge becomes completely empty (but this shouldn't happen with original Brother ink carts).
Are you using Originals or compatable/refills etc?
If the ink carts all seem ok:
Take out all the ink carts and close cover.
Switch off power and wait a few seconds.
Switch power back on.
Machine will prompt you to install each cart.
Do this individually untill all carts are back in machine.
If this does not solve the problem (and you are 100% the ink carts are not faulty) the machine requires engineer to repair.
Jun 15, 2009 | Brother MFC 420CN All-In-One InkJet...
Ink Leaks
Richard,
I dont understand "inverting". Do you mean turning the machine around (180 degree) to see the bottom of the machine?
Anyway, inkjets used to stain after a while. This is because of serveral reasons: the ink absorber felt is getting wet due to the cleaning cycles, some ink will splash from the printhead, ink will flow back from ph to cart etc.
Do you refilled the original carts or do you use generic carts? The latter one do NOT keep the ink inside the cart when turing the machine to bottom (e.g. for Postal sending) due to diffrent construction.
You should use original carts for refill. Make sure the plastic support secures the carts.
Only original carts wont leak!
Mar 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC440CN
Did you use generic ink carts? If yes ink has stained the led control. Try to clean it by help of a towel. In some cases this will help. If not, the led control needs replacing!
Another solution:
Did you answer the question given by printer when changing the cart?
You might take all carts out, unplug machine from power outlet. replug to power. wait until machine demands carts. Place cart in and answer question.
Feb 22, 2008 | Brother MultiFunction Center MFC-440CN...
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
Printer problem
Try to unplug the printer from power. Wait a minute. Take all carts out. Close ink cover. Replug printer to power. Machine demands carts. Insert carts as demanded.
If you still have this error this could be due to generic ink carts. Ink may have stained the led control and the ink assy has to be replaced!
Nov 10, 2007 | Brother DCP 130C All-In-One InkJet Printer
Edweard
Take all carts out. Close cover. Unplug machine from power. Wait a minute. Plug in machine to power. Machine demands carts. Insert new (!) cart as demanded from machine. In case when asked push 1 for YES: cart changed.
BTW:
Always print until machine stopps printing. Display says NO INK XY. After replacing the cart machine will print the rest data out of its memory.
NEVER change cart when machine says low ink (This is only a hint to buy a new cart!). At this point the cart has about one third of ink left!
Nov 01, 2007 | Brother MFC 420CN All-In-One InkJet...
Lexmark X7350 All-In-One InkJet Printer Logo
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
