Question about Montgomery Ward Refrigerators
What size is Montgomery ward HMG 198242C - Montgomery Ward Refrigerators
2 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: montgomery ward refrigerator freezer side by side model hmg 2164
Hi there!
Was the bulb blown that you removed?
If not, it may be the contact switch on the door. These usually are just a press fit, sometimes needing a screwdriver in a slot to release it.
Hope this helps you. If it does, Please take a moment to rate your problem fixed with Fixya! Thanks.
Posted on Jun 17, 2008
What size needle does a Montgomery Ward sewing machine model UHT-J-1917 use?
The needle size depends on whatever thread and fabric you use.
Apr 02, 2017 | Montgomery Ward Sewing Machines
Montgomery ward side by side HMG 229637B ... defrost timer does not cycle ... have relaced defrost timer .. STILL DOES NOT cycle ...if i manually cycle coils heat ... defrost etc etc BUT refridgerator does...
turn the allen screws one is under the hindge side of freezer door and one is under fridge hindge side of door turn counter clockwise be carefull turn to far the adjustment screw will come out of the wheel adjustment bracket.also try having someone tilt refrigator back by pushing top of refrigator then turning the two white adjustment screws in same area of allen screw this adjust the front of the refrigator you may want to adjust the front adjustment so the refrigator is slightly tilted to the back this will help close the doors.
Jan 22, 2014 | Montgomery Ward Refrigerators
Water collecting in bottom of refrigerator side under meat keeper. Wards model no. HMG 2290
Check to see if your ice maker is not leaking water. Otherwise, the problem might be a clogged drain in the freezer. Need to remove the back cover in the freezer to check that the drain is clear. If it is clogged, try removing any blockage that you see and push wire down the drain tube to clear any blockage in the tube.
Oct 04, 2010 | Montgomery Ward Refrigerators
I have a Montgomery Ward Snow Thrower Model 495A. A rope got caught in the auger. Now the motor runs but the auger will not turn. Any idea what was broken and where I can get parts to fix it?
I have an older Montgomery Ward Snow Thrower model No. TM0-35286A and I'm having a hard time finding parts for it. The tiller just stopped working so I'm thinking the worm-gear is shot, but I can't even find the part on-line...Can you help?
Dec 10, 2009 | Montgomery Ward (223600UP) Heater
I need to know the correct size for the auger belt Montgomery ward TMO 35275B 1274B
I'm not sure which belt is which, but one belt is 3/8" x 29.0" long and the other one is 3/8" x 38" long
Nov 03, 2009 | Montgomery Ward (223600UP) Heater
My Ward, HMG - 1400 - 0, refridgerator coils will ice over
Make and model numbers are important to give answers.
Jun 19, 2009 | Montgomery Ward Refrigerators
Refrigerators Logo
29 people viewed this question
Top Montgomery Ward Refrigerators Experts
John Tripp
John Tripp
john h
ray gallant
Are you a Montgomery Ward Refrigerator Expert? Answer questions, earn points and help others
