Question about Crosley Washing Machines
Front load crosley washer-door is locked, unable to open,wash inside washer one year old
  • plarsen2 Nov 10, 2010
    i open the lower front panel and could not locate the cable, found a rubber tube with stopper. not locating the contral panel on top front only noticing the area to add the soap and the area that read the wash information
  • 1,531 Answers
Use a wet dry shop vac and attach it to the end of the drain hose and remove all the water this will unlock the door.then you need to look at the drain pump and look for any obstructions that may be blocking the flow of water or stopping the impellar wheel.
Posted on Nov 13, 2010
    President:
  • 2,468 Answers
Remove the control panel on the top front of the unit,there will be a plastic cable there to manually pull to unlock the door,on some models this cable may be accessable with the lower front panel removed below the front door
Posted on Nov 10, 2010
2 Suggested Answers
  • 2468 Answers
SOURCE: crosley front load washer one year old. doored
your drain pump or hoses are blocked with foreign material,either coins,hairpins,detergent residue from earlier washings,remove the front lower access panel if provided to access the drain hoses and pump and also check the drain itself,some washers have the access door in the back side of the machine,if the stand pipe in the house is slow to drain it can back up and cause back pressure and the machine will sense this and stop also
Posted on Nov 11, 2010
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
I HAVE A CROSLEY FRONT LOAD WASHER AND THE DOOR WONT UNLOCK, I HAVE TOWELS INSIDE, HAVE TRIED RUNNING ANOTHER CYCLE, PLEASE HELP
I have had that happen a couple of times and by hitting the pause or cancel button a couple of times it then opened.
Mar 05, 2014 | Crosley CW6000 Front Load Washer
Unable to open door
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jul 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
UNABLE TO OPEN DOOR AFTER WASH
Apr 08, 2010 | Hotpoint Aquarius WD640 Front Load...
Door is open, lock is engaged.
Solved - installed new door locking assembly.
Sep 18, 2009 | GE Energy Star WCVH6260F Front Load Washer
Clothes locked inside the machine
There is a mechanical lock so you can't open it when running. make sure the switch is off but machine is plugged in. push the door in with a little bit of pressure and with the base of you hand give it a few gentle "thumps around the area of the opening handle it it likely stuck from you trying to open the door in the locked position. Hopefully that will knock it loose (I've seen it before you will probably here it click)
Aug 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Crosley digital front load washer
jus try to lubricate the lock n then try.... it wil work
Jun 17, 2008 | Crosley CW5000 Front Load Washer
Frigidair front-loader washer door remains locked
there is an Emergancy release you can pull to open the door it is either in the soap dispenser area or behind the front lint clean out door depending on your model
Mar 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
95 people viewed this question
Top Crosley Washing Machines Experts
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
