Question about Philips DVP642 DVD Player
Hie i have a philips dvd hts3366/98 and it has a flashing red light on the power button. i cant see a bulging capacitors or brown leaking fluid. i also cant find c316.could it have a different location on my board coz i mostly have c9xx and so on..please help
techman
  • 3130 Answers
SOURCE: philips dvd player not working
Im sorry to tell ya that you did all the things I would have suggested, so it sounds like a system control problem or a power supply problem, and if its a good machine then maybe its worth you having a service person look at it?? Most dvd units are not worth it these days, unless there combos or recorders.. Sorry couldnt be of more help.
Posted on Jun 05, 2006
markevans
  • 148 Answers
SOURCE: DVD stuck inside, player won't turn on, standby light does NOT flash
test the capacitor with a meter to make sure it has the value stated on it.
the work on this unit is quickly exceeding its present value, most likely.
consider upgrading to a higher resolution unit if the fix is more expensive in parts and time than a new unit costs.
good luck
mark
Posted on Dec 29, 2007
  • 396 Answers
SOURCE: Philips HDRW720 won't turn on
I think Philips must have a timer on this unit to fail, I am also having the same problem and I think the hard drive failed. I currently have installed a new drive and held the play and open close buttons down when the power comes up. It will ask for a cd to be installed when initializing the drive. I am currently searching for that cd and will let you know if any luck with the install.
Posted on Jan 01, 2008
SOURCE: Philips HDRW720/17 won't turn on
I have a DVDR725H, which is the same as a HDRW720 but has a 160GB hard disk.
This error code (FAIL 0900 05) is displayed when the DVD drive has been completely removed/disconnected or is not responding.
Note that the DVD drive (VAD8041) is apparently known to have its DVD motor driver chip (SA56202TW) getting destroyed due to overheating. There is a repair kit available (about 10-15 EUR) that comes with a zener diode and two capacitors (order number 996500029182).
Note that it might be easier to get some used philips DVD+HD product that has the same DVD drive, e.g. the DVDR610 or DVDR615 and use that as a replacement.
Posted on Feb 19, 2008
  • 4 Answers
SOURCE: refurbished philips dvp642/37 playing and stops playing
the problem is not the power supply capacitor. it will eventually fail, and need to be replaced, but when it does you'll know it because you wont be able to use the DVD at all. it wont turn on, and the standby light will just flicker.
the problem is that your mechanism/lens is probably dirty or dusty or out of alignment.
this device is kind of sensitive moreso than other players. by "sensitive" i mean "cheap"
try cleaning it with soft, lint-free cloth, and windex.
clean your disks as well.
if that doesnt work, you may just need to buy a new DVD.
at $60 its a good deal, even if some of them do crap out too soon. you can spend more $ on a better quality player if this fact bothers you.
Posted on Mar 09, 2008
42" plasma worked fine this
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Sep 15, 2011 | LG 42PC3D 42 in. Plasma Television
Philips DVP630 won't switch on. It started being 'sticky' opening the DVD tray. Now we cannot open the DVD tray. We also can't even switch it on. When you press the on button, it flickers off and on for a...
I had the same problem and I realized that it is a common problem on Philips DVP 630/642/37 series DVD players..As Power problem..A blinking red power button urges you that there is a malfunctioning capacitor in the circuit board.
This is actually surprisingly easy to fix. but it needs soldering iron before.any attempt. Here are the steps .The decision to try this is up to your own discretion and may be a last ditch effort before throwing the player away.
Unplug and take the metal cover out (plenty screws on side and on the back): Check the board to see if capacitor numbered as "C316 "is bulging-/leaking. If so, get a 1000u capacitor >=16V and replace it..
If you cant do it find a handy man nearby you and ask him to do it..It takes just 10 minutes but you must obtain the capacitor from Radio Shack (2.00 USD) before you begin..
Take care and do not forget to rate me too..Thanks
Jan 30, 2011 | Philips DVP630 DVD Player
Philips HTS3010 not powering on and the power button LED keeps blinking and and click sound from DVD while power Led blinks Help me on solving it.
Hi,Even your DVD is newer version but would you please try the following solution that I provided for someone else....It may help..Because ,when a capacitor in the power circuit board fails, power led blinks and tray sticks too..So take care.
Dec 09, 2010 | Philips HTS3450 System
My DVD Philips 630 player power led blinking only and there no start tell me what is a problem and what to do about the same Thanks.
I had the same problem and I realized that it is a common problem on Philips DVP 642/37 series DVD players..As Power problem..A blinking red power button urges you that there is a malfunctioning capacitor in the circuit board.
This is actually surprisingly easy to fix. but it needs soldering iron before.any attemp. Here are the steps .The decision to try this is up to your own discretion and may be a last ditch effort before throwing the player away.
If you cant do it find a handy man nearby you and ask him to do it..It takes just 10 minutes but you must obtain the capacitor from Radio Shack (2 USD).
Sep 02, 2010 | Philips DVP630 DVD Player
Loud pop and then no picture..only a red light
Hi
Hope this helps
Aug 16, 2010 | Philips Televison & Video
The tv dosen't turn on, it just makes a clicking noise and the red light flashes.
Hi
Hope this helps
Jul 30, 2010 | Samsung Televison & Video
Can't turn on TV.
Hope this helps
Jun 12, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
The red standby light is flashing and i cant turn the tv on
Ur power supply board is dead.U know basic electronic's and soldering?Most of the times,the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
May 07, 2010 | LG 42LC2D 42 in. LCD HDTV
I have 40? LCD Samsung flat screen TV model: LE40A557. This is 16 months old. Today the screen went blank and power indicator light blinks. I have switched the TV off and removed all equipments attached. I...
check power supply capacitors..i repair these every day and the power supply is prone to faulty capacitors..the capacitors should have flat tops and if they are bulging or leaking brown fluid, replace
Oct 17, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
No pwr
the flashing red light is caused by a burst or bulging capacitor on the power supply side of the dvp642's mainboard.
to fix it simply dis-assemble the unit removing the mainboard totally from the casing. search for the bad capacitor on the main board. once you have found it simply turn the board over and using a soldering iron and some desolder twine desolder the capacitor from the board being careful not to burn the circuit board or lift any traces.once you have removed the old capacitor take it and purchase a replacement from radioshack or equivalent store. make sure the replacement has the exact same voltage rating and AT LEAST THE SAME AMPERAGE higher is ok lower will not work.but the voltage must be exactly the same. resolder the new capacitor to the mainboard and reassemble and viola your up and running again
Mar 29, 2009 | Philips DVP642 DVD Player
Philips DVP642 DVD Player Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
