Does not stitch right have big loops of thread on the underside of material. Take it in and they fix the tension but it doesn't last. Is this an ongoing problem with this machine?Does not stitch right have big loops of thread on the underside of material. Take it in and they fix the tension but it doesn't last. Is this an ongoing problem with this machine?
AnonymousMar 30, 2014
No matter what I do I cannot get it to improve end up taking it in for adjustment. Get it home and pretty soon it is back to the same thing. Thread usually all tangled, big loops on the underside of material.No matter what I do I cannot get it to improve end up taking it in for adjustment. Get it home and pretty soon it is back to the same thing. Thread usually all tangled, big loops on the underside of material.
You can't post conmments that contain an email address.
You don't have the thread in the take up lever or it is not in the tension. Rethread it , Pull the thread through the tension assembly and
test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way. set your tension to 5 and try it. sewman7
Although there could be several reasons, this is generally called bird nesting or thread nesting. It is usually a result of loose upper tension, mis-threading, or possibly a needle/thread/fabric incompatibility.
#1--when you thread, make sure you ALWAYS raise the presser foot so the thread seats in the tension disk. And, be sure to change the needle often...
the looping on the underside sounds like a needle thread tension problem. 1st off check top (needle) threading then turn machine by hand to pick up bobbin thread
try a new needle try a different thread top and bobbin try adjusting the top thread tension one number or letter at a time higher sewing on a scrap piece of paper till the stitches look normal make sure the top thread does not come off the thread take up lever
Take the thread off the top of your machine and rethread it. Anytime a sewing machine bunches up the thread on the bottom the cause is the top thread. Make sure the tension dial is on "5". After you thread the machine, put the pressure foot down,(like its resting on fabric, but not on the thread), and pull the thread towards the back of the machine. It should be somewhat tight. The needle should "bow" slightly before the thread comes through the needle.
I discovered that when the thread is knotting up on the underside of the material that it is usually the threading on top and has nothing to do with the bobbin.
