Question about Toshiba TLP-WX100U LCD MOBILE PROJ WXGA 600:1 16:10 2200 LUMENS 4LBS Projector
I have the model TLP WX 2200 and doesn't turn on and after a few minutes, the ON led is green, is blindnig and a bip is heard. After a while, the two of three leds ( on and lamp ) are getting red. What must I do ?
  • 10,594 Answers
It seems lamp is dead/ broken in projector, please check lamp and replace it to fix the problem.
There is lamp cover at bottom side of projector, remove lamp cover to take out lamp.
Detailed procedure of lamp replacement is written in user manual page-45
Click Toshiba Support link to download user manual free copy, if required.
Thanks.
Posted on Nov 10, 2010
WX 435 Motorola was working fine a few minutes ago then it just off and won't come back on or charge. What happened?
Sometimes if the battery is dead you need to leave it plugged in for 5-10 minutes before it will "come back to life"
If that doesn't work, unplug it, take the battery out, wait a few minutes, then put the battery back in and let it charge for a while.
Also try another charger.
Nov 13, 2012 | Cell Phones
Iview 2200 led tv
If it's a GE universal remote and it doesn't have the brand name iview in the manual with the code then you can't use the universal remote with it. I also have a GE universal remote and no matter which model of GE remote you get they have the same codes. I have never heard of iview so I doubt it will work. You can try and see if there are any original remotes for the iview on ebay though.
Oct 28, 2012 | Iview 352PTV TV
Will not power on
if all fan are spin up.
see your RAM, maybe its broken.
a computer need a routine checking all RAM, if its not good, your computer will freeze.
try pull out and put it again. if its doesn't work. replace it.
PS. when you pull out your computer with all RAM pulled out and doesn't heard any BIP BIP BIP (BIOS POST CODE) noise. I can Assume your Mainbpard or ypur processor is broken. maybe its sound scary but its not. see for computer service center to help, they can give you good advice.
May 09, 2012 | HP KT334AA Pavilion Media Center M8530F...
I swapped my ps3 to an hdmi cable and now i want to swapp it back to the rca cables how do i do it ??????
with the playstation off put your finger in the on/off switch you will heard one bip ( this is when the playstation turns on) keep your finger there in the on/off switch ultil you hear a second bip now remove your finger and this second bip is when the ps3 video settings are reset it should work again on rca just way a few seconds and your will see the screen again on rca
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
TLP 2844-Z is faded on the right half when it prints
It probably needs a print head adjustment or calibration.
Here is a link for the user guide,(it takes a minute to load and display) you will find cleaning and diagnosing tips :
http://www.systemsprintmedia.co.uk/downloads/ZEBRA%20TLP%202844Z%20MANUAL.pdf
If your zebra label printer is not feeding to the next label correctly it may need to be calibrated. Follow these steps to calibrate the printer:
  1. Turn off printer and have media loaded (on older Transports, with no ON/OFF switch, remove battery).
  2. Hold feed button down, and turn printer back on (on older Transports, re-insert battery) while holding down the feed button.
  3. When the light starts flashing, release the feed button.
  4. Printer light will turn green and advance a few blanks.
  5. After printer stops advancing and prints the internal information, press the feed button one time.
  6. You will get another label with the “Out of Dump” message on it.
  7. Printer is now ready for use.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 21, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
These 2 links will help you troubleshoot the problem:
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Warning bad connection charger
charger is broken...get a new charger or charge it on pc via usb cable provided....hope it helps you guys....
Nov 07, 2008 | Dual Electronics N99i Cellular Phone
Power on
Hi
You need to open up the camera again and check all the connections for the cables and make sure everything is connected properly. Most likely it's just a cable that isn't plugged in properly.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
May 30, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Unit turning off after displaying red pc chip icon
Hi whitiezn
If you say that this unit is very new , it should on all accounts still be under warranty.
Contact your local Toshiba Service Centre and have this problem sorted out on their account - the machine should still be under warranty.
May 05, 2008 | Toshiba TLP-ET1 Multimedia Projector
LP 2824
Here's the right way to fix the problem.
Autosense Procedure, Configuration Label and Dump Mode:
Models: Orion (2442, 2443 and 2543), Transport (P-2242), Xport (P-2222), LP/TLP Strata (2684), LP/TLP-2722, 2742, 3742, LP/TLP-2824 ,LP/TLP 2844 and TLP-3842
  6. You will get another label with the "Out of Dump" message on it.
Oct 10, 2007 | Zebra Eltron LP 2824 Thermal Printer
Toshiba TLP-WX100U LCD MOBILE PROJ WXGA 600:1 16:10 2200 LUMENS 4LBS Projector Logo
98 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
