Question about Texas Instruments TI-84 Plus Calculator
I have the TI Nspire and cant seem to get the right answer for ln2 divided by 4 ln 1.0125. I guess I dont know how to input it, because I tried another problem that I had the answer for and entered it in and got the wrong answer. I have a test tonight and need to know how to do this!!
  • Texas Instru... Master
  • 8,081 Answers
Sorry, it may be too late for your exam, but here is the answer.
You should enclose the 4ln(1.0125) in parentheses otherwise the calculator will interpret your expression as ln(2)/4 times ln(1.0125).
Here is screen capture that shows you how it is interpreted.
On the top line you have ln(2)/(4*ln(1.0125)), on the middle line ln(2)/4*ln(1.0125), and on the bottom line you have 0.25*ln(2)/ln(1.0125).
Posted on Nov 11, 2010
My ti-nspire cant solve this second order differntial eq. x''+7x'+12x=4/k and x(0)=0 and x'(0)=4/k,t,x
You have to type:
deSolve(x''+7x'+12x=4/k and x(0)=0 and x'(0)=4/k,t,x)
Then enter. See captured image below
Jan 04, 2013 | Texas Instruments TI-Nspire CAS with...
TI nspire wont divide
Press CTRL-Enter to get a decimal result
Sep 20, 2012 | Texas Instruments TI-Nspire Graphic...
I am trying to find the solution to the problem ln(1/2)/5715. the correct answer is .000121 my TI 84 is returning the sum of -1.21285596E-4
That looks like the correct answer. The natural logarithm of 1/2 is about -0.693. That divided by 5715 is about -0.000121
Dec 12, 2011 | Office Equipment & Supplies
How do you put the batteries in?
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Remove the keypad (for TI-Nspire Family or TI-Nspire CAS Touchpad) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and then back off). If the TI-Nspire/TI-Nspire CAS is a Clickpad, hold down [Home] [Enter] [P], and while holding these keys, press [On]. If the TI-Nspire/TI-Nspire CAS is a Touchpad, instead hold down [Doc] [Enter] [EE], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 1, 2, 3, and 4 in that order. ** The [Home] key is located at the top right of the TI-Nspire keypad and has a picture of a house on it.
Aug 26, 2011 | Texas Instruments TI-83 Plus Calculator
Screen Failure
Here is what the TI knowledge base says about a calculator failing to turn on.
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Sep 16, 2009 | Texas Instruments TI-Nspire Graphic...
My calc wont turn on at all no matter what i do.
Try these, courtesy of the TI Knowledge Base
Jul 23, 2009 | Texas Instruments TI-Nspire Graphic...
My TI-nspire CAS doesn't want to go on! I changed batteries! Tried the contrast buttons! Nothing works
Try the other recipes from the TI knowledge base concerning a calculator failing to turn on
Jun 10, 2009 | Texas Instruments TI-Nspire Graphic...
Mar 08, 2009 | Texas Instruments TI-Nspire Graphic...
Reposting! exponential and log equations
Use this entry sequence:
4 LN / ( 4 LN - 2 X 3 LN ) =
or this one which evaluates the divisor first
4 LN - 2 X 3 LN = 1/x X 4 LN
Dec 14, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-84 Plus Calculator Logo
209 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
