Question about Whirlpool AWZ412 Front Load Washer
I have a AWZ 412 and Im trying to remove the drawer as it is completely clogged with fabric conditioner. I have removed the 3 scews but it still not coming out. Is it possible to remove? Many thanks Kate
  • Whirlpool Master
  • 12,061 Answers
Http://elektrotanya.com/whirlpool_awz_412.pdf/download.html
Hi at the above link is your service and repair manual for your unit, inside it gives you a complete parts breakdown on all components so you can see for yourself what to do.
Posted on Nov 11, 2010
Excell 7 VarioPerfect: fabric conditioner compartment will not drain
perhaps you need to contact Bosch website for tech support
Sep 21, 2016 | Bosch Washing Machines
Why does the fabric conditioner compartment stay full of water after wash has finished ?
The compartment has to be flushed to prevent conditioner residue from hardening and clogging it.
Apr 16, 2016 | Washing Machines
Hotpoint aquarius washing machine is not releasing conditioner from drawer
this is an easy one for me as this was happening with my same machine it was under a 5 year guarantee and i got a professional hot point approved repairer out he didn't even take his tool box out as this is an easy repair and a consistent bung up area
remove detergent drawer look up on at top of drawer holder and you see a small hole see picture (if i can upload picture) unbend a paper clip and push up hole removing the gummed up fabric conditioner while your in there spray tunnel with bleach and scrub with hand brush to remove black gunk from tunnel and flush
put draw back and should take fabric conditioner as normal as you have freed pipe were water is injected to flush out fabric conditioner
Aug 03, 2014 | Hotpoint Washing Machines
How to remove despenser tray from awz 410 -1000 spin washing machine .i am unable to do it. water filled in tray
I suspect that it is the conditioner/softener tray which needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 17, 2011 | Whirlpool AWZ410 Front Load Washer/Dryer
The problem is simple: the fabric conditioner I put in the drawer compartment isn't draining into the main drum ... is still in the drawer when I empty the machine of my washed clothes. I've cleaned lots...
Sorry to ask and please don't take this the wrong way but did you manage to remove the whole dispenser drawer and clear out the siphoning tube in the conditioner tray when you cleaned the 'gunk' out? If not please try the following guidance notes, paying particular attention to the bit in bold near the end ;-0)
One of these should enable you remove it
(I am having to guess some of the following!)
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
Good luck,
John C
Mar 22, 2011 | Washing Machines
I have a Kenmore Elite HE52 front load washer that the fabric softener does not want to dispense. I took the dispensing drawer out and washed; does not appear to be clogged. I can hear the water running...
Although you washed the drawer I'm thinking that the conditioner part may still be blocked. I would gently suggest you follow the guidance below
(Sorry these are my pre-typed general complete guidance notes)
Good luck,
John C
Mar 05, 2011 | Kenmore Washing Machines
Samsung WF328AAW front loading washer, about 3 years old. Having persistent scum build up on the multiple water inlet holes that flush the fabric softener from the dispenser into the wash. Have tried...
I put my fabric conditioner in drum in one of those plastic tubs u get with persil liquid. I was fed up cleaning the drawer with steamer and toothbrush. Maybe someone has some more technical advise but find this works for me
Regards
May 09, 2017 | Samsung WF328AAW Front Load Washer
Fabric conditioner section in draw always full with water after cycle has finished
Detergent drawer is clogged with soap. to remove look for small plastic clip on the inside above the detergent drawer which needs to be released. Remove detergent drawer unit and wash thoroughly under running water, or bucket. Replace and problem should be solved until it gets clogged again.
Jan 15, 2011 | Bosch Classixx WFC 2465 Front Load Washer
Fabric conditioner compartment doesnt empty properly. Ive tried cleaning out drawer but still no luck.
If you can remove the dispenser from the machine try soaking it in HOT water. The fabric softeners can cause a wax like build up that can clog the dispenser. If the dispenser will not come out of the machine then pour Hot water into it, cycle the machine and repeat. It took a long time to clog and will take a while to remove the clog(several cycles). This will work but will take time. Mix water with your softener to keep it from cloging again, it will thin the softener and stop the build up. If you add 50/50 water/conditioner shake well and use twice the normal amount so you are getting the full amount of softener/conditioner into the washer. This will help i had a similar problem with my front loading washer.
Oct 17, 2009 | Washing Machines
Fabric condition not emptying
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 29, 2009 | Washing Machines
Whirlpool AWZ412 Front Load Washer Logo
284 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
