My Hisense TC 2919 H model 74cm is cutting picture on top and bottom ( heads and writings ) how will I solve this problem
4 Suggested Answers
rsheehan
  • 69 Answers
SOURCE: Phillips flat screen 27 inch screen cuts off top and bottom
horizontal over scan , one H.V. cap is out of tolerance in hoz deflection
Fair Cost to fix 75.00 could be a few leaky diodes to. in addition to the cap
Posted on Jul 01, 2009
joez47
  • 61 Answers
SOURCE: My Hisense TLM3233D 32 in flat screen suddenly has
It sounds like you have inadvertently changed the screen size setting. This is usually in the "set-up" section when you select "menu" on your remote. It may also be labeled as "zoom" or "view mode".
Posted on Sep 13, 2009
bshldn
  • 736 Answers
SOURCE: picture too large for screen
It appears that on this television you can only adjust the picture size when you are using the twin picture feature. You must adjust the picture size with your other remote control. Since I do not know whether you are connected to a cable box or a satellite tv box or a blu ray player or a DVD player I cannot be very specific. On your other remote control you should had an hd zoom button, aspect, format, ratio, #, or etc. Those buttons change the picture size. The other factor determining picture size is the resolution the equipment connected to your tv is set to. This tv supports 1080i but you should also try setting the connected equipment to 720p or 480p or 480i. Also the connected equipment may be connected to your tv in two places so make sure you are on the correct selection using the tv video button on the Sony remote.
Posted on May 06, 2010
Pictureis too big for screen
go to your settings and check tv resolution,tv display and tv ratio
Feb 17, 2014 | Hisense Televison & Video
I need to move the picture up on the tv
Sounds like a possiable Tcon board problem but what is your model number?
Feb 05, 2014 | Hisense Televison & Video
I have a panasonic model number TC-P42X1 and i have no picture or sound. and the red light flashes every 4 seconds none stop
I had a similar problem with my Hisense TV and I replaced the "Main Board". Got the part on ebay. Don't know if this will help.
Jan 02, 2013 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
My Hisense TLM3233D 32 in flat screen suddenly has started cutting off the heads of people and i cant read the writing at the bottom of the screen. I have done a factory reset through the menu and tried...
I use a digital satellite television decoder and the aspect ratio on the decoder was set incorrectly. After speaking to the DSTV helpdesk they assisted to set the aspect ratio to the correct setting.
Jan 02, 2010 | Televison & Video
Picture is cut off at the top and bottom of the screen - The top of the head is cut off and any writing on the bottom Help!
Look on your remote to see if you have a picture butto or you can try and go to the menu settings and see if you can adjust the tv format from widescreen to regular or 4:3 or 16:9
Sep 23, 2009 | Televison & Video
My Hisense TLM3233D 32 in flat screen suddenly has started cutting off the heads of people and i cant read the writing at the bottom of the screen. Have i pushed a button somehwere without realising it....
Sep 11, 2009 | Televison & Video
Jun 30, 2009 | Philips 21PT4475 TV
TV picture aspect ratio
No. Aspect Ratio is same for UAE and India, and also the broadcast System.
Most Cable TV operators in India broadcast the signal 'slightly oversized, and so the viewer gets the Scrolling at the bottom and top of the screen cut-off.
Nov 29, 2008 | Panasonic TC-25P22R 25" TV
Hisense color TV ±74cm, Model TC2919H
I HAVE A PROBLEM IN THE PRIMARY POWER SUPPLY STAGE HAVE CHECKED ALL COMPONENTS AND RELACED STRG96...IC AND OPTO COUPLER .
CAN U LET ME HAVE A CIRCUIT DIAGRAM?
Sep 04, 2008 | Televison & Video
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
