Question about Nokia 1600 Cellular Phone
Ringing dont work but I listen other person when they call me. I verify setting, ringing volume and the profiles was'nt silent.
  • 3 Answers
Hi here is the solution for ur problem process is here click on menu-----go to setting and go to tone setting there is a option like ringing alerts click on that and select continuous ringing ok .
Posted on Jun 17, 2008
2 Suggested Answers
SOURCE: sonnerie absent but I listen other person
when mobile switch on speaker work but when dialing it not working and when loudspeaker on it works of nokia-1110
Posted on Jun 26, 2008
I have a galexy s, i have no ring on incoming calls
may be your ringing volume is set to zero. to check, go to profiles. select personalize option for the activated profile(general) increase the ringing volume.
Nov 17, 2011 | Cell Phones
Nokia 1661 not ringing solution
chrisgazb,
please try below options:
1) verify that your profile is not set to silent (vibration/meeting) mode
2) verify your ringer tone volume is not set to minimum
3) last option is to visit the service center
Aug 16, 2011 | Nokia 1661 Cell Phone
When i put my silence tone, the ring call is silent, by the messege tone is still ringing. How to set it up properly. Tq for your kindness to guide me what i should do.
Aslim, go to your profiles, select silent, before you select *activate*, select *personalise* in the ringing tone panel, select *no tone*, in the ringing volume panel, reduce the volume to nothing. In the message volume panel, reduce the volume to nothing also. Then select *save*. Then you can activate silent. This should help.
Apr 07, 2011 | Cell Phones
I have LG GM205 phone and have 2 problems.\r\n1st
Change profile to silent, then go back into general profile & select 'personalize'. Go to Keypad Tones & turn off, then click back & select 'activate'. You should now have no keypad noise and the phone should ring.
Jun 04, 2010 | Cell Phones
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
My LG VX-8700 does not vibrate. Ring works, but vibrate mode is the same as silent mode. Can this be fixed?
Yes,
What happened is you probably set it on silent and from the soft keys, you increased the ringer volume. What you want to do is go to main menu => settings => profiles, and from there make sure your ringing volume is set on lowest possible.
Oct 28, 2009 | LG VX-8700 Cellular Phone
My phone has no song at all
Hi Kathnicks2
Have you checked your profile if its in silent mode? Also check the settings and in that check if you have selected the incoming call alert as ringing or vibrate. You can also check if your mobile is ok by trying to listen to ring tones in general. So, if you are not able to just listen to ring tones, then you will have to meet a service person who can get it right for you.
Nov 19, 2008 | Nokia 1100
Motorola Razor -Silent Mode
what you have to do is customize it as silent mode by turn the ringing volume down and turning the sounds off. this can be done in profiles.
please rate me. thank you.
May 26, 2008 | Motorola Mobility RAZR V3
Nokia 1600 Cellular Phone Logo
66 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
