Question about General Electric GE 24-Hour Power Strip Timer #57698
We have grow lights and a pedestal fan plugged into the timer. Lights and fan are set to come on at different times. When the fan comes on, so do the lights. But, when the lights come on, the fan does not. Any ideas what is going on here? Amps and wattage are not a problem. It's a GE Power Savings Strip Timer 15077 purchased from The Home Depot. We returned the first one and are on the second one and still have the same problem.
SOURCE: setting GE Plug in mechanical timer 24 Hr Model
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Posted on Dec 18, 2009
SOURCE: how do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Posted on Dec 21, 2009
SOURCE: I have the GE Plug in Mechanical Timer Model
We had the same problem when we first tried to set our timer. Although we have a newer model, this might work for your timer as well. The pin for each 1/2 hour interval that you want the device to be "on" must be pushed toward the perimeter of the dial, not the center of the dial. For each 1/2 hour interval that you want the device off, the pins should be pushed toward the center of the timer. Don't forget to move the arrow on the dial to the current time just before plugging in the timer. Be sure the switch on the side of the timer is moved to "timer on", the override is "outlet on" for when you want your device to come on during the time that the timer is set to have your device turned off.
Posted on Dec 31, 2009
SOURCE: when one timer on my
found a link for PDF instructions:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15077-Manual-eng.pdf
Posted on Oct 07, 2010
shunt311
  • 34 Answers
SOURCE: Model #15119 GE plug in
Hi, here is the manual for your timer.
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15119-Manual-eng.pdf
You need the adobe reader to view PDF file's if you dont have it here is the link.
http://get.adobe.com/reader/
Good luck (",)
Posted on Jan 07, 2011
How do I set different programs on the digit timer for my Christmas lights to come on different times??
Copy following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Note there are links to other brands.
Add comment and describe timer for more possible help.
Nov 27, 2012 | Hardware & Accessories
Tip
Dyson Cool AM08 Air Multiplier pedestal fan - Getting started
How to assemble and use your new Dyson Cool AM08 Air Multiplier pedestal fan: adjust the power and oscillation, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
on Mar 07, 2014 | Dyson Dryers
Need a good vacation timer. Any suggestions?
Copy following link to see analog vacation timers that turn lights on at random times.
Set current time slightly different so lights inside house can turn on-off at slightly different schedules.
Rotate dial to set current time, plug timer into outlet, make sure bulb is good, turn light ON, and plug light into timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#vacation
Multi-function digital timers, such as Woods 59377, and lifetime-warranty Intermatic DT620 also have vacation feature, and timers have 2 outlets, but programming is more complicated than using analog timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#digital
Jul 13, 2012 | Hardware & Accessories
It works fine until the time i have set for lights to come on they dont come on, but if i plug in recept. Ii works fine
Timer is not identified. Problem is not clear.
Add a comment with clear description of product, and say what you have done to set timer.
What do you plug-in to make lights work?
Question is posted under Woods dawn-dusk timer that turns ON automatically at dusk, and then turns OFF 2 4 6 or 8 hours later:
Many different timer-brands work in same manner.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
Jul 28, 2011 | Woods Outdoor Lighting Timer
I have a Westek indoor digital timer, i have a nano tank with 2 lights (moonlight, daylight). I"ve tried setting the timer for 7 days with each light on at different times, it just won't work.Though...
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
http://waterheatertimer.org/Woods-timers-and-manuals.html#TE05W
You want to control each light with different programming?
Westek TE05 timer is single-channel timer, so different lights cannot be controlled by different programs.
You need a two-channel timer so each light can come on at different times.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Zilla timers are two-channel timers: yellow outlets for daytime, and blue outlets for nighttime.
Mar 28, 2011 | RTO Amertac TEO5W Decorative Indoor Weekly...
Lost direction on how to set the timer
You posted under Woods 59383
Manual for 59383:
http://waterheatertimer.org/pdf/Woods-59383.pdf
If you have different model Woods timer, see link below, or add a comment.
To set Woods 59383:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Segments located around dial control on-off times.
Pull segments UP for OFF times.
Leave segments DOWN for ON times
Set manual override switch to arrow-down position
Switch unit to ON position.
Plug in timer.
Plug lights into timer.
If lights have switch, switch must be ON.
Max load 500 watts
50-mini-bulb string of Christmas lights is 25 watts
Dec 01, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Don't know what is it used for,and how it operates?I don't have any instructions for it.
You posted under T101 timer.
Most box timers have model number and instructions pasted on inside of door.
Instructions can seems a foreign language sometimes.
If your timer is different than T101, then add a comment with timer number.
I have extensive files on timers.
Box timers are generally used for heavy amperage loads like outdoor lights, swimming pool pumps, water heaters, parking lot lights and lighted outdoor signs.
They are surface mounted near breaker box, or in attic or basement, or garage.
Box timers are used in schools to ring bells, and inside factories to run processes and fans.
Some are complicated electronic devices used to control machines with one second precision.
Mechanical box timers are noisy when turning on-off, so are generally not installed in living area of house.
T101 timer is least complicated of any timer.
It is used for ordinary household 120V circuit.
Timer has 120Volt clock motor, and controls 120Volt circuit.
For example 120Volt water heater, or 120V grow lights, or aquarium, or any application up to 2 horsepower, for example timer can be located inside garage to control outdoor lights.
T101R is raintight outdoor box, with rubber gasket on door that seals tight when closed.
Raintight boxes are installed outdoors to operate 120Volt spas and pool pumps.
When box timer is rated for indoor, there is no rubber gasket on door, and that box is called NEMA 1 enclosure.
My local Lowes sells T101 T103 T104 > and each is for slightly different purpose and each wires differently.
Link below shows wiring and manuals for T100 series timers.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Here's how T100 series timer works:
Lift and rotate yellow dial until current time lines up with silver pointer.
Clock motor rotates dial as time passes.
Clock motors are accurate for years, but current time has to be reset after power outage.
ON-OFF trippers are placed on outer edge of dial.
Trippers push a lever, and lever turns circuit on-and-off.
ON tripper pushes lever one direction.
OFF tripper pushes lever opposite direction.
Each time lever is pushed, manual-override lever clicks back and forth with audible sound.
Dec 01, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
My grow light is on a timer and was off last night when it was suppose to be on i played around with it and got it on, but once again as soon as it went off wont go back on... Maybe it is something to do...
check and make sure you have the timer right am/pm.also the mechanism that rotates the timer might also be bad or going bad.if the am/pm timing is set right i would try another one from your local home center and if it works its likely the timing mechanism.
Mar 24, 2010 | Garden
How do i set a bog standard timer to control lights
Ok these work in 2 ways and get get a bit illogical.Say if you want to set the timer to come on from 6am and run till 11am.
You either push all the teeth inwards to the centre for that time, or you make sure they are out.
The usual is to push all the teeth inwards from 6-11am to put the light on.
Apr 02, 2009 | Garden
General Electric GE 24-Hour Power Strip Timer #57698 Logo
285 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Freddy
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
