Got new baird sound bar 3.1 channel speaker system 70 wat and dont no ow to change bass
  • 6 Answers
SOURCE: Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Posted on Sep 24, 2006
  • 905 Answers
SOURCE: Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Posted on Nov 03, 2008
Benimur
  • 6966 Answers
SOURCE: bose companion 3 series 2 multi media speaker system
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, the 14 seconds interval is significant. This is indicative that whatever fault it is, it is coupled to a time-based circuitry. The time-based circuitry need not be complicated. it can actually be a simple resistor/capacitor network. The capacitor takes a certain amount of time to charge and then discharge (14 seconds, 'whoomp'). Having said this, then the foremost suspect would be an electrolytic capacitor, probably low value (1~4.7uF), probably a coupler/decoupler. Of course the capacitor serving other functions could very well be the culprit as well.
Corrective measure would entail, identifying/determining which capacitor and replacement. Tedious as it may sound, each capacitor would then have to be tested for capacitance and leakage out of circuit or at least 1 leg un-soldered.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate it at all. Cheers.
Posted on Dec 27, 2008
DickCanFixIt
  • 948 Answers
SOURCE: Bass/Treble balance on Bose Lifestyle 5
You need to go into your menu and set the "MOVIE EQ" to your liking. That is where your bass/treble balance is on a Lifestyle system.
Posted on Mar 01, 2009
  • 153 Answers
SOURCE: connecting 4 bass speakers to one amp?
If you have a 4 channel amp and 4 speakers and each speaker is connected to each of the 4 channels you are just fine.
A stereo amplifier has 2 channels, typically labeled left and right and each channel has an amplifier. A 4 channel amplifier has 4 amplifiers. With one speaker on each channel, there is one speaker on each amplifier. Audio amps are referred to as amps or amplifiers, although if they have more than one channel it would be more correct to call them something like 'multi-channel amplifier' or 'multi amplifier speaker driver'. Semantics.
Posted on Apr 29, 2009
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
Sir my speaker bose 301 series v and i connect to amplifier pioneer 5 x130 watts.also i have center speaker.bose vcs10.is this compatible to good music and movie....
If they're all Bose 301-5's then you have the rare instance of matching speakers all around, so when sounds move around the room in a movie they don't change. I'm envious because even though I have Bose 901's (front) and 301's I don't have that exact match you have. The 301 sound is very good to my ears.
I assume you have them all set as LARGE speakers in the Pioneer, since they are capable of good bass and the parameter is more about Bass response than actual size.
If you added a subwoofer (which you may not need) you might fill in the lowest bass and effects channel.
Aug 19, 2010 | Bose 301 Series V Direct/Reflecting...
Hi, i wanna know how i can get correct and good withe balance in many different place under sun and beside wit filters change ?thx advence
i think youre trying to ask how to create a good balance, but im not sure what you mean. theres a balance of bass to treble, and theres a balance of sound so yu dont feel too far from any speakers.
balance between bass and treble can be done with tuning the stereo and the amplifier gain.
balance so you dont feel too far from a speaker, most people get more speakers, or run a 4 channel amp to their speakers to make them louder.
Aug 17, 2010 | Car Audio & Video
My 1994 e150 sound system sounds puny compared to what I believe stock should be. All the speaker work there just isnt much volume, bass, or treble. Is there an amp that boost the sound? where is it?
well first i would change all the mid speakers out to kenwood speakers and not the cheap ones cause the cheap ones are like stock speakers the more higher priced ones like the 80 dollar ones are equal to 300 dollar speakers then you should get a 2 channel or 4 channel MTX amp each speaker can take 150watts. your system would be alot better than stock. if anything look on crutchfield.com that would be the best place if you dont want to go to a car stereo shop in your area. if you plan to keep the deck stock then you need a hi-lo adapter which will hook up to the right or left rear speaker and the remote wire needs to go to the ignition wire behind the deck
Aug 01, 2010 | Car Audio & Video
Our new lg 5.1 surround sound system will only play full surround sound on some new release blu ray films and the rest will only play through the front 3 speakers as dolby stops as soon as you get past the...
Dolby will only activate when it has information for all 5 channels. For normal stereo only left, right and bass boost speakers work, so you lose center and rear speakers. The system should have an option to play SIMULATED surround sound, to activate all speakers. In many systems, this option is called dolby prologic, simulated or some other fancy name.
Jan 17, 2010 | Audio Players & Recorders
Ok this problem is killing me...
maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Jun 18, 2008 | Visonik Dual Bass Box with Amplifier Car...
Bass destortion
yes u nee dto get the kilspe 2.1 promeadia speakers way better big bass rocks seprate bass control used set on ebay for 65
Feb 02, 2007 | Logitech R-20 Computer Speakers
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Televison & Video Logo
325 people viewed this question
Top Televison & Video Experts
Electro Med Services...
